(...) As a hobby I work on some of the more intractable aspects of audio reproduction such as: why does every piece of electronics gear have a different sound? (...)
Rene
Welcome Rene. You have just landed in the proper forum!
Rene
I guess it's time to stick my neck out! I've been dancing around this topic for years, ever since Sony threw down the DSD gauntlet against the DVDA consortium. Actually since the original shootout between analog tape, DSD and HDCD at Sony Studios in NYC with David Smith.
From what I've read back then, DSD won. :b
Yes, DSD won the war - but not the battle.
Once Sony saw that DVDA was dead, they withdrew from the marketplace. How gracious of them to take their toys and go home.
A Sony engineer at one of the hifi shows back in the 90's told me that DSD was developed so that payers could be made for less $, needing only 1-bit DACs.
I wish I'd gotten his business card. I wonder if he's still out of work.
-- ...And in comparison, the PCM-1795, which is a Stereo (2-channel) DAC, is roughly only three dollars each (when purchased in fair quantity).
It cost a bit more than than 8 cents, but is was also considered the Rolls of the DAC chips for some time - the Ultra-Analog 20400a. It cascaded two BB PCM63 K in a single die and it was hand trimmed for lower distortion. I have owned several DACs using them and all (Krell KPS25, Audio Synthesis DAX and a PS Audio Ultra Analog) all of them shared a full bodied sound. Later versions of these units had 24 bit DACs that sounded more detailed, but less powerful.
Do you have experience with it? Do you think it can be considered NOS?
One of my designs was taken from Analog Solutions by Dick Powerswhen the audio division was closed. He started a company called Ultra Analog that manufactured my DAC module under the name DAC D20400. This device was sold to OEMs Wadia, Pacific Microsonics, Mark Levinson and others.
Was it ever verified that 20400a was 2 PCM63? I thought that was a rumor from diyaudio.
Dan Lavry was the creator of that DAC. From his old website
The Karna amplifier power supplies are absurdly overdesigned for a nominal 20 to 30 watt amplifier. The input and driver have completely separated B+ supplies from the output section; by completely isolated I mean separate plate transformers and separate damper-diode rectifier bridges. The only thing the two sections share is a power cord. The damper diodes, in additional to having far quieter switching than solid-state rectifiers (including HEXFREDs), can carry peak currents of 1 amp, which isn't bad at 500 volts.
The input section has shunt regulation powered by current sources with a measured isolation of 120 dB (the Gary Pimm cascoded MOSFET current sources). Same for the driver section, which gives very high isolation between sections.
The output tubes can carry momentary peaks of 300 to 400 mA - 300B's can turn on surprisingly hard, and the amplifier slides between Class A1 and Class A2/AB2 with no visible transition around 15~20 watts. The Class A PP driver section can actually drive the grids of the 300B's 30 volts positive (Class A2) with no visible or audible transition, something I would not have thought possible for a DHT like the 300B.
I've measured full-power output at 500 kHz with no visible distortion on the scope, a test that would demolish many solid-state amplifiers. The slew rate on the grids of the 300Bs was some crazy number well in excess of 1000V/uSec. This was a spooky test; I knew all of the tubes were driving loads that were almost purely reactive at that frequency, yet they handled it pretty well. That's the magic of Class A PP; nearly complete immunity to any load, which is not true of Class AB or SET operation.
The after-RMAF visitors are usually shocked by the sound of the Karna amplifier; there's the delicacy and tonal depth of 45's and 300B's combined with the slam-bang dynamics of a Crown Macro Reference. There's none of the usual mush of most vacuum-tube amps; it's insanely fast compared to most amps, including solid-state. If you can imagine Stax headphone transparency with Klipschorn dynamics and 45/300B tone color that about describes it.
What's odd is that recordings, even "bad" recordings, sound great, but boy, it doesn't forgive poor sources at all. Changes to the source are usually audible before I walk back to the sofa - everything sounds different, there are no sound-alike DACs with this amplifier.
What gives me pause is the new speakers will be far more transparent - and dynamic - than the Ariels. The system will gain nearly 10 dB of headroom and loudspeaker distortion IM distortion will drop several-fold. This will almost certainly result in more demands on the source - maybe by then my friend's DAC project will be done.
Just found the truth in a old review - the 20400A used a BurrBrown 12 bit multiplying DAC (the DAC7541A) coupled to a discrete 8 bit DAC. Thanks for noting it! Surely it must be considered a true NOS!![]()
Its worthy of note here that the clever sauce of this module was in the calibration algorithms to select/trim the resistor values in that discrete DAC. And also that it had an output deglitcher (sample/hold) as CMOS ladder DACs like the 7541 are notoriously glitchy.
