I will do it later. I will look for examples in the Gregorio Paniagua La Folia from Harmonia Mundi to illustrate it.
Could you please give an example based on a recording that we all probably own what constitutes "fine micro detail?" I would like to know exactly what you mean by this and an example of what "fine micro detail" sounds like.
Thanks. And no, I'm not looking to set you up. I honestly want to know what you mean by this and have you give a concrete example that I can relate to.
Hmm perhaps a wrong/confusing choice of words on my end. Not really sure how I can otherwise describe it. Maybe a picture is worth a thousand words.
I guess I would call that focus. I would think that fine micro detail would be the ability to hear some low-level information in a recording that ordinarily gets glossed over with lesser gear vice everything being out of focus.
How would you define resolution then?
I thought the discussion was centered on "fine micro detail."
Right, which to me (and most others I suspect) = resolution.
If to you fine detail = focus, then what is your interpretation of the term resolution? (I am also just honestly interested to know what you mean by this).
Look, you are the one that tried to describe "fine micro detail" by posting a picture of a cat that was taken out of focus and the same cat in focus. That is why I said I would call your description of "fine micro detail" focus. It's not my definition of what "fine micro detail" means. I wanted your description of "fine micro detail" and the out of focus and in focus pictures of a cat are what you gave me. I already explained what I thought it might mean, I was hoping for an audio example from you and not two pictures of cats.
I thought my original full-range Apogee ribbons were pretty special....
Lee
Apogee Stages Lee?
It will depend on what people consider a resolving speaker. You can have resolution related to detail, dynamics, localization and nuance. Sometimes a loudspeaker which excels in one of these aspects is not the best in the others.
Micro, could you expand on your interpretation of resolution? What I had in mind was the ability to resolve fine micro detail across the spectrum.
Thanks for taking the time to put that together, I will look up the music suggested.
To me the image analogy works, but then I may be on a different page to everyone else. Hopefully the listening examples will help to further clarify.
