That's a decimated response![]()
Ron posts videos of his system for his own amusement and thanks people when they respond. Bonzo posts for his own amusement and continues to post when others respond.
We should start a new thread, Owe Why do I post?Ron posts videos of his system for his own amusement and thanks people when they respond. Bonzo posts for his own amusement and continues to post when others respond.
Could this also be the problem with the recording process ADC>DAW? I have recently discovered I like some live stream recordings on YouTube but not the released digital album.Because of the memory retention problem, one can never fully enjoy listening to an entire album via streaming as subsequent tracks after the 1st track selected (not necessarily the first track on that album) to be played will always sound less opened, dynamically restrained, and less satisfying musically.
But if one creates a playlist of that album and insert something else from another album in between all the tracks of that original album, then the album will sound more consistent from beginning to end. The problem is you need that something else to be a silent track and it has to be as short as possible in order to minimise the disruption to the musical flow. And that "bridging" track has to be the same format and resolution as all the tracks from the original album, or otherwise the DAC will react adversely and subsequently exhibit some sonic anomalies. (Because of this different and separate issue, one should never directly compare 2 tracks of different resolution immediately one after the other. Always use a "bridging" track of similar resolution to the 2nd track to "climatise" the DAC)
Such as the last one you posted (Grace Kelly) and which are in fact strictly identical?Could this also be the problem with the recording process ADC>DAW? I have recently discovered I like some live stream recordings on YouTube but not the released digital album.
@jeromelang, have you ever run your observation/theory by a DAC designer (like Andreas Koch of your Playback Designs) to see if they confirm technically what you’re saying?Because of the memory retention problem, one can never fully enjoy listening to an entire album via streaming as subsequent tracks after the 1st track selected (not necessarily the first track on that album) to be played will always sound less opened, dynamically restrained, and less satisfying musically.
Even if a certain DAC designer did confirm this, it could simply be indicative that that specific DAC has an issue. But to be honest, I don't even understand what problem he is trying to fix!@jeromelang, have you ever run your observation/theory by a DAC designer (like Andreas Koch of your Playback Designs) to see if they confirm technically what you’re saying?
My phone keeps bringing me back to this. So I keep seeing it and thinking, what is Peter saying? What are you saying. I missed the underlying meaning.Ron posts videos of his system for his own amusement and thanks people when they respond. Bonzo posts for his own amusement and continues to post when others respond.
Are you really lacking that bit of self confidence in your own listening abilities that you need a person of high repute to tell you what hear is or isn't true?
You can always set up your own listening tests.
Start by making a playlist of track from a particular artiste whose music you are highly familiar with. Arrange the playlist so that tracks alternate from different albums. However make sure they are all of the same bitrates and sampling rates.
Compare what you hear against playing an album of the same artiste from beginning to end in their original sequential order.
Listen out for 2 aspects of sound reproduction:
(1) soundstage and imaging
(2) musical flow
I asked if you had any technical backup of your theory from someone with a technical understanding. I guess not, since you chose go to defensive.Are you really lacking that bit of self confidence in your own listening abilities that you need a person of high repute to tell you what hear is or isn't true?
(2) musical flow
I asked if you had any technical backup up of your theory from someone with a technical understanding. I guess not, since you chose go to defensive.
I’ve never heard anything remotely like what you’re describing. And I mostly play albums beginning to end.
But I’m open to to hearing discussion about this from people with more technical understanding than me.
Until then, I’ll pass on the tortured listening test!
Hey, this is a forum. Its all true until you disprove rhe claimNever heard anything like it either. Literally unbelievable. Extraordinary claims require extraordinary evidence.
Hey, this is a forum. Its all true until you disprove rhe claim![]()
It is interesting when someone makes a claim or states a theory and then someone else comes along and says "Prove It", without offering any reason other than their scepticism. Then, when the person making the claim offers guidance/instructions for the sceptic to fish for himself, he is then called out for being defensive. If sceptics are truly interested in the claim or theory they should be willing to put in some equity of their own, otherwise they're just keyboarding at the claimant's feet for the amusement of seeing him dance to their demand.
I don't hear any difference. You seem to make it a point not to reply to my questions, but I'll try again - what differences do you hear?It all comes down to recording quality as has been said many times..
Here is a live stream studio recording of the track 'Swingin' (starts 3.13) which was released later on CD (below):
What do folks think of the difference in sound?
More often than not, an instance of bad faith in discussion that is referred to Sealioning.It is interesting when someone makes a claim or states a theory and then someone else comes along and says "Prove It", without offering any reason other than their scepticism.
![]() | Steve Williams Site Founder | Site Owner | Administrator | ![]() | Ron Resnick Site Co-Owner | Administrator | ![]() | Julian (The Fixer) Website Build | Marketing Managersing |
