Patience, patience and more patience. Its painful, boring, laborious but once you hear your cart "properly" aligned it will be more than worth it. Once you get used to the Mint all you need to do is ensure that the cantilever is parallel to the fine black lines at the 2 null points after checking that the stylus is accurately tracing the arc etcI ordered a mint yesterday any tips for using it???
My tractor of choice...
how long did it take you to dig up this pic? Maybe you could have just not replied!!!
Here is a photo showing the relative curves traced by my 9" SME V and 12" SME V-12 arms on the Mint protractors. Note how much flatter the 12" curve is and the overhang distance from the spindle hole.
Very informative pictures, thanks Peter.
I also ordered mine just recently which has not yet been delivered. I will compare Mint to Dr Feickert Universal protractor that I already have. Tonearm is Graham Elite.
Zenith is also painful with Dr Feickert. The base is all black which requires even more light, also parallel lines are two far apart unlike Mint, making paralel cantilever adjustment harder. I will report my findings after comparing those two.
why don't you use Bob's jig? the mint LP is an exercise in frustration I had better success with the graham jig.
The key problem when setting zenith with the Feickert is that it is difficult to compensate for the parallax effect. With the Mint, you know when you are looking to the alignment lines directly from the front and above because the lines overlap their reflections in the mirror below (as shown in PeterA's picture above). I now use the Feickert to set the pivot-spindle distance and the Mint for overhang and zenith.
In that case, be aware of the following. The manual for the Graham Phantom that still comes with Elite (until Bob updates it) states that the pivot-spindle distance for the 10" arm is 230.3mm (247mm effective length and 16.7mm overhang). However, Yip draws the Mint protractor for the 10" arm based on a pivot-spindle distance of exactly 231mm, as this is easier to measure without error.That is also my intention, plan to use Dr Feickert for PTS, Mint for overhang/zenith. I have a second tonearm Ikeda 407 so still need Dr Feickert as mint that I got is for Elite tonearm. If mint shows better improvement, may order a second mint for Ikeda.
bob's alignment is different than yip's method.
