What's best in highly sensitive/efficient speakers.
morricab
9,483
5,042
1,228
Switzerland
Interesting....
When I demoed the 28/3 model I found it to be very coherent. And, this was literally minutes after hearing a single-driver speaker in the same system. I listened for a disconnect between the cone bass and the horns above but nothing stood out.
Maybe a 10 inch woofer is able to play up higher with better dispersion.
morricab
9,483
5,042
1,228
Switzerland
Does anyone know what electronics they were they using here?
I think it is a Russian company called NEM.
Exlibris
588
429
198
Canada
systems.audiogon.com
bonzo75
22,620
13,639
2,710
London
It was disappointing to read the reviews of the system featuring the Animas at the T.H.E. Show 2019 in June. It makes me hesitant to make travel plans to go and hear these.
I like the speakers and have heard them sound good only once at Munich in 4 years (Two other years they had the Avaton). That does not mean you will like them if you travel all these horns have a different sound and whether the wavac 300b works with it is not clear.
Reactions: KeithR
Exlibris
588
429
198
Canada
When I read this I think "what are the chances that these will sound good in my room with my amp?". It seems like a real crapshoot with these speakers whereas other speakers generally get good to glowing reviews from show to show and person to person.
morricab
9,483
5,042
1,228
Switzerland
I say give them a shot.
bonzo75
22,620
13,639
2,710
London
They won't sound good with the Mayer.
That said nothing sounds good show to show. If anyone uses shows to judge they will stumble on the right component only by luck or because they already have a bit of the system background at the show
morricab
9,483
5,042
1,228
Switzerland
How can you say this with any certainty? An amp of that power is MADE for speakers like the Animas, which are like 109db/watt. If not that then what are they for?
bonzo75
22,620
13,639
2,710
London
I know. :)
But to my earlier point -- I could go and like them and buy them but then find that they really sound bad in my room with my amp. I know that's true of many speakers but these seem to be hyper room and amp sensitive.
The 45 is a very low watt amp. I think the Anima requires more power and drive especially for the bass, which is probably why the wavac didn't work. Usually the sensitivity readings are only for mids or so.
If anyone wants the duo, thus horns symphonia is a better speaker imo. This retails at only 15k euro.
Nice little montage:
morricab
9,483
5,042
1,228
Switzerland
I know. :)
This can be said about most large speaker systems
Reactions: bonzo75
morricab
9,483
5,042
1,228
Switzerland
Yes, the hope of being able to keep my amp is the only thing stopping me from just ordering the Odeon 33s.
Yeah...not gonna work with the 33s...
