Well, the fact that desktop Chrome browser works and that doesn't, I say the bug is in the Droidx. That said, every browser had a ton of bugs and web software is designed to work around it. In that regard, I say vbulletin needs to work around it.
We wouldn't be doing the messing. They would have to roll it into one of their future releases.I hate to mess with our software to fix that single bug.
No, I have not. I like Chrome on desktop so didn't feel the need to switch until I ran into this issue. Compatibility has been really good and performance excellent. Is Dolphin free? And have you tried to post with it?Amir, have you tried/downloaded any other browsers on the phone? FWIW, I use Dolphin HD on my Droid and it works fine.
Thanks Ron. Which option did you use for posting? I found one that worked (plain "Reply") but the other two would not.This post is made with the Dolphin HD browser.
There are 2 versions of the Dolphin browser program and one is "HD" which is a higher resolution version.Why the HD in the name Ron. Is it only for droid phones
I think I first hit the Go Advanced button and then hit submit.Thanks Ron. Which option did you use for posting? I found one that worked (plain "Reply") but the other two would not.
...Battery life is disappointing. It lasts a day and half and it goes abruptly from ample power to warning that it is too low...
