ying and yang--Lamm ML3 and darTZeel 458
Hi adyc,
I am making switch from ss to SET. Very curious what SET you were using that led you back to ss again? If so what was the driving factor behind this decision?
Cheers
IMHO you should try the EA 50ohm BNC cables with a BNC T , a 50 ohm terminator and an RCA BNC adapter . It will emulate your 458 input at the Lamm RCA, using the best mode of the NH18. See http://www.whatsbestforum.com/showthread.php?691-Which-amp-or-amps-are-darTZeel-owners-using-with-their-NHB-18NS-preamp&p=59796&viewfull=1#post59796 . I will post a photo of my adapters later today.
If it hums still with all sources disconnected then there is either a transformer mechanically humming or there is something wrong with grounding or wiht the internal circuitry. I have rarely found an electrical hum or buzz continue when the amp is not hooked up to anything other than the speakers. Mechanical hum happens regardless...if it happens at all...
not interested in integrating 4 more boxes into my system. that is my viewpoint right here, right now. I've learned never to say never.
I know you are trying to help and appreciate your speaking up. you joined a chorus of LL1.1 recommenders.....all well intended.
resistance is feudal. I see myself running two parallel preamp/amp combo's down the road....Slamma Lamma pre and amps and of course my Pass SS XS pre and amps...;) That seems to be the best way to go if you are to maintain two different pre/amp topologies.
Im not nescesarily talking about hum in the sense of noise coming through the tweeter , but transformer hum which is a kinda 50 HZ ( or 60 Hz ) moving of the windings in the transformer .
The higher the output in the ( SE )tube power amp the bigger transformers the more noise, it doesnt become louder with increase in volume .
The Zanden 7000 integrated 300 B set didnt have much transformer hum , small wattage small transformers .
The Lamm probably not much at around 30 watts .
Mechanical hum is related to the quality of the transformers, mains quality and sometimes to mechanical resonances in the mounting of the transformer or amplifier box.
US electronics coming to Europe suffer a lot more from than those working in 60 countries - at 50 Hz transformer flux and and losses are higher, resulting in higher temperatures and dilation of transformers. Most US manufacturers do not test their electronics at 50 Hz, they do it at 230V 60Hz.
BTW, the Lamm ML1.2R are exemplary in this aspect - the most mechanical noise free amplifiers I have owned.
Besides that there is the tube noise / hum which increases with volume coming through the tweeter
My Cat hums the Graaf GM 200 more so , although not SET , transformer hum mostly .
We can have two kinds of electrical hum - cause by the input, drive or output stage, that does not depend on volume setting, and that created by input stages before volume or signal grounds - that depend on volume setting. SE are particularly sensitive to any ripple in the power supply, as they do not benefit from differential cancellation. Unbalance in the output stages of push pull amplifiers can create electrical hum. All in general , I can not cover all design variations!
BTW, we listen mostly to harmonics noise - they are much nastier than the 50 or 60 Hz fundamental.
What kind of noise are we talking about here Mike, I have the same amps on 105db horns and their dead quiet. There's no tube rush with the ML3s do you have a ground loop?
david
I also have zero noise from my ML3 and have heard David's and there is none also.
+1
Mike, simply, it is the price of admission...great design, from a great brain, and many, many boxes :).
Cheers,
ALF
No worries Steve; Mike, with David’s help will figure it all out...David is mental about grounding; he is one well-grounded!
Cheers!
Alan
Imo the best path is as rockitnan suggests and that is with a Lamm preamp
even if you are only getting 90% of the Lamm ML3 performance magic ? There is no doubt that the ML3's will reach their peak performance/sound with the matching Lamm pre...This is a fact you cannot deny. Given you spent the big doe $$$$ on possibly the best tube amps on the planet, it seems counterproductive to hobble them with a SS preamp from another manufacturer. ;)
I totally agree
Mike...you matched your Dart amps with the Dart pre as that was the best combination. How can you deny that the best Lamm performance is obtained in any way other than with the matching Lamm Signature preamp
OT: Hey ALF..what's next after the ML3's if you feel like sharing ?
Hi Christian, many congrats on the American Sound and your upcoming new listening room!
It is coming together, it’s close, I will post it up in a short time...thanks for asking.
Cheers!
ALF
I sometimes use a set of mono tube amps, and I prefer them with a good solid state preamp, even over their matching tube preamp. It speeds them up a bit. I am sure the Dart pre is fantastic with the ML3's.
I'm sure the Dart will do quite well. It does not have the synergy case though. Lamm's are not slow/sluggish tube electronics either, in my experience using the Lamm LP1 sig phono.
Cheers!
ALF
Thanks Alf. Looking forward to hearing what you changed too. :D
