Apparently Bill got over his stated aversion to plastic horns with their plastic coloration. That makes me feel better about my Oris150 horns.
What driver is in your 150s? AER BD 3?Apparently Bill got over his stated aversion to plastic horns with their plastic coloration. That makes me feel better about my Oris150 horns.
That’ll be due to the Pnoe being manufactured out of high density fibreglassApparently Bill got over his stated aversion to plastic horns with their plastic coloration. That makes me feel better about my Oris150 horns.
like my sailing boatThat’ll be due to the Pnoe being manufactured out of high density fibreglass![]()
In principlelike my sailing boat![]()
Yes, because he pays to advertise here.Does the other guy get to stay??
How is your post relevant to the thread topic ! I would recommend that you start your own project thread … As to your assertion regarding a simple stave and plank conical wave guide construction being the apogee of horn design might you enlighten us further.Update on my horns:
I also agree with Weiss at OMA () that only conical horns add no distortion to the sound and have the widest sweet spot.
Time alignment is also critical - most of these large horn projects are not time aligned.You can certainly have a great and fun sound from non time-aligned drivers; but with multiple horns the affects are usually greater than with conventional drivers (eg, Magico).
Because I had discussed my horns with Bill on this thread. Actually, you had asked for more information here?!How is your post relevant to the thread topic ! I would recommend that you start your own project thread … As to your assertion regarding a simple stave and plank conical wave guide construction being the apogee of horn design might you enlighten us further.
As have I fella … As have I !Because I had discussed my horns with Bill.
no I don´tDo you know what is the material being used in current Avantgarde horns?
Bill was speaking in most positive terms about your new upper range horns, I hope that we might hear a few audio vids of your newly modified horn arrayno I don´t
but my latest top horns are CNC´d in waterproof MDF and all abs/plastic horns are out of my system
abs plastic last info i know.abs also has a problem uv light must be painted very well.Do you know what is the material being used in current Avantgarde horns?
