I'd have to agree with that!Hi Bill
I don't know if you ultimately want to use your deck as playback only so...
About a year before I heard of the Tape Project I had my Technics !500 internally modified on the output path only. Premium caps, resistors, solid silver wire and WBT Next Gen silver output connectors with the work done at the Parts Connexion. Sound wise it was hard to believe that it was the same machine.
After the upgrade I took the deck elsewhere for a tune up. The tech swore he never heard such deep bass from his test tape. Though now the deck is used as a transport only it still has capability to playback through my tube Repro or to be reconfigured for solid state internal playback. So you can have your cake and eat it to!
I have been using a RS 1700 since @ 1980 and have never seen it or the 1500 ruin a tape. Speed stability is such that you can hear tape stretching on some of the used reels I have bought.
As for owners of the Technics decks if you still have the original 10 cent output jacks UPGRADE!!!
For tapes in good condition and no splices the Technics path is fine. But 30+ year old studio masters with splices and paper leader are a different story altogether. The small radius turns on the tension guides will help peel off a weak splice, where on a PR99 type path it would go through with no problem -- a few times. Also a tape that sheds slightly will build up quite a bit of residue on the Technics (at least, mine) whereas it is minimal on a straighter path. Not a show stopper, just something you have to be wary of when working with certain tapes.
Have you compared the sonics of the audio path internal update to the external Repro? If so, how did they compare?
I'd have one machine optimized for playback, probably with an external preamp, and another just for recording.
--Bill
