I like this a lot better than the canron guage. Measuring platform is not too high at just above the surface
I have one like the one on the OP. It came with my TechDAS cart along with tweezers cart leads and screws. My trusty really old Clearaudio finally died on me so I used the freebie.
I almost had a heart attack because it was riding high and I couldn't use the lifter to set the stylus down on it so had to do it manually. I like them low slung weighing areas a whole lot more just for that added sense of security.
Yeah my Clearaudio died years ago too And I lost the the AC adaptor along the way to the Cartridge man stylus pressure gauge. Now that was a nice piece.
http://www.thecartridgeman.com/digital_stylus_force_guage.htm
These are pretty good and accurate their downside is 5 grams max limit, that's not enough for those with some vintage cartridges. Another minor issue is that you'll get slightly different reading if the stylus isn't centered on that dot. Otherwise it good value.
Ortofon scales (disclaimer; I am an Ortofon dealer) are both high quality and more sanely priced than some other ones I see and they work with cartridges that have heavier tracking weights. At the end of the day I don't see the need for 2 or 3 digital places, tracking weights are a starting point and the better arms already bring you right there without any scales. Fine tuning is done by listening!
david
Then why does Jonathan Carr tell you to set the Atlas at *exactly* 1.75 gm? There is a reason. Personally with the VPI arm and counterintuitive combo I can easily and reproducibly set the VTF by 0.001 gm and it makes a difference.
And it's great the Ortofon can sat VTF for vintage cartridges but that probably is only of interest to 0.0001% of analog lovers.
Myles, does J Carr say that or the manual?
My manual says between 1.65 - 1.75 with 1.72 recommended.
Pardon me it's 1.72 gm.
Then why does Jonathan Carr tell you to set the Atlas at *exactly* 1.72 gm? There is a reason.
Why does one want precision? It has to do with optimally placing the coils in relationship to the magnet and flux fields and tracking.
Count me in that group!And it's great the Ortofon can sat VTF for vintage cartridges but that probably is only of interest to 0.0001% of analog lovers.
That's what you said in your first post. I bought a new gauge precisely because it did go to 3 decimal places.
I just ordered the ds-3 from a Japan seller on eBay. I like the idea of the scale being much closer to the thickness of a 200 gram record versus the acoustech I use now. In any event, when setting weight, the VTA better be the same as that when you play records otherwise thy VTF will not be what you think it is.
