A lot of Dealers don t wanna hassle with / aftersales of tubegear .
A lot of audiophiles are not keen on changing tubes either .
Why not state Solid state is better , problem solved.
Ps . In the year or so i owned the ARC pre i never changed a tube , it operated flawless
To me, it’s like the difference between buying TV dinners from a supermarket vs. making your own food. The latter involves work: you need to buy groceries, stock your kitchen, learn how to cook safely, and most importantly, enjoy cooking. As the saying goes, if you can’t take the heat, stay out of the kitchen. But if you do learn to cook well, you can enjoy far better and healthier food and it costs far less than eating out everyday. Not to mention orders of magnitude tastier than TV dinners. But TV dinners are easy. Stick it in micro. This same analogy holds true in high end audio.
If you can’t do something as elementary as changing tubes, you certainly shouldn’t own tube gear. In fact, you should probably not own high end audio. In my experience a lot of solid state gear is even harder to set up than replacing tubes. If you have owned dCS digital, you know of what I speak. Get one of those all in one streaming speakers. I have a Devialet Phantom for causal background listening. No fuss, no muss, plug into the wall and stream to it from your phone. Only one problem: it sounds like crap. So does most solid state gear to my ears, except for a very small percentage of high end audio gear. Even at this rarefied top end, nothing touches the sound you get from tubes, in my 30+ years of owning almost every major brand of solid state high end audio gear. Classe’, Krell,, Mark Levinson, Chord, Bryston, Esoteric, dCS etc. — I’ve owned solid state preamps, amps and DACs from all these venerable firms. And they all fall far short of the musicality of tubes.
So, I compromise. I run multiple systems. My reference system is all tube. ARC Ref 6SE line stage preamp, ARC Ref Phono 3SE phono preamp, Lampizator Pacific DAC, Triode Labs 45 SET monoblocks and Klipsch La Scala horns. One watt of glorious SET power is all I need to play music as loudly as I need to, delivered using a single Telefunken 12AX7 smooth plate triode with an Emissions Lab 45 power tube and a Western Electric 422a rectifier. This system gives me goosebumps every time I listen to it.
In my second system, it’s all solid state. Currently it’s using Mola Mola electronics, the Makua all-in-one preamp (DAC, phono, linestage) and Kaluga monoblock class D amps. Wonderfully musical for solid state. But as brilliant as Brian Putzey’s designs are, and they are truly state of the art, for my listening pleasure, it doesn’t begin to approach the quality of my all tube system. It’s nice to configure the Makua through its iPhone app, and its phono stage and DAC are truly world class, but there’s a level of three dimensionality I get from my main tube based system that completely escapes the Mola Mola gear, as good as it is.
Yup, it’s a drag to own tube gear and have to change tubes. Especially quality tubes are pricey. But just as I’d never settle for a TV dinner and prefer a nice home cooked meal, I’d rather own tubes and put up with the hassles.
My $0.02. Of course, I can’t speak for anyone else.
