Something I have done before, but since we are on the topic, here are different versions of a recording:
Google Pixel 6a
iPhone 10 S
Tascam DR-100MK3 (build in microphones)
The recordings were all done simultaneously and at pretty much the same distance from the speaker.
There is a little bit of static on the left side of the Tascam recording at several points, which may be due to the proximity of the phones - those recorders tend to pick up interferences from other electronic devices (especially phones).
The track was probably sourced from a 78 (the original lacquers may have not been available, I don't know). There is a lot of "surface noise" in the recording, which the Tascam picks up more clearly, along with everything else.
I have external microphones for the Tascam as well, but one of the XLR plugs is broken and I have not fixed it. The external microphones are better (but not "studio-grade").
You may not like the music and/or the speakers - but it serves as a reminder of what a better microphone/ADC brings to the table.
I cannot see how different versions of the iPhone would make a significant difference, compared to what you get with a recorder like the Tascam (which can be found on ebay for 250$, the MK2 version even less).
I posted the recording initially in my thread, with some details about the track and the source, if you are interested to check it out: https://www.whatsbestforum.com/threads/hopkins-system.35850/post-943453
Note: the recordings are made "near field" with a single speaker (track is mono). That's how I like to listen to the Altec. Little room interaction, no speaker cross-talk...
Google Pixel 6a
iPhone 10 S
