The biggest problem with understanding what resolution sounds like is in understanding the difference between what you can hear consciously and what your brain is actually capable of detecting and processing subconsciously.
Your two ears are approximately 30-35cm apart. Our ability to detect the source of a sound is based on that difference…..on the changes in amplitude, timing and phase between the soundwaves from a sound source impinging on one ear vs. the other. Your brain is able to pick up and process those miniscule differences with a high degree of resolution….(the higher the resolution, the smaller the differences that are detectable). Our entire ability to discriminate direction is based on these minute differentials. Those differences are far, far smaller than our conscious brain is able to detect. That’s because what we are able to discriminate consciously is far, far lower in resolution. High resolution hearing is automatic and subconscious. What we actually hear is a result of the processed differential signals, not the signals themselves. Remember that soundstage for example is not contained in the actual signals, its contained in the differentials between the signals.
When we turn up the volume, we seem to hear more detail, so we conclude that we have increased the resolution….but we haven’t! The resolution at high or low volume is identical. What we have done is to increase the volume of all sounds, lifting the quietest ones above the threshold of hearing. That threshold is fundamentally the quietest sound the ear can detect, plus any ambient, recorded and processing noise. Because increasing volume increases both the loudest and quietest parts of the music equally, the actual resolution remains the same. To increase resolution, we need to find ways of removing noise….the ambient noise in our listening room, the recorded noise and the noise associated with all the electronics, stray emi and the network used to produce the sound. When you add detail without increasing amplitude you’ve essentially increased resolution.
The other problem with understanding resolution is the fact that in hi-fi there are multiple areas where different resolutions play a roll. Amplitude, frequency, time, and phase resolution all have an effect on what we consciously hear as does the various combinations of those changes.
Increasing resolution should make any music sound more natural because in essence we are removing distortions and noise and revealing more of the subtle differences that together make up the fine structure and strands of the music.
