Tim, your repetition of this mantra is getting a bit tired, but I will respond at least one more time:The elimination of noise so small that most audiophiles and recording pros never hear it has, in your system, resulted in expanding the off-axis frequency response of your speakers beyond what is credible, in imaging that simply cannot happen - in any room at any cost - in dynamic range that is inconceivable from a system the size of yours. I don't doubt that you have some understanding of electronics that exceeds my own, which is very limited. What you clearly don't understand is how, and how much, those electronics can impact audio reproduction. In that area, you've transcended engineering, even science. You're firmly in the realm of science fiction. The methods you're employing - even if they were dramatically more effective than they've ever been for anyone else - are simply not capable of yielding the results you're reporting. They are, in fact, barely related.
I think it's to do with the position of the fingers, expressing deep thoughtfulness perhaps??By the way, Steve, I think you and I have the best avatars. I'm just sayin'....
Tim
Dan, thanks, but I probably won't have the time to digest what has been said on another forum at the moment. These are not brilliant descriptors, but would you say the improvement was in musicality, or dynamics, or both?Upgrading the TacT RCS PSUs made a very big improvement in the SQ.
I think people got tired of talking about vibrations so the thread started wandering (or was it vibrating?).
So we'll leave it at the "agree to disagree" level: the people who've "got" it will stay, quietly, on one side of the divide, and the ones who believe it is impossible to "get" it will stay on the other. That's fine by me, just a shame more people can't "get" it ...I can't make it real for you, and you obviously can't make it real for yourself
finding that digital needed about a week to come good -- oh, dear!!
fas42
Few people here would agree that you are able to get what you say you got from your HTIB. Then, now you are saying that a 108 dB speaker can be driven by an HTIB .. What you showed us when you were pulling our collective legs were regular HTIB speakers not a horn based thing ...
Yours IMO is a very subtle type of trolling .. You look for and eventually find allies on specific subjects in general far out stuff but those you know some audiophiles here will consider and for a few posts or threads go in their way .. then you (feel compelled to) come up with some impossibilities and watch people react to it .. likely smiling or ROTFLYAO...
Having said this, that is the last electron I will spend on you. You are on my ignore list ...
Sorry you choose to ignore me, Frantz, but I got the idea that the aim of many audio forums in general is to bring "new" and different ways of thinking into the arena -- how many times do you see posts from people despairing that the industry as a whole is slowly decomposing into a self indulgent relic, of very little interest to the newer generations. So I'm just trying to do my bit to counter that!now you are saying that a 108 dB speaker can be driven by an HTIB .. What you showed us when you were pulling our collective legs were regular HTIB speakers not a horn based thing ...
I would have thought fairly obvious, Tim. This is something that numerous, "normal", audio people have mentioned over the years, that the digital circuits, especially the ones in the early years, seemed to need long periods of time powered up to stabilise, that is, for the SQ to be at optimum. Which for many people, for many years, was a level that was on the borderline of being bearable ....,,,what, in God's name, does THAT mean?
Sorry, terry, life gets in the way; I got caught up in things to be done while answering your longish post. We met at your factory some years ago, my memory wouldn't be able to pick how many; you showed off a new speaker you were putting together at the end of the day, to demonstrate what you were aiming at, etc.
Dear, oh, dear, what a twist. I acknowledged that capacitance changes may not be the primary cause, but suggested other second order effects could do the trick. In terms of measurements, like most people here I rely on my ears: if something sounds or works better because I address some issue related to vibration transmission then I use it: I don't reject it because I can't point at the precise technical explanation for what may be occurring.
So if you have audible problems then the "true cause" may not be understand.
But the main thing is that there are several things that are original, and I am not yet ready to give these ideas away. It's the old IP problem, I'm afraid.
It most definitely is NOT simple repacement of cap's and suchlike with designer parts, and throwing in ferrite bits here and there. It's a lot to do with getting rid of every critical connection which just relies on physical insertion to do the job, doing major surgery on how the power supply is stabilised (that's mostly IP), stopping vibration affecting crucial cabling (hmmm, where did I read something about that ...), and filtering out garbage from the mains (also IP)
Frank
Terryj-The reason why we let things go with Frank is that we have found out over time that when you try and drill down into his core to get answers, it's like pushing down on jello. It just gushes out the side and you never get the answers to the questions you ask or you just get more hocus-pocus. Frank was just asked to provide a picture of the inside of his wonder machine and he won't do it. Why? Because either he has done nothing, or it is so butchered up he would be embarrassed for anyone to see what he has done (which is pretty much what he said).
Well, thank you, microstrip, case dismissed!!! Of course, it is not politically correct to continue with the "charade", so for normal listening you must now throw away the weedy speakers and attach an appropriate manly one to the Krell ...
Of course, the thought for doing the reverse now occurs to me: why not get a miserable, zero cred amplifier, doctor it a bit and then attach it to mega expensive, impressive speakers and see if you can fool those same friends. Gee, there could be something in that ...
Holy dooley, I've just got a great idea! Why not get weedy speakers, doctor a miserable amp and get really impressive sound!! Hey, I hope no-one else has thought of that yet!
Frank
* "elimination of noise so small that most audiophiles and recording pros never hear it" - everyone has, it's the ugly crap you hear from your tweeter when you put ears too close
* "in imaging that simply cannot happen" - plenty of people can get it, check out the thread in Audiokarma
* "dynamic range that is inconceivable from a system the size of yours" - all systems have that sort of dynamic range, the trouble is that the sound is normally so messed at that volume that no-one would want to keep listening to it
* "clearly don't understand is how, and how much, those electronics can impact audio reproduction"
To answer your points, of course a 108dB sensitive speaker can be driven to deafening levels by the HT. However, my speakers are probably around 90dB, the amps can do 20 watts, so peak volume between the speakers at 2 metres is around 105dB, straightforward audio maths. Plenty loud enough to produce impressive sound if the key bits of the system are working correctly. The thing is, I have heard so, so many systems not working working correctly over the years, that I, in my own little corner, have very little desire to hear any more of such ...
Frank
Talking of expectation bias, it would be very amusing to get some extremely highly regarded gear, speakers, amplifiers and such and do some cosmetic mods. Put a skin of bad veneer around the speakers, glue a Bose badge on front; add a cheap plastic box around the amp, etc, and stick a weird Chinese name on the bits. Play this for a group of audiophiles and state that this was a bit of rubbish that a relative had passed on to you. How many of the listeners would nod sagely, and agree how terrible it sounded, and ask how fast you could get rid of it?
Frank
Why not ask the mods if you can have your own manufacturer subforum? Look at how good that arrangement would work for all.
two chances at that Terry.......slim and none
Guys, let's do things this way. If you have nothing to discuss pertaining to the thread topic, simply join a different conversation here. Of course, you may feel free to address any points about audio in any thread.
Thanks,
Lee
