Where would you source a wooden horn?I like the sound of my Odeon wooden horns very much as well...my DIY will probably end up with wooden horns in the end...
Are there commercial products available in wood?
Sounds great, Sami. There is mixed opinion in the school of thought on wall thickness too. I also opted for thick wall like you (and others such as Romy) but there are proponents for thin walls. I was studying the web on the BBC cabinet philosophy with thin wall, thick wall etc. Quite interesting.Just to add more, they type of wood and the thickness as well as finishing also have an effect. As I have been working on the new speakers I have built out of mdf, plywood and solid wood. Then I started trying different finishing materials.
I have clearly found out that the finishing has much less effect when there is enough thickness. There is still a sound signature between types of wood but it lessens with thickness. Still mdf and solid wood sounds different enough. I ended up making the horns quite thick, with solid wood and quite a bit of layers of instrument grade finishing.
Thanks for the informationsThere are small manufacturers making JMLC, tractrix, and radial horns, such as clones of TAD radials, in wood. Markus klug and others are making wooden multicells. Bill is making tractrix as of now for his own but surely he can make JMLC.
When I knock on my mid horns on the Unis, they sound quite inert but not dead, maybe that is the reason...Leif and team had tried wooden JMLC but went back to autotech.
Interesting because the Pnoe horn is rather thin walled.I have also heard a high plastic sound in a concrete and plaster JMLC with BMS driver, so it is not imo as simple as a slam dunk on material. Wood horns have their own color. The correlation is tough to establish with material alone, leaving aside driver and crossover. Does tune audio Anima timbre sound good because it is a wood horn? Not sure. Universum and Pnoe sound awesome and are not wood. There are some that sound very plasticky. The BD oris BMS driver also has a plastic diaphragm
So it is all a matter of combining and executionAt Munich in 2019 they had papier mache horn as well as metal horn in the western electric room and it was great, and JC strongly recommended papier mache but there are bad sounding papier mache
Western electric some of the horns are in wood, some metal
Some prefer the WE 16a to the wooden 15a, some the other way.
Yes papier mache WE was used to outsource and increase production, but it was great and JC strongly recommended it.
All I am saying is that these various materials have their own colors, and it is the final voicing.. The designer has to balance the voicing with horn material, driver, and crossover.
Leif's wood is a different design now, they are trying a constant directivity design great if it works because then doesn't need a tweeter. Two way. The TAD clones are also CD and wood but they preferred the autotech jmlc to that. So again, it is a combination and execution
This isn’t correct. Did Leif have a wood JMLC - no. So you are conflating two independent concepts - one being geometry (very critical) and other being substrate (very critical).
Two-Way without compromise would be awesome.Leif's wood is a different design now, they are trying a constant directivity design great if it works because then doesn't need a tweeter. Two way.
What about the Uni JMLC?There is no plastic horn that I have heard that doesn’t sound of plastic.
I pointed out when you said Leif is going back to wood, he is going to a different geometry. They tried 76 cm wooden iwata. And TAD clones they have experience with. They ended up with autotech.
My point is this is all a combination. It is unfair to put down universum or pnoe as inferior, based on not being wood. They are brilliant horns.
You are misquoting and ignoring plain facts to suit your arguments.
>> You can’t compare across geometries like this. This is wrong!! You can compare a Plastic Iwata with a wood one or a wood jmlc like Sierra and a plastic one. That is fine. Don’t conflate.
>> In terms of Pnoe and Universum - the words I used was “good if not great” - so again don’t misquote me please Kedar. It isn’t cool or good manners. What I said which you can’t seem to understand it that plastic isn’t a good choice in any situation other than CHEAP and rapid production.
The problem is that the dual woofer FLH with bass horns would have to play up to 350hz to cross over to the Uni's mid JMLC hornTbh uni has one of the best mids and highs I know, I wouldn't change it one bit, to make an even better horn, add a dual woofer FLH with bass horns.
