What's best in highly sensitive/efficient speakers.
Looks like Odeon is showing a new model at Munich 2019.
Reactions: jeff1225
That’s very interesting, Brad! Do you think you would trade up for these?
Hard to say, I would need to hear them side by side in my room probably or at least with my AC gear to get a clear idea. I think I would keep the ones I have over the No. 33 or 38 though.
What the hell is the salad bowel doing on the bass driver?
Given that this driver is producing sound well into the mids (probably up to 400hz or so) it is probably having some positive effect. Maybe it is harmonizing the sound character between bass and mid and drivers are blending better this way? It sounded very good.
It would need to be 8.25" to affect 400hz as a horn, and isn't going to provide any extra sensitivity. It's maybe half as big as it would need to be (8.25"), and according to their site with 15" bass drivers they cross more like 200-300hz area. Their models on website don't have the salad bowl.
I think it's just for (funny) looks.
Reactions: christoph
Would it not be marginally acting as a mini waveguide to improve directionality.
This was sounding good, much better than the other Odeons I have heard. I think they incorporated some of the wood tone from the 120k model two years ago, and possibly better integration (Tough to say from a show demo) than the ones you might find in the used market. I have a couple of videos I will share later
Or just to look like a horn? ;)
Like Avantgarde likes to do as well.
They keep calling "horns" in the bass that are never ever horn loaded (not even wave guided) for the frequencies that they reproduce :rolleyes:
Funny.
Normally I concur mostly with Brad and Ked but this time my friends (M and D) and I found this Odeon not to Sound very good.
I have to admit though, that we didn't stay very long in that room because all 3 of us didn't like the Sound too much :oops:
We know the Odeon Sound very good as M and I own(ed) the the No. 32 and No. 38/2 and the model on demo just didn't grab us.
We even joked that they would have better hooked up the little 28/3 they had on silent display on the side ;)
Funny.
Yes funny indeed. What didn't you like? I went there three different times and found it quite good and I took an AC owner up there who also thought it was outstanding.
Their website doesn't have this model because it is a new model. If you look at the top model on the website (no. 38/2) you will see the midrange horn is quite a bit larger than it is on this model at the show, which has about the same size midrange horn as the 28/3 model. This means that the bass on the new model will be going up higher in frequency and I think to get the blend better between the mid and the bass they added the short horn, wave guide or whatever you want to call it. This will likely enhance the output of the driver in the range they needed for the crossover, based on the overall size of the horn around the bass.
So I was right. They have done some mods to improve coherence, which my big no no with the previous models, plus the wood like tone
Well, it is an analysis on my part, I did not talk directly to Axel to get the "true" explanation...guess I should have...
Reactions: bonzo75
The horn is not for the bass in this case...it is for higher frequencies (the size on the woofer is probably not too different overall than the mid horn on the 38/2). Since the mid horn on this speaker looks to be about 28/3 sized, then you probably need that short horn on the woofer to get a better matchup since it doesn't go as low as the 38/2 mid horn. Avantgardes short horn bass might be doing something similar to give a better match to their mid horn but this is just speculation.
Interesting....
When I demoed the 28/3 model I found it to be very coherent. And, this was literally minutes after hearing a single-driver speaker in the same system. I listened for a disconnect between the cone bass and the horns above but nothing stood out.
The mid horn on the 28/3 (and the 33 and 38) look more substantial in terms of thickness and weight than the horns on the new model.
Funny.
Does anyone know what electronics they were they using here?
