Sorry, was reading old stereophile measurements but that may be incorrect. I thought with the SS input stage, it might be more 3rd harmonic in general and hence less "warmth."
I heard the LM Audio 501 (KT120 p/p), the huge 219 845 SET (which I believe you've heard), as well as Audion Black Shadows (w/ 845B tubes) yesterday at length. The first two were on my speakers (Devore Gibbon X), the latter on the Zu Definitions (my former speakers).
The SETs have a holography that is clearly unique, and for the first 30 minutes is pretty intimidating - but after that, I close my eyes and feel like I'm swimming in it which I find very distracting. I found the LM gear fairly soft and sluggish - particularly on electronica like Trentemoller. I guess if vocals are your thing, maybe its a great personality match, but on jazzy electronica it felt slow and on classical, not particularly dynamic. Bass was bigger on the 501 of course, but it wasn't particularly tight either. The 219 was a better sounding amp in general (and more expensive) and I felt more detailed with instruments that were far more 3D in space. I clearly thought like I was missing information on the 501 - but thats only a $4450 amp. I have heard Shindo gear on the Devores before at the same dealer and came away much more impressed than either amp. Of course, Shindo gear costs double as well.
Meters on the 219 were mostly loafing between 5-10 watts with 20-25 watt peaks, so probably some compression going on as well. The Devores are 92db into a very flat 8 ohms, so an easy load.
Re: the Audions, it was a pretty midrange focused sound with a slightly rolled off treble and fast bass. Sounded quite nice on some older 50s/60s/70s recordings and more vivid/dynamic than the LM gear (Zus are also much more efficient). But it definitely has a "sound" if you know what I mean and had some of the same distractions I experienced all day.
