What is currently the best analog to digital (A/D) converter?
VPN
238
74
258
There are, of course, many uses for A/D converters, such as: (i) Ripping your precious Vinyl, (ii) Ripping your precious analog tapes, (iii) Professional recording, and (iv) DSP measurement test gear. In most cases one would probably like to use the absolute best A/D converter, supposing the analog rig is top quality too.
What do you think is currently the best sounding analog to digital converter?
Some candidates (updated):
- Merging Horus/Hapi
- Grimm Audio AD1
- MSB Platinum Studio (PCM)
- Forssell MADA-2 (PCM)
- Ayre QA 9 Pro
- Prism ADA-8XR
- Lavry AD122-96 MX or AD10
- EMM Labs ADC8 MK IV
- Prism Orpheus
- Lynx Aurora 8
- Lynx HILO
- Metric Halo
- Apogee Symphony
- Antelope Audio Eclipse 384
- Weiss ADC2
Thanks in advance for your views regarding those that you have actually heard and compared.
Bruce B
Apr 26, 2010
6,931
373
1,210
Snohomish, WA
www.pugetsoundstudios.com
Merging Horus/Hapi is currently the best I've heard, followed closely by the Grimm AD1
Weiss ADC2 - alright.... nothing to write home about
MSB Platinum Studio - best PCM I've heard
Digital Audio Denmark AX32 - same as Merging Horus/Hapi
Prism ADA-8XR - Great all around converter. Doesn't do anything bad
Forssell MADA-2 - second best PCM converter I've heard
Burl ADC - Have not heard
AVID/Digidesign HD I/O - forget about it.
Lynx HILO - great bang for the buck.
Metric Halo - not bad...
jfrech
1,970
478
405
Austin
Don't forget the Nagra's. Nagra Seven and VI...Nagra has a few portable ones also
Bruce B
Apr 26, 2010
6,931
373
1,210
Snohomish, WA
Nagra does not make a dedicated A/D converter. It also includes the mic pre's, and hard drive. If you want to include the all-in-one devices, I'd suggest the following also.
Korg MR2000s
Korg MR2
Tascam DA-3000
Tascam DV-RA1000HD
IZ Technology Radar 6
Sound Devices
Genex AD8 and GX9000/9024
VPN
238
74
258
Bruce,
Thank you! You are certainly an expert.
Have you, by any chance, heard the Ayre QA 9 Pro, EMM Labs ADC8 MK IV, or Lavry?
Bruce B
Apr 26, 2010
6,931
373
1,210
Snohomish, WA
Bruce,
As you can see by the below pic, I have/had these converters in my system. The Lavry I had a few years back.
The Ayre QA9 Pro is not really good. It worked poorly and when it did, I did not like the sound. I still have the EMM Labs converter and it was the converter I used (and the Wilson's chose) for all the Wilson Audiophile transfers. As for the Lavry, it was the best PCM converter I've used until I tried the MSB Platinum Studio. I feel the Horus/Hapi is the equal or better. I'd have to use them side by side to tell.
VPN
238
74
258
Mighty impressive stack!
If you feel the MSB Platinum is the best PCM A/D (equalled by Horus/Hapi), I suppose you feel the Merging Horus/Hapi, followed closely by Grimm AD1, are the best for DSD?
Bruce B
Apr 26, 2010
6,931
373
1,210
Snohomish, WA
If you feel the MSB Platinum is the best PCM A/D, I suppose you feel the Merging Horus/Hapi, followed closely by Grimm AD1, are the best for DSD?
Correct.... You can read all about it HERE
jfrech
1,970
478
405
Austin
Korg MR2000s
Korg MR2
Tascam DA-3000
Tascam DV-RA1000HD
Bruce, are you sure here? The Nagra Seven can take a line input from your pre or phono stage...http://www.nagraaudio.com/nagra-seven/
Bruce B
Apr 26, 2010
6,931
373
1,210
Snohomish, WA
dallasjustice
2,067
7
Dallas, Texas
There are, of course, many uses for A/D converters, such as: (i) Ripping your precious Vinyl, (ii) Ripping your precious analog tapes, and (iii) Professional recording. In most cases one would probably like to use the absolute best A/D converter, supposing the analog rig is top quality too.
Add DSP measurement test gear to that list. I have a Hilo. It's great. I hope to get some Merging gear soon. I will wait until after CES to decide what's next. The Merging gear is really cool partly because of the Ravenna ASIO ethernet. I can't wait to get rid of USB, FOREVER!
astrotoy
1,477
918
1,185
SF Bay Area
I like my Pacific Microsonics Model Two. Software is important too, I use Pyramix, Mykerinos Card and Izotope RX3 Advanced.
Larry
Reactions: Amir
Loheswaran
424
91
258
I have had the pleasure of hearing DAC's from:
DCS - Elgar and Pulsar - don't know the current range - very high res and clean sounding - impressive
Burmester - god knows which model - very luxurious, solid, and effortless
Chord - very neutral and solid
I also recently heard the CAD (Computer Audio Design) and was utterly blown away by it's finesse, flow, neutrality - it was like very good vinyl just cleaner - IMHO I never knew that digital could sound that good - it's one of those products that truly stand out and has me finding a way to buy one. It doesn't have that 'look at me' sound that defines a lot of modern audio.
VPN
238
74
258
Mike, Are you sure you didn't study both Law and Engineering? Your system changes and work with DSP have been quite impressive!
Loheswaran
424
91
258
empty pot makes the biggest noise - doh;)
awsmone
1,614
511
370
Canberra Australia
My only experience is with the accuphase DG 48
I like it as it interacts at hi res with rest of system via hs link
It does room correction
But I use it for custom equalization of vinyl
It is surprisingly transparent in this mode
I do use it for room measurements but not room correction now with DEQX HDP 5 s x2
Sorry no experience of others but always wondered about the Grimm ad
Anyone else experience with the " CAD"
