Yes that makes sense.
I have a Poseidon to ground the amp and the negative speaker terminals which works very well.
Keep us posted and let us know how it goes
Hi Barry,
Do you mean you can connect the negative speakers input to the Poseidon with other things like a preamp for example, at the same Poseidon ?
Thanks Mike and apologies to all. I made a confusion with the Olympus Tellus.
Sorry
blame it on Jazzhead.![]()
..... The quest to keep pushing boundaries , tread where no man has ! Will be interesting to see how an uber rig/room will react to three seemingly inconsequential little boxes , filled with cat litter . Just disconnected my outer two Atlantis Minimus which connect to the Posiedon . Immediate flattening of stage , loosing depth and tonal density to note reproduction . So I expect a nice boost to be had , will be watching this space keenly . Cheers !
Might as well throw in a few Everests into the mix ......
I agree - your system needs working on![]()
I'm already fully 'Everest'ed' with 7 of those, 4 on the Silver Tellus and 3 on the Poseidon.
I will fasten my seat belt before inserting the Atlantic Minimus boxes. Joe Pittman says 3+ weeks for delivery.
Meant one each , on the incoming AM .
the Atlantis MinimUs comes supplied with a short & specifically designed umbilical cable( this is included in the purchase of the Atlantis MinimUs) that allows you to connect directly on to the back of one of our dedicated grounding box's.
obviously the three Everest's I have already for the Poseidon will also be used for those same posts connecting AM incoming cables.
maybe i'm missing something, but my understanding about the Atlantic Minimus is that it has a captured connecting cable and that there is no option to use another cable and there is no post to use an Everest knob. please clear up my misunderstanding if that is what it is. as is normal for Entreq, information is a bit obscure and mystical.
from the Entreq website regarding the Atlantis Minimus;
If by captured you mean captive .. Then no . There is a short umbilical that s suppled with the AM , normally terminated with an Entreq type spade either side . One end will will hook on to the Poseidon peg and the other to the M8 silver binding post on the AM, similar to the binding post on the Poseiden . The wooden screw on block , depicted in the picture is incorrect . It uses the normal hollow wooden peg to clamp the spade . I have the AM binding post Everested , with good gains . Hope this sort of helps.
Very interesting.
Have you tried the Entreq i'cs and speaker cables.
I'm very pleased with mine and they,of course. have their own earth connections to the ground boxes.
been pondering your 'not unexpected' response to my decision to add more Entreq. aren't I done?
and I guess I have to say that how I got my system to the place it's at, that we both appreciate, is the same process I just went through to add these 3 Atlantis Minimus boxes.
I got a whiff of an opportunity for a system-wide performance boost, thought it over for a few months, weighed the cost/benefit, and the hassle factor of doing it, and then pulled the trigger. I almost did it 45 days ago but backed off.....I was not sure enough then.
will this be that move that is only 'meh'? could it take things backwards? well.......my view is that, if anything, my system now takes absolute advantage of any gain. it's transparent like that.
I also considered adding another Troy product, but decided not to spend that amount of money.
