Yes, as a friend said to an engineer who asked your question, "yes, political science is a great deal like engineering."
It seems to be that a double blind ABX test could easily be designed to deal with all of the issues that you have raised. I would propose for one that the test subject should be able to listen to a track or tracks for as long as they want, it a a nice relaxed atmosphere, telling the tester when to switch (or pretend to switch) when he or she is ready. I for one would volunteer to be the test subject in just such a test.
What is often cited by objectivists is that "preference" is not a question & not being tested.
Not familiar with his book. A bit of familiarity with his tests. I find the use of one speaker rather than two speakers in his tests be two exactly what I'm talking about - objectivists wilfully ignoring psychoacoustics because, as Toole says, (I paraphrase), "it's a simpler test"Are you familiar with Toole's book?? That happens to be exactly how they do their testing on loudspeakers. It's based on preference. As a matter of fact they can reliably predict how well a speaker will score just by looking at the frequency response/measurement set. This is all based on which speaker the blind listener thinks sounds better.
Rob![]()
Do you have the research that shows this?I do believe they tried it both ways, stereo and mono. The stereo results didn't contradict the mono tests. But the differences found in the mono test were larger and more reliable.
Again, without showing the research which correlates stereo & mono results, I find this unconvincing.Essentialy they made it easier for the test listeners to reach a conclusion that they would also reach with more difficulty in a stereo test.
It's a bad approach because it eliminates a significant number of factors that we pay particular attention to in our normal listening - ITD. ILD, sound stage - width, depth, solidity - I'm sure there are others perceptual aspects I'm missing that rely on stereo reproduction. I find this approach similar to measurements using test signals very unrelated to the dynamics & crest factors in music - again for the reason that it is simpler to analyse.I fail to see how that is a bad approach. It is a more discrinmating test than if it were more complex. They haven't ignored psychoacoustics.
Maybe so, I don't know the recording side - maybe some who do can explain this?A bit off topic. A common piece of advise given by people who mix recordings: listen to your mix in mono when you are done. Why? It is easier to hear when something isn't right about the mix in mono. Get it right in mono, and it will be fine for sure in stereo.
Yes, I agree absolutely with this & would add that a lot of blind testing falls into this category - psychologically, it is a heavier processing load with more factors in play than normal listening.I think you will also find it to be very uncommon for human subjects to perform better in a complex test than a simpler test.
Do you have the research that shows this? Again, without showing the research which correlates stereo & mono results, I find this unconvincing. It's a bad approach because it eliminates a significant number of factors that we pay particular attention to in our normal listening - ITD. ILD, sound stage - width, depth, solidity - I'm sure there are others perceptual aspects I'm missing that rely on stereo reproduction. I find this approach similar to measurements using test signals very unrelated to the dynamics & crest factors in music - again for the reason that it is simpler to analyse.
I can understand the desire for using tests which are easier to analysis but the limitations of such tests should be recognised.
Just an aside, the Harman speaker shuffler takes 3-4 seconds to switch speakers. Even though each speaker sounds very different, a lot of those differences get erased by the time you hear the other speaker! It requires fair bit of concentration to remember what the other speaker sounded like. The short term memory is really that: short term.Are you familiar with Toole's book?? That happens to be exactly how they do their testing on loudspeakers. It's based on preference. As a matter of fact they can reliably predict how well a speaker will score just by looking at the frequency response/measurement set. This is all based on which speaker the blind listener thinks sounds better.
Rob![]()
As I asked already, can you link me to the research paper which shows the correlation between mono & stereo results? From what I read, the reasons given were to avoid the confounding affects of testing in stereo - comb effects, etcDr. Toole did the tests and said whenever speakers do better in mono they do in stereo as well. Keeping in mind most of his tests regarding speakers are blind testing for a preference of one speaker vs another. Once he obtained those results it made testing simpler to do it in mono. You'll have to ask him for the research data. His motivation wasn't for a simpler test. It was for the most disciminating test. That it was also simpler was a bonus.
Again, I haven't seen any research to show this. But I would also make the point that if one's listening is being directed towards freq & amplitude differences then yes, that perceptual aspect of our hearing is being ignored.If all the reasons you think stereo important (and without Tooles work I would have assumed the same thing for the most part) get less clear results than mono testing perhaps those aren't the issue you believed them to be.
What results?After reading those results it makes some sense.
You are assuming too much here - the balance between speakers (matching of speaker drivers) will have an effect. The time alignment between the various drivers (in one speaker) may only become evident in stereo listening? As I keep saying where is th eresearch that shows the correlation between mono & stereo results?ILD, ITD are just between speakers. It isn't like one speaker has more of a time difference than another if positioned the same.Nor like the level difference will be more different with one vs the other. So what is left is those various stereo imaging and staging effects are probably due to varying frequency and phase response along with directional differences. It may be in mono, though no imaging is possible all those same differences cause a similar or even heightened differences in the preference. So the best testing speaker in mono will be the best speaker in stereo as the stereo result will be more accurate and predictable. Toole and Sean Olive have developed a model that they say allows them to predict which speaker will be preferred by testees with a very high degree of correleation. Much of that model does look at directionality of the speaker, early reflections, and a number of other things that would appear important for good stereo performance. You can read a bit about their ideas in this article from 2004.
Ah, do you mean to retrac what you just said then - a heavier processing load being a confounder is well known in psychology.http://www.edn.com/design/test-and-measurement/4384927/Sound-science
As for listening to mixes in mono, I don't know that it has been researched. It is some collective wisdom that a number of people working in that field suggest. Not everyone does it or thinks it necessary.
While blind testing may present a heavier load, it also seems to give more consistent results.
If you have not read the book you don't have a complete understanding of the testing. Why he went mono is all explained. All the data you are asking for to support that position is all either in the book or in the referenced papers in the back of the book. He chose the simpler test because of psychoacoustics, he used that as a tool to get more reliable results not ignoring it as you suppose.
Rob![]()
Anyway, let's not get side-tracked into another Toole/Olive/Harmon debate. It was brought up here in answer to my post, as an example of blind testing for preferences & yet I think it's a good example of objectivists avoiding the complexity of dealing with psychoacoustics - using a mono speaker which are switched outside of our known auditory echoic memory time window.
You seem to be quite good at only listening to yourself. This isn't the first time. If you want to know about the data on Toole's work, get the book he wrote. I would go find it for you, there are at least a handful of interviews where he gives summary of those findings. But I was a bit put off by your dismissive attitude in your reply to me. So find it yourself or buy his book or bumble on needlessly. They did the tests, mono and stereo. Got better more reliable and more discrimnating results in mono. It is not what you are convincing yourself it is.
Then a whole diatribe to make it look as if I made big claims and didn't supply the results you need. The repeated lament, what results? Where is the data? Well, I told you where to find it. Go buy the guy's book.
Rob![]()
Yes, unfortunately, this is the problem. To my mind, as long as the test is giving the results wanted (null results) this "making do" is accepted. Once the same test reports results not in keeping with "expectations" the whole tets procedure is questioned/analysed/changed. Witness the reaction to Amir's positive ABX results of Arny's test - investigations of IMD, sample rate converters, possibility of cheating, etc.+1 Here
Your points is that blind test is not perfect .. Everyone gets that. Has gotten it for a while and on both side there will be extreme positions. For the most part objectivists are quite clear that they can'talways perform blind tests they make do with what is available.
Who says this applies in the field of auditory perception when long-term listening is used? Please don't cite that Harmon test of Sighted Vs Blind as an example - it is one of the best examples of skewing a test I have ever seen - picking employees from Harmon as the test subjects, doh!!Let's use a cliche.. Almost everyone know that Blind tests are not perfect. Nothing is. yet there are tests although imperfect that yield better , more reliable results than others and on that front, sighted tests fail miserably.
It's funAs an aside it would be interesting for you to read this post by Ack:
Is your brain playing tricks on you? A case of expectation bias?
You will then make of it what you wish.
