Pass Labs XP-22
PeterA
14,722
13,503
3,515
USA
Has anyone heard this new preamp from Pass Labs? It was recently released and it replaces the two box XP-20 which has been around for about eight or ten years. I think it retails for about $9,500. It should have some trickle down technology from the XS series. I think I read that it has a new volume control, or the one from the XP-30 and lower noise.
I am curious how it sound compares to the XP-20. Is it like the .5 versus the .8 amp series, where they seem to be voiced differently? Some people ended up preferring the .5 to the .8 in certain systems. Or is the new generation an across the board improvement?
EDIT: Here is a link I just found and some photos. The specs in the link are quite impressive. Note the new front faceplate and power supply cable connector.
http://www.moremusic.nl/pass_labs/xp22.html
Thanks Peter. I am in an email conversation now with Mark about this product. I just might do a trade-in. I was curious if they stilled used the DB-25 cable to connect the two chassis together. I upgraded mine to the Revelation Audio cable, and it took the XP-20 to a much better level. It appears Pass paid attention to this and the new cable uses aviation grade plugs with silver/copper cable.
Just noticed it has a power switch. Wonder why?
Yes, I replaced the stock cable with an Revelation Audio Cable on my XP-25 and it made an audible improvement. It definitely looks like there is some trickle down from the XS line.
Probably has something to do with a Lawyer somehow.
I may just wait for all the bleeding edge folks to dump their XP30's in anticipation of the XP3x once it comes out instead of laying down for this new unit. Err..maybe
Very curious how this guy sounds though. I keep telling myself this two chassis unit is more practical but the devil on my shoulder keeps disagreeing with the sensible side of my brain telling me to go for the "old" XP30 instead. :)
My gut feeling, which is usually wrong, is that there will be no XP-32. Three chassis for a pre is a PITA, and I doubt the performance is all that much better than the two chassis XP-20.
Disclaimer. I am a biased XP-20 owner who has ordered an XP-22. :)
Mr Fox,
I look forward to your in depth comparison review of the old 20 and the new 22 :)
Well, the difference when I moved up from the XP-20 to the XP-30 was large enough to make me smile and never look back. :)
I cannot imagine the 22 will be better than the 30
That's a great photo jackelsson. What a stack of hardware. A few years ago I borrowed a friend's XP30 and directly compared it to my XP20. I actually preferred the 20 at the time. In my system, it had a more neutral tonal balance where the 30 sounded too warm. It had slightly higher resolution, but I did not like the added warmth. In combination with my slightly warmer XA160.5, the 30 was too much. I also tried the XA160.8 in my system. Perhaps the .8/30 combination would have struck the right balance, as does my .5/20 for my preferences.
I later tried the XS Pre in my system and found that its tonal balance more closely resembled that of the 20 in my system, and not the 30. That struck me as odd because the frequency response specs and impedance output (120 ohms) of the 30 and XS are similar while the 20 has a much higher output impedance of 1K ohms. I now realize that my Transparent cables which are calibrated for my XP20 were not properly calibrated for either the XP30 or the XS, so I did not hear the XP30 or XS at their best. I am still confident that the 20 and XS have more similar tonal balance than either does to the 30 because I heard similar tonal differences between the XP30 and XS in a different system.
It is hard to say if Pass will develop the three box XP32. If the separate power supplies are that important for sonics, why does the XS have only two? Pass also decided not to have a three box XP35 phono. The new XP17 phono may already be better than the XP25 phono which is scheduled to be replaced by the XP27. I suspect the XP27 will be extremely good.
I have just ordered an XP22 which will arrive next week. I have sent my cables back to Transparent for re-calibration so that I can hear the XP22 at its best. I have also borrowed a pair of balanced ICs so that I can directly compare my XP20 to the XP22. If someday the XP32 will be released and it is considerably better than the XP22, that may be an upgrade worth doing also.
Ack, why do you think that? I just heard from someone who has directly compared the new XP17 to our XP25s and he told me that he prefers the new one box XP17. The 17 and 22 both have trickle down tech from the XS which was developed as a flagship after the XP30 had been around for a while. You may be right, of course, but I'm curious on what you base your assumption.
Congratulations Bud. As you and I have both learned, the performance of the XP can be greatly improved by using the Revelation Audio umbilicals. I have compared the 20 to the 30 and preferred the former in my system, but see my other post for the possible reasons. The 30 uses the noisy umbilicals while the new XP22 apparently has much quieter ones similar to the ones from the XS.
I am sure the guys at Pass have compared the new XP-22 to the XP-30. I have not heard which they prefer. It would be an interesting comparison. A used 30 is about the price of a new 22. If they sound similar, I would buy the newer design with one less box.
As you know I am NOT a fan of the XP-25 phono; I am a fan of my MODIFIED 25, but I still remain skeptical when people claim that the 17 is better than the stock 25. As to why I think all that is because reputable manufacturers carefully version their products, and that has been proven true time and time again. I think the 17 is a replacement for the 15, the 22 for the 20 and the 27 for the 25; but otherwise the 30 remains a statement product.
I feel you would better off with a used 30, and I also think your prior assessments had been based on an overall less resolving system, nothing to do with your cables. Since then, the resolution of your system has improved significantly and your preamp purchase merits careful thinking.
Love my 30. Don't see it ever leaving my rack!
Congratulations on placing that order, Peter! That is very exciting!
I look forward to your comprehensive report and comparison!
Thanks for your comments, Tasos. Yes, I understand that you bought the Pass phono as an interim solution because you were tired of waiting for Spectral to come out with a new phono, so I know you are not a fan. You did buy it after briefly hearing the Xono phono in my system. From what Pass tells me, the differences between the 15 and 17 include some of the modifications you made to the 25, like better shielding to the power supply and umbilical cable. The 17 does not have a separate power supply and umbilical, but those are significant sources of noise in the 25. The 17 may not suffer from those same issues and may in fact sound better. Of course I have not directly compared the 17 to the 25, but at least one guy at Pass told me that he preferred the 17 to the 25 during his long term listening. I have no reason to doubt him. The 27 should be even better maintaining their two price/performance levels.
I gave the purchase some careful thinking. I have had the XP20 since March, 2009, eight and a half years. Prior to the XP20, I had the X1 and was thinking of upgrading to Pass' then statement preamp, the three box X-0.2. I was told by the dealer that he and Pass Labs thought the newly developed and just released XP10 was better than the former statement X-0.2 still in production. In fact he "strongly recommended" that I get the slightly higher priced lower model one box XP10, over the statement three box X-0.2. The one box base model sounded BETTER than the former statement product according to the designers. So I saved a bit more and waited for a deal on the even better sounding second level product, the XP-20. I just reread my emails to Reno Hifi from 2008 discussing the X1 to XP10 or X0.2 upgrade path to refresh my memory.
Your thinking that the "statement product" can not be surpassed by a newer, lower model was refuted by Pass Labs and Reno Hifi back in 2008 and even addressed in a review at the time by HiFi Unlimited in 2011 regarding the new XP-20 and the former flagship, three box X-0.2:
"The moment I fired up the XP-20, I was thinking to my self "now this is more like it!" The two box XP-20 came with very bold expectations as the foreign reviews already claimed that it's so... good, that it made the much more expensive and higher end X-0.2, three box model redundant."
and this one from a later article in HiFi Unlimited comparing the X-0.2 directly to the XP-20:
"The X-0.2 offers subliminal, textured, and solid bass reproduction. It's noise floor levels are not as low as the latest XP-20 that good ol' Odiosleuth had up graded to recently, but still amongst the most quiet of preamps as they come. Out right transparency and low level signal preservation is another area where the newer preamp designs like the XP-20 has clearly marched on. So clearly, statements about the XP-20 out performing the Pass(t) statement product are not without substance."
So, apparently, here is a clear case of a former statement flagship product being surpassed by a newer product. Pass Labs may have just done it again with the XP-22 which benefits from technology first developed in the much more expensive flagship XS line. I don't know, but history does have a way of repeating itself, and it is clear that Pass knows how to develop and market new products.
I have given this new preamp purchase some careful thinking, in fact since the new models were announced a while ago. I have not heard the XP20 yet, so I can not have directly compared it to the current statement XP30. I don't know which is better, but based on both the story of the earlier statement/flagship being surpassed by the then new XP10 base model PLUS the auditioning in my system of the XP30 a couple of years ago and preferring my XP20 after a direct comparison (even with cables that were not re calibrated for the lower output impedance, and which aren't the issue anyway), I feel confident that I am making the right choice, for me, at this moment. If in a couple of years if there is indeed a new three box XP32 available, that may be worth considering too. There are just too many examples of former flagship products being surpassed by later generation technology. Magico has done the same thing a few times and I will soon find out if Pass has done it again like they did ten years ago in 2008. I would not be surprised.
From Reno's website:
The New PASS XP-17 single-chassis phono preamp (successor to the XP-15) is now in stock and ready for quick shipment.
In September-October 2017 the XP-22 (successor to the XP-20) is scheduled to be released by PASS.
In Fall 2018, the XP-27 and XP-32 (successors to the XP-25 and XP-30) are forecast to be released by PASS.
Beyond that, I hear you, but what they said in 2008-2009 may not be representative almost a decade later.
Based on the above and your claim that the 22 is better than the 30, then we would have two preamps, the 22 and 32, better than the 30. So why would then one spend the money for the 32, unless it’s so much better. None of this computes.
“In Fall 2018, the XP-27 and XP-32 (successors to the XP-25 and XP-30) are forecast to be released by PASS.”
Looks like I was right about being wrong.
My XP-20 is sounding so good now the XP-22 had better be a lot better. Of course if it is better then I will have to upgrade to the new Shunyata Sigma speaker and ICs. :)
Good Morning Tasos,
Those quotes from the Reno website are not quite accurate. For instance, the XP-22 was not released in Sept-Oct 2017. The first units are going out now in December. The XP-27, I was just told, may be ready by year end or early 2018, not Fall 2018. No word on the XP-32. I think the website needs updating.
Perhaps I was not clear enough in my previous posts. I am not trying to claim that the 22 is better than the 30. I have not heard the 22 yet, so I have no basis for making such a claim. However, you seem to be claiming the opposite. I simply thought carefully about which to buy and made a decision. There are two used XP30s available right now on Audiogon, and I decided not to buy them based on my conversations with Pass and Reno and on what I wrote above. Here are more excerpts of me specifically NOT claiming that the 22 is better than the 30:
From post #12:
Ack, why do you think that?...The 17 and 22 both have trickle down tech from the XS which was developed as a flagship after the XP30 had been around for a while. You may be right, of course, but I'm curious on what you base your assumption.
My comment that "You may be right of course" refers to your statement "I can not image that the 22 will be better than the 30". That is hardly me claiming that the 22 is better than the 30. I admit that you may be right.
From post #13:
...I am sure the guys at Pass have compared the new XP-22 to the XP-30. I have not heard which they prefer. It would be an interesting comparison. A used 30 is about the price of a new 22. If they sound similar, I would buy the newer design with one less box.
Again, I concede that they may sound similar, not that the 22 is better and that I have not heard which preamp Pass prefers, and that it would be an interesting comparison.
From post #17:
Again, the statements in bold don't make any claims as to the 22 being better than the 30. In fact, I clearly state that "I don't know which is better". Based on the past developments of Pass preamps, Pass may once again have decided to introduce a new line of products that surpasses the old statement product. I don't know if that is the case here, and to repeat, I am not claiming that it is. I have decided to audition the XP22 in my system under the generous Reno HiFi trial period and compare it to my XP20. If it is better, I will keep it.
Deciding to buy the XP20 over the then flagship X0.2 was the right decision for me at that time, and I am basing this decision in part on that experience and on the recent conversations I've had with my dealer and Pass Labs. If you are confused by, or don't agree with, that decision and want to learn more, I suggest you contact Reno or Pass directly and discuss it with them.
