Oh okay, that clears things up. What I'm saying is good as treble might seem, it gets better when what's missing from the reproduction of the full signal (Bass) is put back/reproduced along with it.
Given a particular amp is powerful enough to control the bass, if the bass is finely controlled doesn't it follow the amp will finely dissect the treble too? In defense of amplifiers, it has been my experience the amp cannot overcome the sins of the other components.
Although we think of instruments in term of the spectrum covered...a violin for example is considered a high pitched instrument .. Its spectrum however does show considerable energy in the upper bass. A good reproduction of the bass frequencies does help in reproducing the violin (and many other instruments, including the human voice) better ...
Nothing to disagree with there, Frantz, but it's all a matter of what you call upper bass and what you call full range. The spectrum graph Mike posted a couple of pages back showed the violin's "bass" overtones falling off at about 200 hz. That's not going to be much of a problem for most small 2-way speakers, the best of which are going to go to 50-60hz without significant coloration. Are they full range? No. Are they able to handle the bass content of most music? Yes. Add a sub for the last octave or two. And while I would absolutely agree that covering the 50 - 30 hz region can add a lot to some material, it clearly doesn't add anything to a violin. I wonder how much more of the music we listen to contains no information below 50hz? A lot, I suspect. None of this is to say that full range is not a good thing. I'd just advise against getting too carried away and insisting that music is incomplete without it. I suspect that is usually not the case.
Tim
Above and below some frequency the shelf has a flat response, so the upper treble or lower range is not changing response, but rather the relative balance between them.
Hi Tim,
I have to wonder about some of the spectrum's I see listed about instruments and how greatly that spectrum varies over time. Most look at the sustain of an instrument, where that is often the least identifying/unique part of the sound between instruments. I'm not suggesting that a violin would be the best example, as I suspect a more percussive instrument would be a better example. As I'm sure you know, any sound with a "fast" attack or decay must include wide bandwidth by definition. Depending on when an y lower level bass energy occurs, it could certainly affect the perception of percussive or changing events. IMO, apart from the more obvious instruments, with non-shy instruments the deeper frequencies largely punctuate the sound, much like plosives in speech.
From my own simple experiments, it's quite intriguing, if not confusing, to play with simple shelving filters while listening. You can shelf up or down frequencies only above 1-2kHz and hear how the perceived bass qualities change, and you can lift up and down the lower octaves and hear how the upper frequencies can sound more or less detailed or muddied. Above and below some frequency the shelf has a flat response, so the upper treble or lower range is not changing response, but rather the relative balance between them. I suspect most audiophiles would be surprised at the process used by an engineer/sound dude to get the exact beater head & attack sound for a kick drum... especially as they whip around the HF EQ!
There's good reason Bass should be spelled Base. It is the foundation. Now turn off YOUR sub off and yes you have your answer and it will be exactly the same as mine.
I'm sorry, Gary, I don't follow the logic of what you're saying here. With the waveform as shown there should be no loss of "shimmer decay" if the underlying bass waveform is filtered out, either in a software editor, or by crossover components ...If the bass is removed, or wrong, the shimmer and the pureness of the "tink" of the triangle is lost.
More like $2 worth, I reckon ...Now I agree with Tim and pretty much everybody else here that true full range is a not a prerequisite to musical enjoyment. It is however a huge chunk of the puzzle whether one's reference is live, artistic intent or the signal. Live means big instruments. A violin is still larger in surface area than most every two way, a triangle more than most tweeters, a piano or kettle or Kodo drums more than subwoofer drivers even with xMax in consideration. The simplistic view of artistic intent is if it was written or played all of it was meant to be heard. As for being true to the signal, if it's in there, play it all as best you can within the limits of practicality.
Just my 2 cents.
Oh dear, I feel such a lone, lone voice, proclaiming the virtues of the good tweeter, may its soul forever truly bathe in streams of pure, unadulterated, glistening notes, effervescently emerging ... (bloody hell, a pleb from down under going poet on us, can it get any worse ...)
Yep, I still stand on the dark side, so I will rephrase your "No real bass, handicapped highs" to "No accurate treble, handicapped everything else". Like everybody else, I am a child of my experiences and since my experiences include the transformation of sound when the treble snaps into focus, even having thick, plodding bass turn into sharp, gut thumping kicks, then that's where I will unfortunately have to remain ...
Frank
Whew!
Out of interest, let's analyse the waveform you presented. The initial impact of the "hammer" produces a slowly decaying note at about 300Hz. Once the striker is no longer in contact with the instrument a very strong natural tone or 8th harmonic overtone appears, at 2400Hz, which also slowly decays. This is the shimmer element. There was an earlier more subtle note struck, at about 3800Hz, which decays by about halfway through the time grab. Underlying all of that are tones which vary from about 100 to 400Hz, which are all of the rest of the sound content of the music making shown in this snapshot.Frank, if you look at all 0.08 seconds of the waveform, you can barely perceive a single wave with everything else superimposed on it. That's 12.5Hz.
My guess is that what people are responding to is the natural very low bass energy that is part of the background sound of virtually all environments, bass background noise if you will, ambient rumble. Microphones don't have any problem picking this up and so when this is added into into the mix by a high quality subwoofer this sounds and feels more natural. Thus, irrespective of anything else, the music comes across better with its presence ...If I am understanding this somewhat,
If there is a guy gently striking a hihatt and then a bass guitar starts in, then the hihatt sounds better all of a sudden?
Seems to me that is nothing to do with the bass reproduction but something happening in our heads.
Confussssed.
Tom
Confussssed.
Tom
I think if most audiophiles could log some hours in mixing and mastering, a whole lot of myths would dissolve.
Tim
