You know you're an audio junkie when .................
I read something recently by Sean Olive ,I believe ,which suggested that 4 seconds was the upper limit ,I will try and find the article.
Keith.
So what. I assume it simply supports your view of auditory memory and the value thereof, which many on this forum obviously disagree with.
And how, pray tell, did he determine that four seconds was the threshold?
I look forward to Mr. Olive's observations.
That was my whole point. A cable that has such an effect is a bad cable since it is distorting the signal in some manner. As I said, what comes out of the cable should be identical to what goes into the cable. Of course, that is easier said than done. So, I guess the ideal cable is the one that does the least damage.
Exactly! I was just pointing out there's plenty of cable out there that WILL alter the sound. Some more, some less. But still, they can't be ignored.
alexandre
alexandre
ALL cables have their own sigature there are NO exception there is no such thing as a neutral cable.
I personally reject (like PA's statement that burn in is nonsense) all "absolutist" statements.
But then again, I'm an atheist. :)
Every cable is transparent unless you deliberately engineer it not to be , ie deliberately high capacitance.
Keith.
provocative statement.
I wonder if the designers of the gear you sell (Grimm, Weiss, Grand Prix, Cessaro, etc.) would agree with that statement......and wonder if they consider themselves cable agnostics too? and if they made cable design choices based on voicing or related processes and then how you would view that and reconcile the conflict.
hard to imagine that the Cessaro designer thinks that which cables are used inside his speakers essentially don't really matter. i'd guess he has done his listening homework before any cable gets to be included in his design.
I have heard this system with ALL Stealth cables and with ALL Purist Audio Design both top of the line cables both system sounded very good BUT different wich one was better ????? depends on your taste my friend prefered the Purist Audio Design and it was HIS 38k worth of cables.
I suspect it is the opposite. The engineering comes in how to make the cable transparent between the source and sink.
I agree. Absolute statements about audio are absolutely absurd.
Isn't a listening test subjective?
If a cable is "burned in" after a certain amount of use then couldn't that condition be measured scientifically?
Power Cables need to be burn in good for two weeks 24/7, hooked up to a high velocity fan to hear their full potential...:p :D
336 hours of break in? :eek:
I believe in the need for "break in" but ......................
Again, an "absolutist" statement that's impossible to quantify.
And hooked up to a high velocity fan nonetheless.
Woof.
my experience as far as time to 'break in' has had mostly to do with the gauge/size of the cable. my Evolution Acoustics TRSC (triple run speaker cable) and TRPC (triple run power cable) continued to improve for 10 days-2 weeks of continuous time on the Audiodharma Cable Cooker . and the Cable Cooker is much more time effective (and ultimately more performance effective) than music only.
those triple run cables are the heaviest cables I know about. so that is an extreme case.
lighter/smaller gauge wire seems to take quite a bit less time, as short as one or two days for phono cables.
Burn-in: The time it takes for your ears to become accustomed to what your system sounds like.
Warm-up: I'll give you an hour if you kept your components in a cold garage in February and are waiting for them to come up to normal operating temperature.
Hello, Gary. Unless you are being sarcastic, we will have to agree to disagree on that one sir. Perhaps to the untrained listener and perhaps to a certain extent to the trained listener but............
Tom
+1 on the Burn-in.
From the Keithley "Nanotechnology Measurement Handbook" (for those who do not know, I should add Keithley is not an high end manufacturer ...) http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CCIQFjAB&url=http%3A%2F%2Fwww.keithley.com%2Fknowledgecenter%2Fknowledgecenter_pdf%2FNanotechHandbook_1.pdf&ei=I66qVOWWE4TyUsmGgJAD&usg=AFQjCNGN5UhSAo6spUq5pgDO-y5GE5wXLg&sig2=AtVQxyWUZ00UUGouQmJqnA&bvm=bv.82001339,d.d24
I have been using their instruments and manuals for more than three decades.
Woof.
If you just hook up your new power cable to your gear and let it burn-in...with some power cables, it takes 500 hours or more to break-in really good !
I remember driving from Boston to Chicago to pick up my speakers. They were in crates in the back of my pick up truck for two days in February during the return drive. Once I got them un-crated and into the listening room, I noticed that the aluminum baffles were very cold to the touch. They did not warm up to room temperature for at least eight hours. I did not hook up the speakers to run a signal through them for at least twelve hours. I would practice the same caution with electronics.
With my Pass amps, I notice that they sound better after about an hour of warm up. Four hours are even better. I usually take them out of stand by mode an hour or two before listening.
Others may do things differently.
Just for giggles, why don't you and PA give it a try and tell us what you hear. ;)
PS: To make this test relatively simple, put some "critical" interconnects (amp / preamp or source / preamp) in the fridge for a few hours or perhaps some power cords assuming they are detachable. Pull them out for an hour, reinstall, and listen immediately thereafter.
Better yet, replicate the above with your CDP if you have one.
With my Pass amps, I notice that they sound better after about an hour of warm up. I usually take them out of stand by mode an hour or two before listening.
Same here with my Pass amp.
And recommended by the "man" himself.
