Transrotor cleaning arm
Bodhi
1,051
361
155
I know my Dealer doesn't sell many of them - if any. I haven't seen any of his Transrotor customers using the cleaning arm. My friend who owns a TR Tourbillon uses these excellent Goat hair brushes from German company, Levin Design & just cleans the lp and needle before each play. That's the way I'd go, along with having a custom acrylic dust cover made for my deck. Another top tip is to use something like the excellent Acoustic Revive RL-30Mk3 demagnetizer which effectively demags and destats your lp in one step.
audioquest4life
328
188
115
60
I have been using this with my Transrotor Apollon TMD for years. The one thing you have to watch out for is if you have a thicker platter, more than 60M, you will need a three piece cleaning arm and their is a chance that the glue holding the extended holder for 80MM platters can come undone or loose Making the top portion with the actual brush unstable.
This is my model: https://www.hifi-phono-house.de/pla...nsrotor-design-staender-fuerorfeo-und-apollon
i find them effective for large things like pet hair...I use this in combination with a carbon brush.
