Nvs, Dartzeel, Durand, were beta tested in Mike's room for months, and Ron used for development
Ked, are you Mikes spokesman now?
Peter,
I would describe Mike's (458) system more like a 3D mapping system that lets you look at everything in the soundstage, and with an unlimited dynamic range so you don't get any false flags about what is where, or what is being played. It is more like you get this experience that makes you sure you could get up and walk around going from musician to musician, and see what they are all playing. It kind of reminds me of a very high dynamic gray-scale image (blind people that sonic locate see in gray-scale, connection?). Nothing stands out or forces you to focus on it, so you're able to examine all of it in an extended scale - like the physical embodiment is about the room. And it can sound like you're in a big venue!
So it does not sound like live music, and it does not sound like all the characters of the studio. It is really about getting a special view into everything going on within the music. It gives a depth of ability to differentiate all the things happening without limitation, that is on such a level that it makes it world class. And it can do it while rocking out to Led Zeppelin or Bach.
Please debate this with Folsom. He suggested 1) that acoustic measurements are objective, and 2) that can be used fairly easily to build a good listening room for two-channel audio.
just to set the record straight.
I reject completely and unequivocally the use of the words 'dry' 'dryness' 'dryer' or any derivative of that word relative to the darTZeel electronics. period. exclamation point.
jeeeezzzzz!!!!!
Ron, see what you have done using bad words around the children. now they are all potty mouth young devils.
I agree, nice writing.![]()
The ability of the system to recreate the venue as it's soundstage generally means things are pretty dialed.
Morning Ron,
Just woke up and saw your comments regarding one of my previous comments in this thread.The smiley after your first sentence and an expression like “Miguel’s Kool-Aid” suggest irritation on your side. That puzzles me in all honesty.
First of all, I do not think this forum was created for diplomats (only). If I read things on WBF I disagree with or opinions that in my view need more context, I react in case I think a broader / different view might be interesting to our members. And maybe unlike some of our members I do not distinquish in this regard between comments made by ‘regular’ members and founding members or administrators of this forum. Respectfully disagreeing with eachother or seeing different audio angles should be possible on WBF.
In my reaction I did not state nor made the suggestion that you were critical about the Tripoint grounding. That was not the point. My (main) point was that (top notch) grounding is key for getting a really great, that is a realistic, music reproduction at home. Nothing more but also nothing less. It is in my view one of the fundamentals - as acoustics, power and isolation - of our joint hobby.
You experienced a certain dryness with the Dartzeel solid state amplification. And I suppose this is one of the reasons (or maybe the main reason?) why Mike is experimenting with / listening to tube amplification in his set up. If he would have been completely happy with his audio system / ss amps it would make no sense to invest a large sum of money in set amps. Without the grounding he is currently employing this dryness would have been (much) more profound. And guess what: if Mike would ground his ss amps with a Tripoint Elite or use (even) better ground cables, this artifact will (very) likely dissappear.
So in short, my point was - and I suppose the same applies to Robert but he can speak for himself - and is that by ignoring the importance of grounding the audio picture was not complete. Nothing more, nothing less.
jeeeezzzzz!!!!!
I truly believe he could have liked Ares Cerat dac, pre, power at a show, or Zellaton spkrs, or CH Precision dac, amps, or AG Trio horns, or restored Apogee Full Ranges, or Robert Koda etc etc (you get my drift) got it home, and the room would have synergised an amazing blend.
And you’d have come away with a parallel musical exposure, maybe just as compelling.
Dear Bruce Dee,
Sometime I wonder if the Tripoint actually makes your system sound worsewhen you disconnect it. I mean when you have it in your system, you get all the goodies that Tripoint users talk about. I am using the Elite. I hear all that too. Recently, I connected my tape pre to it and boy it alleviates my tape sound even more. But when you even unhook just one of the grounding cables, even from a power supply of my phono, I get this incoherent sound that can be easily detected if you are not deaf. The thing is Before I had the Elite in my system, I didnt hear any harshness or disoriented sound like this. I know there will be consequences having said this
. Just an observation. I better get back to my hole.
Kind regards,
Tang
. . . Are you analyzing measurements of your room?
. . . I used Air Tight ATM 211 mono Amps on 97db Zingali for a year. . . .
The Room was absorbing some of the energy, which helped a lot to get the resolution I was looking for, but on the other hand the need of power, even for 97db speakers was increasing by a margin.
My current tube monos are CAT Convergent Statement Amps. . .
Maybe. But I would guess that Mike would find exotic tube gear to have a coloration of some sort.
Yes - I have been trying to get the frequency response chart of Bonnie's measurements.
recently I did own the Lampizator Golden Gate for 15 months, and had the Nagra HD dac twice in my system for a few days over a 4 month period.
ultimately; both were exposed in my system as having colorations that, while I really liked them, had a sameness/coloration over the music. I prefer the sonic viewpoint of the MSB Select II for, among other reasons, better system synergy and more pure window on the musical event. YMMV, just my 2 cents.
What do you expect from the isolated frequency response chart? IMHO it supplies very limited information and can be very misleading.
Dear Audiocrack,
Thank you for your very thoughtful and introspective reply.
First, please know that mys are always genuine, and never facetious.
Of course you should never distinguish between "regular" members and founding members or administrators. Anyone who cannot take some heat should get out of the kitchen -- even if it is his kitchen!
I think I was a little trigger-happy when I saw your post because immediately prior to reading your post someone sent me a screenshot of a Facebook post (I am not on Facebook) by Miguel which was a pretty snarky comment. When my wife read Miguel's comment and then read "Mike has deployed an elaborate array of Tripoint and Entreq grounding products, which I do not understand and which we did not discuss" she was dumbfounded to understand how my self-deprecating admission that I do not understand grounding products could possibly have attracted such an obnoxious comment about me from Miguel. So that is the "backstory" to my Kool-Aid comment -- which I absolutely should not have written, and for which I sincerely apologize!
But the theorizing that more Tripoint products "(very) likely" will ameliorate the shade of "dryness" I believe I heard from the darTZeels compared to the ML3s is the kind of preconceived notion and assumption which I argue against in the article. You are a fan of grounding products, and so many sonic problems tend to look to you like grounding issues. Someone who makes cables products probably sees most sonic issues as having a cable-related solution. In the article I implore people to be much more circumspect about what thinking they know what sonic attribute is caused by what, and to not be so quick to assume a particular cause and effect based on their particular component interests or preconceived notions.
You may be right -- but I, personally, have absolutely no idea if even more Tripoint products will ameliorate the "dryness" point.
I agree that acoustics, AC power and isolation are fundamental issues which a well-sorted room and system will address. But to me Mike had a fantastic AC power infrastructure (100 amp Equi-Tech isolation transformer and balanced power device with dedicated circuits leading to Furutech outlets) before the first Tripoint product entered his room.
My fault, Mike! But I do not know what other word to use to explain why on music for which the ML3 is great in your system I would prefer to hear that music though the ML3 rather than the 458.
