Thanks for that. In my room, although very large, I want as narrow a speaker as possible, as they are placed mid-room with floor-to-ceiling windows beyond, that offer fantastic views from my 19th floor flat overlooking the harbour and city.From a practical side the Mezzo bass cabinet has a larger footprint than the DuoGT. So, if you are concerned with space then the DuoGT will be a little easier to fit.
For that reason I ditched the Duo XD "scaffolding" and replaced this with a top-mounted cradle on the lines of the Mezzo one, but with revised measurements provided by Avantgarde. This allowed the base frame to be rotated 90 degrees (as per SUB231) to further slim them down visually. With my earlier Duos, a back-mounted F-shaped bracket was made to support the 2 horn tubes. Both work well, with improved vibration control and the appearance of being considerably narrower. The Mezzos are losing their appeal!
Photos of Duo XD as supplied and as modified, and earlier Duos with F-bracket to support horn tubes
