There will always be outliers in every test - we normally look at the centre of the bell-curve for the most probable result, not the outliersJohn: "If I was the only one who heard such improvements then I would agree with you. Did I test myself using an informal blind test - sure I did. If, I also hear many, many people all reporting agreement on the improvements then I take note. I know "mass hypnosis" & suggestibility can be used to explain this, sure!!"
The above explanation only works if you ignore the users of jplay who heard no difference, surely they are just as likely to be correct as the ones who do hear a difference. When there is no objective evidence of any difference, and there is no plausible explanation given of even the wildest speculation of how there could be a difference, then one should very well question their own observations if they hear a difference. BTW, I care not whether you are blinded, in fact I generally do not believe in blind testing, as it tends to test the observer rather than the DUT.
Have you read this thread & their reply? Let's see They say "We cannot _control_ timing in OS (due to its design) but we can _influence_ it to a great deal indeed!"I think you fall into the trap of assuming that the developers blindly just try "random" changes to see what affect it will have. This is a naive, black & white view of how such developments occur. People often follow their theories/ instincts in developing products, analysing the results with listening tests as they proceed. The end result may not easily succomb to measurements to show these audible differences but it therefore does not invalidate them. So I disagree with your hypothetical picture of the software being developed in a random way just because they have no measurements to show what they can hear."
I do not have a naive view at all, I consult in product development. The problem I have here, is that the jplay developers offer no explanation of how their SW could improve sound (assuming a working asynchronous interface environment). This is what I am responding to, please go back and read my post because you appear to have not gotten it. When they admit to not knowing how, or why their approach could improve sonic performance, they are also admitting to having no working theory to start with. If one has no working theory to start with, then development can only occur by random chance, trying things, and seeing what happens.
And why do we need to influence timing?" ..."Surprisingly, it turns out that size of this buffer which is a sort of a necessary evil, has an impact on sound as in, smaller buffers sounding better! We don’t know why (at least we can measure buffer size lol) but we can theorize that smaller is simply better as less data has to be moved around which means more of it (ideally all) can stay closer to CPU simplifying the process by minimizing ‘fetch data from ram bank’ steps." I'm not going to go through each of their points, it's there in the thread for you to read but I would suspect that as you use Linux for audio, you already know most of the points they make. For you to then try to paint a picture of random, haphazard development is really being somewhat disingenuous, I believe
You are taking a guess at what the resultant effect of their software should be. Did they say that? From that guess you are building a strawman argument, etc. - I'm sure you know the routine by now, you have been on many forumsNow, if noise reduction (airborne and USB cable borne RF) is all that jplay is affecting then it should be relatively trivial for the developers to pay some RF engineers to make the appropriate measurements
When you were testing the different software that you mentioned before - where you found that they sounded different - how did you settle on the particular one you use now? Did you SOLELY listen to it or did you get measurements from the manufacturers? I presume you got these measurements as according to yourself "Anyone who bases their evaluation of an audio system SOLELY on listening is making a lot of big mistakes."
