As I can listen to it for many hours at a time I do not develop fatigue at all with my digital, others do. It depends on your sensitivities I guess, and I don't mean that in a derogatory way at all.
However, listening to unamplified live music puts things in perspective. Yes, often it can sound very smooth and 'clean', but perhaps equally often it sounds hard and even 'distorted' -- all depending on venue and seating position. Just close your eyes to suppress expectation bias from seeing the musicians playing, just listen, and it becomes evident. I have heard live sounds from unamplified instruments that, if they could be properly reproduced over a stereo system (very difficult to do), would make many an audiophile run out of the room screaming "distortion!".
I wrote the above on another thread. Diapason, who is a musician, suggested that this observation about live music is a crucial point that is often overlooked, and encouraged me to initiate a new discussion on that:
http://www.whatsbestforum.com/showt...yth-busting-thread/page39&p=373394#post373394
However, then I remembered that to some extent the topic was already discussed in this thread.
Yet I would like to revive the subject from another angle, by expanding a little more on 'cleanness' of sound through stereo systems. On a number of orchestral recordings the reproduction especially of brass through my system sounds pretty hard, not unlike what I experience from brass in many, but certainly not all, live concerts. Yet sometimes I am not quite sure if the recorded sound really has that intrinsic character or if the sound is, at least in part, just the result of system distortions. I tend to believe that some orchestral recordings may drive my system to its limits, so the system might distort then, but on the other hand other orchestral recordings heard through my system give me pause: they really do sound rather smooth and clean even at loud volume. Does my system really distort that much then? I know that on some systems hardness is never or rarely presented in the manner as it is through my system, and there is never any hint of the 'distortion' that I hear even in some unamplified live music, a perceived distortion which appears to arise from the acoustic interaction of the sound waves from the instruments with the hall or venue in which they are playing and which does sound somewhat like common distortion from audio equipment. Are those systems indeed less distorted than mine? In some sense perhaps or even probably so, but do they sometimes make the sound smoother and 'cleaner' than it should be? After all, they never sound 'distorted' in a manner that I even hear in some instances of live music, as just described.
I have the impression that many audiophiles are obsessed with having a 'clean' sound -- the greater the perceived cleanness of sound the better, supposedly, the system is. Yet based on the above a provocative thought has entered my mind:
Could it be that in some instances the clean sound rendered through a system is in reality a form of distortion, and that a less 'clean' sounding rendition of the recording at hand would in fact be the less distorted one?
I know this sounds counterintuitive, and turns the usual perception on its head, but would that be possible? After all, distortion means not just what we commonly refer to as distorted sound, as audible harmonic or intermodulation distortion, but any alteration of the original signal to be reproduced through an audio system. In that case there might indeed exist something like a 'too clean' sound.
My thinking is lead into that direction also because of a relatively recent experience that I had in a very high-end system. I thought the sound was of incredible quality, but a bit too polite and polished compared to the real thing, unamplified live music (yes, live music can sound very smooth depending on hall and seating position, but the system sounded remarkably smooth on every recording, which I did not find realistic). A later substitution of the phono stage with an audibly superior one removed the in my view too polite and polished character of the sound and introduced a more credible hardness and bite of sound on music where you would expect it; that new realism in combination with all the other strengths of the system made the sound phenomenal in my view. In that case one could argue that the previously too polite and polished sound -- a too clean sound if you will -- might have been a weakness of the system's performance, rather than a virtue. *)
Any thoughts?
________
*) The phenomenon described for this system might have had to do something with system synergy, because I heard the phonostage that appeared to have been the culprit also as part of another system that did not sound too polite and polished at all.
