Hi
Listening to John Eliott Gardiner's with the MOnteverdi Choir, on original instruments. Digital on CD and doesn't need any ap;ogy. great sound, great work, greta Music. Likely multi miked but hardly intrusive... Ambiance is well captured and the entire oeuvre breathes. Serious, good, big .. somewhat, interestingly Bach-like but definitely Beethoven... haven't heard it for a while but Bach to it (pun intended). Highly recommended
View attachment 31662...
don't know why the yuuuge picture
.. Solved![]()
Two unexpectedly nice acquisitions of mine in the last fortnight. The first is a very nice performance and recording of the two Chopin concertos. I'm certainly no piano performance expert but I really like the performance and the string playing is superlative. Every one of those string players could be a soloist in their own right (and the liner notes say they were all specially recruited and all had to individually audition). The recording is actually extremely good by outright standards, let alone the fact that it is a 1999 digital one. The LP was cut (so I understand) from DG's 24/44.1 master (which in reality is more like a 21 bit recording in a 24 bit envelope). The only real caveat is that the low end is rather bloomy and it will certainly test the bass clarity and control of your system and your listening room acoustics and damping, lest it sound overly warm and cuddly. I did some further research into DG's "4D" recording since I well remember it first appearing in the early 90s. There is a really good run down of it here (and the actual LP I bought pictured below).
http://www.gammaelectronics.xyz/s_1993-DG-4D.html
And now for one I almost missed altogether. Mainly because Acoustic Sounds decided to file this one under their Jazz section as opposed to the classical one. Well, I suppose you could argue for it both ways but for my money I've always regarded these Jazz Suite pieces as parody-like vignettes of the pre-war "cafe jazz" era as envisaged (in only the way Shostakovich can) for a small classical orchestral ensemble. Of course the piano and trumpet concerto sandwiched between the two jazz suites is more typical of Shostakovich's output but even it has somewhat of a jazzy "vibe" at times. Of course, you could just buy this LP for the awesome cover like I did
Sonically this won't necessarily blow anyone's socks off. I am not sure of the quality of the digital sources but it is a Decca digital recording from the early 90s. I'm not sure whether back then Decca were still using their bespoke 18 bit, 48 Khz system or whether they had moved to subcontractors "doing what they like" so to speak. But the engineer, Simon Eadon, was Decca trained through and through and the recording, though a little dry sounding and possessing some digital "edge" and brittleness at times, still does sound better than the previous CD issues (though that could come down to Sean Magee's remastering - Magee now having earned an extremely solid reputation for cutting classical LP releases for Universal). Put it this way - I've enjoyed this LP so much I've already played it three times in the first week and that says something for a regular classical record buyer!
Original Issue recently acquired. One of the crown jewel's of my original issue mercury living presence collection.
I also think the Jazz album is excellent. I've never really cottoned up to Shostakovich's symphonic works since it all basically sound like Russian military music circa 1930 although there are some exceptions. But the Jazz album is wonderful. Even better however is the companion album, the "Dance" album. Check it out.
Awesome Christian. Although I have had to "settle" for the Speakers Corner reissues, I treasure mine nonetheless. I think the combination of Starker and Mercury put a whole new meaning to the term "legendary". He is by far my favourite cellist. And actually the first original Mercury LP I ever heard was SR90303 - his performance of the Dvorak concerto.
That is a collectors item!Janos Starker recorded Bach's Cello Suites five times, two of which are available on CD. The first in 1965 for Mercury Living Presence, was a triumph. He set his reputation for technical perfection, sensitive phrasing and a supreme expressive intensity. Some, however, regard the transfer to CD as less than perfect.
Beautiful, truly gorgeous violin tone!
I got the 24/96 files from here:
https://www.highdeftapetransfers.com/products/dvorak-violin-concerto-peinemann-violin-ravel-tzigane
From a DG tape.
cheers,
alex
Mind you, I'm the furthest thing from an expert in classical music, so I'm sure there are better performances out there that I've overlooked...
