Matching Koetsu Blue Lace to proper SUT or pre-amp
bgupton
109
13
248
San Francisco, CA
I pulled the trigger on the Koetsu Blue Lace. I'm a bit confused about pairing it with my pre-amp or another SUT.
I have a Shindo Vosne Romanee. I also have the standard A23 SUT made for the Denon 103. My understanding is that the A23 I have is made for medium output carts like my Delos. I also understand that the Vosne Romanee has a built in phono stage that is more optimized for a low output cart.
What I don't know is if the Vosne Romanee's phono stage is optimal to get the best out of the Koetsu Blue Lace given it's output/impedance or if I should be considering a separate SUT like the A23 Hommage T1 or something altogether different. It's hard to find technical specs on my Shindo stuff. I'm sure my dealer will respond, but thought I'd ask here too. :)
Any advice on how well this cart will mate with my Shindo and/or better SUT matches?
Here's the tech specs for my Blue Lace:
Specifications:
Body: Blue Onyx
Type: Moving Coil
Coil Wiring: Silverplated Copper
Magnet: Platinum Magnet
Cantilever: Boron Cantilever
Output Volts: 0.3mV
Frequency Range: 20Hz to 100kHz
Channel Seperation: 25db/1kHz
Inner Impedance: 5 Ohm
Channel Balance: 0.5db/1kHz
Recommended Impednace: 30 Ohm
Weight: 12.5g
Compliance: 5 x 10-6 cm/dyne at 100 hz
I've owned the cart--and its forbears--the Cotter 2L is the best as purpose built for the K's--they are available S/H
Second only to the now virtually unobtainium Expressive Technologies SUT
Any others apart from these two are compromises with the Koetsu's
Just my opinion
Good Luck superb cart!
BruceD
I use the Doshi Audio with my Coralstone. No SUT needed. I believe Rockitman uses a SUT with his Aesthetix.
Specifications:
Body: Blue Onyx
Type: Moving Coil
Output Volts: 0.3mV
Weight: 12.5g
Your preamp has built in SUT's that can handle a .2 mv signal according to the specs. No idea if they are good match for your cart sound wise, but I would try them first. Should have enough gain at least.
Yes as a Shindo owner I know the Pre can handle the cart--but the listening consensus seems to indicate the MM Phono plus an appropriate SUT is the preferred input with the Shindo Pre's
Just an observation
BruceD
Hi, Well the two I have mentioned above--but The Auditorium Hommage would be the pick currently available in cohesiveness with the VR Pre--there are two types I'd suggest try the higher setting version(EMT/Denon /etc) even though your Cart is low output--it may work better--just gut feeling as I've found the K's to boot out bit more than they rate.
I've owned the Ortofon series Auditorium SUT and it mated very well with the Shindo Pre
Good luck
BruceD
I'm an SUT guy. Built in silver cores and jensens. For my Koetsu I only use my Koetsu step up.
Specifications:
Body: Blue Onyx
Type: Moving Coil
Output Volts: 0.3mV
Weight: 12.5g
Congratulations on your Blue Lace! I found it to be the best cart so far. Have in mind that the newer Koetsu carts sound more dynamic without losing the lifelike timbre and other qualities. With the right tonearm and correct installation the Blue Lace will shine. Make sure you have the (heavy) counterweight closer to the spindle for better tracking. IME a good phono betters the Koetsu SUT. I found that the Blue Lace works best at 58-60 dB phono stage gain and 100 Ohm, but the former could vary with different equipment.
Years ago, I tested a Koetsu SUT vs. the Mitch Cotter with a Pro-IV and Rosewood siggie. I thought the Cotter had more life and more leading edge, the Koetsu SUT did indeed shine in the almighty midrange. It was an overall tossup on the audio balance beam. My taste ran toward the Cotter though I think because the Koetsu carts at the time were soft at the frequency extremes.
Just my opinion
BruceD
Very interesting remark Bruce. I use inter alia use a Koetsu coral stone platinum diamond cartridge but I have never combined it with my Expressive Technology SU-1. Actually have not used the ET SU-1 for more than decade I believe. Am I being stupid here and should I get it out the box again? Actually thought about selling it but there only a very few audiophiles who know about ET SU-1 and never wanted to sell it for a fancy price.
Thanks for the info!
I just got back from meeting with Stirling @ Audio Systems Optimized. Great guy. He's doing an install for me and dialing in my room. I had him inspect the Blue Lace since it was purchased used. Dealer claimed that it only had about 5 hours on it. I assumed that was dealer speak for 500 hours, but I still got a great deal.
Stirling inspected the cart pretty thoroughly and says that it is indeed barely used. Said it still looked brand new. Nice!!!!! Now I feel even better given what I paid for the cartridge.
My install is Friday, so I'll keep you all posted. Pretty excited now. :cool:
If you try it and decide to sell, let me know.
If you get the ET SUT you must get the cable that accompanies it in tandem--part of the designers synergy
It is the finest SUT ever made--put's the rest behind it
BruceD
I used the A23 with the Dynavector 20X2L into the VR as well as the Giscours with great results. The specs of it look comparable to the Koetsu in terms of output and internal impedance.
I prefer the Expressive with the Dynavector XV-1s that I have. But the Kondo I use with the IO-M and that combo is a must. The Expressive just adds so much life to the music and I haven't heard another transformer do the same.
