Greetings music enthusiasts, audiophiles and electrostatic lovers- especially Martin Logan owners.
That time has come, and I thought it would not happen so soon. I have finally parted with my Quads, and closed the deal for a brand new pair of Ethos. The speakers arrive on Monday!
From the very first note and basically the third serious audition with the Ethos, I knew straight away that this was the full sound I was looking for. My Quads served well (apart from the reliability issues...) and they delivered many hours/ years of musical bliss. I thought that was going to be the end of the road BUT when I seriously spent more time with the Ethos, it just left me in awe. It was as if someone had taken a veil or cloth off their face and mouths and started to sing, belt out dynamics of tonal accuracy and a very high level of transparency that the Quads are not capable of.
Apart from the loudness factor, which I will never use at that level, it is a solid build! Using ML's latest X-stat technology with vacuum bonding air frames, the voltage tolerances are none that I have ever experienced. I am extremely grateful for all the valuable advice given in reference to stats (their pros & cons) and especially to Kostas for his outstanding demonstration of the CLX's. Now I can begin to fully understand the ML philosophy and its quest for music purity.
Not only was the speaker far ahead in terms of ruggedness and construction but also superb value! It was less than half of what I paid for the Quads, and this goes to say that expensive necessarily doesn't mean better. I was nearly looking at the MG3.7i but I think this is one of those very special experiences one could possibly have in your home and one that delivers absolute value with a true refinement in sound.
I truly hope the road ends here, as I will not be able to afford the CLX's due to other commitments & priorities. Apart from that, I don't think I would ever need the CLX's as the Ethos gives me all that is required and plenty more in the Low frequency, allowing it to be matched according to room characteristics. Although a FR stat would be the perfect line source, I will only dream for now...
Might as well sit back and enjoy the music!
Cheers to all, RJ
Cheers to all, RJ
