DSD comparison to PCM.
I guess it's time to stick my neck out! I've been dancing around this topic for years, ever since Sony threw down the DSD gauntlet against the DVDA consortium. Actually since the original shootout between analog tape, DSD and HDCD at Sony Studios in NYC with David Smith.
From what I've read back then, DSD won. :b
Hi Rene! Good to see you here! And thanks for the link to the Bruno Putzey correspondence ... such a refreshing change from the usual PR guff from reviewers and vendors.
From a production point of view, it seems like DSD is the SECAM of audio: a useful distribution format, but almost impossible to use in the studio. (Cross-fading SECAM gives bizarre color distortions, which is why PAL was used in the studio, and then converted at the transmitter to SECAM.) The intriguing little trick of converting a tiny section to DXD, editing that, and then converting back to DSD for the edit interval is fascinating. Not a bad method of concealing a momentary change in quality.
I especially like the point of BP mentioning that A -> D -> A comparisons that share a common clock for encoding and decoding are not valid, since DSD has very low latency (transmission delay) while PCM is many times larger, which decorrelates the jitter on each end. Better to play it back and listen to the track recorded on two different formats, and decide from there.
The first time I heard pro-quality DSD at the studio in Boulder I noticed the reverb on the singer sounded quite different than the acoustic instruments - it actually stood out from the sound of the vocalist. I asked, and it turned out that there's no way to do DSD reverb, so it's done in PCM format, and mixed in. EMT plates still exist, I understand, but are getting pretty rare these days.
Nearly all modern recordings originate as high-res PCM, and have been made that way for nearly twenty years. Given that reality, I wonder what quality losses happen when 192/24 PCM is transcoded into 64fs DSD ... compared to leaving 192/24 in its native format. Hard to believe that PCM -> DSD conversion would actually *improve* the quality ... unless the PCM converter at the consumer end is much worse than the equivalent DSD converter.
Yes, DSD won the war - but not the battle.
Once Sony saw that DVDA was dead, they withdrew from the marketplace. How gracious of them to take their toys and go home.
A Sony engineer at one of the hifi shows back in the 90's told me that DSD was developed so that payers could be made for less $, needing only 1-bit DACs.
I wish I'd gotten his business card. I wonder if he's still out of work.
The PCM1795 is a 32-Bit/192kHz Stereo DAC, but way more cheap than the Mono 24-Bit/96kHz PCM1704K DAC.
* My pre/pro (Integra DHC-80.3) has six PCM-1795 DACs, but to me they are inferior sounding to the PCM-1704K (top grade) DAC.
Architecture; you bet! ...Lynn, Rene, Richard?
Yes, the latest price in small quantities for the PCM 1704 is around US $75 each - and those are mono converters, not stereo, so you must buy two (or more, depending on whether you want to parallel or operate differentially). My understanding is the ESS Sabre 9018 is around US $40, and it has 8 channels, which are ganged together to make it a 2-channel converter. Other delta-sigma converters are less - some, much less, with the cheaper ones having voltage-mode output.
The rumors I've heard about the PCM 1704 is that TI has tried several times to discontinue it (thus, the scary note on the spec page), but military and aerospace customers demand a ladder converter with well-defined input/output characteristics. This goes all the way back to the original form of digital, telemetry from missiles.
Well, Sony is famous for a long line of battery-powered consumer gadgets, going right back to the first mass-marketed transistor radio, followed by the (cassette) Walkman, and then the Discman ... which is probably why Sony developed the 1-bit converter in the first place, making the best of the limited power supply. Sony's acquisition of a movie studio at the same time might have had something to do with the mania for copy-protection that characterized the SACD disk format.
Still curious how ESS implements DSD playback in the 9018 converter; in a way, it's the converter's best feature, and certainly sounds different than other delta-sigma converters when fed a DSD source.
-- I forgot to mention: The PCM-1795 Stereo DAC will do both PCM and DSD.
- The PCM-1704 Mono DAC, only PCM.
_______________________
* An easy question for you people: Who built (designed) the ESS DACs?
...And from which country, and town?
-- ...And in comparison, the PCM-1795, which is a Stereo (2-channel) DAC, is roughly only three dollars each (when purchased in fair quantity).
Its a jelly bean digital part, whereas the PCM1704 needs time on the laser trimming machine fixing up all those internal resistors to get the performance specs. Hence $$$.
The DAC chips I'm using cost $0.08 each, recycled out of junked Creative Soundblaster PC cards :p
-- I dunno either Richard; as long that your ears like what they sound like, that is all it truly matters at the end of the audio musical expedition. :b
Analog vs Digital ... PCM vs DSD ./././ and all that jazz.
It cost a bit more than than 8 cents, but is was also considered the Rolls of the DAC chips for some time - the Ultra-Analog 20400a. It cascaded two BB PCM63 K in a single die and it was hand trimmed for lower distortion. I have owned several DACs using them and all (Krell KPS25, Audio Synthesis DAX and a PS Audio Ultra Analog) all of them shared a full bodied sound. Later versions of these units had 24 bit DACs that sounded more detailed, but less powerful.
Do you have experience with it? Do you think it can be considered NOS?
EDIT - the the 20400A used a BurrBrown 12 bit multiplying DAC (the DAC7541A) coupled to a discrete 8 bit DAC, not the PCM63K as I incorrectly wrote.
Was it ever verified that 20400a was 2 PCM63? I thought that was a rumor from diyaudio.
Dan Lavry was the creator of that DAC. From his old website
One of my designs was taken from Analog Solutions by Dick Powerswhen the audio division was closed. He started a company called Ultra Analog that manufactured my DAC module under the name DAC D20400. This device was sold to OEMs Wadia, Pacific Microsonics, Mark Levinson and others.
You are correct - but I also found the rumor spread all over the net! Just found the truth in a old review - the 20400A used a BurrBrown 12 bit multiplying DAC (the DAC7541A) coupled to a discrete 8 bit DAC. Thanks for noting it! Surely it must be considered a true NOS! :)
The Karna amplifier power supplies are absurdly overdesigned for a nominal 20 to 30 watt amplifier. The input and driver have completely separated B+ supplies from the output section; by completely isolated I mean separate plate transformers and separate damper-diode rectifier bridges. The only thing the two sections share is a power cord. The damper diodes, in additional to having far quieter switching than solid-state rectifiers (including HEXFREDs), can carry peak currents of 1 amp, which isn't bad at 500 volts.
The input section has shunt regulation powered by current sources with a measured isolation of 120 dB (the Gary Pimm cascoded MOSFET current sources). Same for the driver section, which gives very high isolation between sections.
The output tubes can carry momentary peaks of 300 to 400 mA - 300B's can turn on surprisingly hard, and the amplifier slides between Class A1 and Class A2/AB2 with no visible transition around 15~20 watts. The Class A PP driver section can actually drive the grids of the 300B's 30 volts positive (Class A2) with no visible or audible transition, something I would not have thought possible for a DHT like the 300B.
I've measured full-power output at 500 kHz with no visible distortion on the scope, a test that would demolish many solid-state amplifiers. The slew rate on the grids of the 300Bs was some crazy number well in excess of 1000V/uSec. This was a spooky test; I knew all of the tubes were driving loads that were almost purely reactive at that frequency, yet they handled it pretty well. That's the magic of Class A PP; nearly complete immunity to any load, which is not true of Class AB or SET operation.
The after-RMAF visitors are usually shocked by the sound of the Karna amplifier; there's the delicacy and tonal depth of 45's and 300B's combined with the slam-bang dynamics of a Crown Macro Reference. There's none of the usual mush of most vacuum-tube amps; it's insanely fast compared to most amps, including solid-state. If you can imagine Stax headphone transparency with Klipschorn dynamics and 45/300B tone color that about describes it.
What's odd is that recordings, even "bad" recordings, sound great, but boy, it doesn't forgive poor sources at all. Changes to the source are usually audible before I walk back to the sofa - everything sounds different, there are no sound-alike DACs with this amplifier.
What gives me pause is the new speakers will be far more transparent - and dynamic - than the Ariels. The system will gain nearly 10 dB of headroom and loudspeaker distortion IM distortion will drop several-fold. This will almost certainly result in more demands on the source - maybe by then my friend's DAC project will be done.
Lynn have you considered a DHT on the input as well, such as 26, or not really worth it?
Its worthy of note here that the clever sauce of this module was in the calibration algorithms to select/trim the resistor values in that discrete DAC. And also that it had an output deglitcher (sample/hold) as CMOS ladder DACs like the 7541 are notoriously glitchy.
You are correct about the internals of the UltraAnalog 20400. The standard part did use an internal sample and hold for deglitching. The factory had an algorithm for calibration. As an employee of Pacific Microsonics, I spent a few Saturdays at the plant doing the cal. Keith Johnson insisted on true 20 bit parts, so we had to be especially careful with selection and trim, taking somewhat more time than the standard production units. PM developed a way to get around using the sample and hold, so our parts were custom. I believe this trick also omitted the internal NE5534 opamp.
