I would suspect that stuff like :
DeFractionalized Memory: By forcing the data on memory to populate in its original order, DeFractionalized Memory can transform sound to a more analog, natural tone, with increased dynamics, bass and ambient retrieval.
Even a state of bit perfection will allow up to seven bits in a byte to be played out of original order, due to the weakness in the code used for digital audio.
The Clock mapper: The Clock Mapper is an affordable and superior alternative to the costly and antiquated atomic master clock. It is used in recording studios, and now, can be part of your home high end audio system. The Clock Mapper literally isolates all its audio processes to a single clock, removing all jitter from competing processes, by virtue of having no interruptions or conflicts with non-audio demands for clocking.
This cannot be done with a single master clock, because even small distances between components create timing changes. State changes in chips then change this timing infinitely and randomly (dependent upon what is being played), adding to the inductive and capacitive timing changes from using a single master clock.
and IDEAS:After a single use of IDEAS*, your music is transformed. IDEAS removes zeroes between original audio codes -- very common in music stored or played on SSDs or hard drives -- therefore removing the time gaps which manifest as jitter.
The release of subtle and increased ambient information, as well as a dramatic shift toward an 'analog' sound, is heard immediately. All music becomes more lifelike and natural.
as well as Read Until Right (RUR) should make a big differnce in quality to digital playback.
Much of this is implemented in the Much more affordable Mini Streamer ($2500 to 3500) with the top model having 2TBs of Defract storage.
I am interested in feedback on this potential little marvel which features: • “DeFractionalized” wide byte memory
• IDEAS 1
• IDEAS 2
• The Clock Mapper
• RUR CD Copier
The proof of the pudding as always is in the eating, but the high level concepts are compelling. Oh, and it has a blueray player built in as well. .
Taiko...a potential problem of downloads would be "Embedded jitter" and you would something like the IDEAS concept to clean that jumble up, no?
