please describe for all of us the specific in home reproduction system that has come closest to meeting your expectations. it matters not your degree of disappointment. simply what got closest.
all your lamentations need a context.
thanks.
OK, here it is, prototype #2, being developed for 11 years so far.
About the room (which is critical) it's a rectangular prism about 30 feet long, 14 feet wide, 9 1/2 feet high. One long wall is mostly glass, there are windows at the front and rear. The flooring is low pile burber carpeting over wood. Acoustics are on the live side but not terribly so. There are no acoustic room treatments...deliberately. It is a standard Toll Brother's music conservatory with a flat ceiling due to a room above it.
The main speakers are modified AR9s. Substantial changes have been made to its spectral balance by virtue of additon of eleven 3/8" indirect firing mylar tweeters per channel that are aimed at the walls and ceiling. This results in the reflections from the main speakers having the same spectrum as the sound coming directly from them. Unfortunately, this corrects for only one type of geometric field distorions of three identified by the model but it's a critical one. If there's a future prototype, I will design a different type of speaker that will correct the other two.
Sixteen RS Minimus 7 speakers are located around the perimeter of the room. They aim their sound exclusively at the walls and ceiling. Small but effective enclosures for them prevent their direct radiated sound from reaching anyone in the room. Extensive signal processing generates the necessary time delays, changes to spectral content as the delays become later, and channels the appropriate delays to the speakers. The currnt version divides the room into 4 reverberant quadrants each supplied by four speakers. The system could generally be desribed in conventional terms as 6.2. The signals all receive extensive equalization. There are 16 equalization circuits including for the main loudspeakers. It is critical that the system sound flat and that means among other things individual equalization for each recording, even different cuts on the same recording. Very tedious to arrive at. Changes to the simulation of acoustics are achieved by changing parameters of time delay, rate of spectral change during decay, adjusting the relative and absolute intensity of the individual sound fields. Small changes can have a substantial subjective effect. The system is classified as an Electronic Environmental Acoustic Simulator and was described in vague and general terms in my now expired patent 4,332,979. Despite its complexity, in this class of equipment, it is a very primitive version. The patented version itself was severely chopped down and adapted for its use as an entertainment device compared to the full blown concept. I think of it as being like a very early color TV set, unique but difficult and quirky.
At it worst, it will produce sounds that are literally unbearable to listen to. Worse than you could possibly imagine. I am not one for hyperbole but this is what it strives to accomplish. Among its goals which it achieves fairly well with most recordings after enough tweaking are the following; Enormous and natural sense of space. Sense that the instruments are far beyond the front wall of the room and more powerful. That the sources of the reverberant field are undetectable by ear. That the reverberant sound field is inescapable in the room. That the musical timbre of instruments are reasonably accurate as they would be heard at a live venue. There are no sweet spots but there are sweet regions which are in about 1/2 the room. If there's another prototype, that's another engineering issue that will be addressed, to make every spot in the room a sweet spot to listen to.
The system is designed and adjusted to the room it's in, not in the usual sense of tuning but where the acoustics of the room itself is an inherent and indespensible part of the system. The system does not fight the room the way conventional sound systems do, it depends on the perimeter of the room to reflect sound to work. Any changes to the design of the system or its calibration to the room invalidates all prior settings for individual recordings. If the system were to be moved to another room, it would have to be completely redesigned and recalibrated for that room. It would be difficult or impossible to get it to function properly in some rooms. Irregularly shaped rooms like L shaped living room-dining rooms, discontinuities created by large archways or openings to other rooms, rooms that are acoustically on the dead side are its bane. The adjustments to the field to get it in exact balance are critical. Errors of as little as 2 db can be troubling. For example, the system must take into account that one wall which is mostly glass reflects sound differently from the opposite wall which is mostly sheet rock.
The system does not use special amplifiers, CD players, wires, or other audiophile paraphanelia. At the time I started building it, I could have incorporated them if I'd felt they'd have been of value. The entire system provides under 300 watts of amplifier power and cost under $3000 to build (much of the equipment was bought used.) The first prototype which used entirely different equipment relied on LPs as CDs were not yet available at that time. A pop or click on a phonograph record played through this kind of system sounds like a canon shot. The one type of distortion it cannot compensate for is where there is an imbalance of loudness between two instruments on the same recording. The system exaggerates the disproportionality so for example if a piano or violin is as loud as an entire symphony orchestra, it sound rediculous.
I'll be the first to admit that even after all these years of experimenting with this type of system and the model behind it, there's still a lot to be learned about it. There are still aspects to it which I don't understand. When you sail in uncharted waters, you are entirely on your own. If you can't figure out how to solve a problem yourself, there's no one to turn to for advice.
Well that's it. It's been a great toy to play with. It's why I'm not an audiophile anymore. BTW, absolutely nobody qualified for whom I had even the faintest hopes of developing it into a commercial product was remotely interested in it.
