coming back to this thread...i am looking at 2 options and would appreciate advice. To refresh: we have a Nikon D5100 (16mp, DX) and a Nikon 18-200 telezoom (good for what it is):
Option 1: Get Nikon 70-200 f/2.8 (VR 1 so about 8 years old...but direct from Nikon distributor with 18 month warranty)...700 bucks (vs newer 70-200mm f/2.8 which costs 2,200)
Option 2: Get Nikon 7200 (also DX, 2nd hand from Nikon distributor)...also about 700 bucks.
Option 3: Get both...keep just our 18-200mm lens.
I think Option 1 makes the most sense...and just sit tight and wait til, say, the new D7500 which is due to come out in June perhaps comes out 2nd hand next year.
We take few photos, always use 1 of the 32 pre-settings...but will take pictures of Maccu Pichu or Taj Mahal...and blow them up to 4 feet x 5 feet. We think for pure amateurs who are time constrained...the 70-200mm seems like a good bang for buck improvement. Thanks for advice!
- First it's a question of range Lloyd, 70mm is already telephoto range what are you going to do for your wider angles?
- There's no difference in glass between the versions only the electronics, VR2 is faster acting and can come in handy in hand held low light level shots or fast paced sport shooting, but there are techniques to overcome that if needed.
- The 7200 is a better camera than your D5100 but you'll notice more the deficiency of the 18-200 with this camera, but then again depending on your expectations YMMV.
david
Hi David,
Thank you! I specifically remembered and went back to your comments about the 70-200mm some time back. The vast majority of the photos we take that we care about:
- Blow up to 4 feet x 5 feet: Macchu Picu, Angkor Wat, Taj Mahal, Safari
- 'Hardcover story/picture books' of our travels which my wife likes to make as our coffee table books...portraits of us while traveling, plus the landscapes, safaris
We have our 18-200mm (27mm-300mm with our DX camera)...and find we use the zoom a lot because we are often quite far from our targets, or are taking them at night when its tougher to capture it with low-light. (We will keep this lens no matter what since its excellent for what it is and does.)
The advice we have received is that while both the body (Nikon D750 or D7200/7500) and lens (70-200mm f/2.8) will make an improvement, since body and lens cost the same...the lens will make the bigger improvement for us.
We intend to bring our camera and lens...take photos around the store, outside, etc...and then swap for the 70-200mm f/2.8 and if we really can see the difference in our shots, we likely go for it at the price and with the warranty. But if not, we probably save our money, enjoy taking photos with what we have which has produced some very nice coffee table books and 2 beautiful 4'x5' framed photos on our walls.
Hi David,
Thank you again.
1. I am sure better body and better lens will be...better. But candidly, I think we are buying the lens or the body, but not both...unless we are absolutely blown away by the combination.
2. As for taking photos around the store...yes, I agree. I hope they have a full-refund guarantee for at least a day or a few days to allow us to test drive. But just in case, we will take the camera outdoors in front of the store...shoot backlit trees, buildings, shadows, etc...and see what we see when we do the same shots with our existing lens.
Lloyd,
Hope all is well. I bought a Nikon 70-200 F2.8, the version before the FL that's out now. I use it and a Nikon f1.4 50mm with my Nikon 300s. I like you, debated lens or camera. I went for the lens b/c the new 70-200 had a price increase and I found a new 70-200 (non FL) for right at 2k. It's a big and heavy lens. Once your past that, it's spectacular with DX.
I'll upgrade my camera one day... the 300s keeps taking great pics especially of family and wildlife which are my normal subjects.
Net net, I'd go for the lens...You could also get a f4 70-200 and save. Not sure if I'll really use the lower light capabilities of the f2.8
Thanks for the advice...i always aim to buy once and buy right. For 700 bucks the generation earlier of your 70-200 f/2.8 seems plenty good for us. Of course we will try to do a little test driving with it first, but it sounds like a good thing to be doing and with an 18-mos warranty from Nikon's distributor, probably not crazy given their reputation for high build quality with this lens.
I know some people were not happy with the newer VRII version of the 70-200 F2.8 lens, it has a problem with focus breathing.
Thanks. BTW, you might consider the D7200 which would be a massive upgrade over the 5100 in every parameter. The extra megapixels would help your large blowups, and you'd still be in the DX world which means smaller lenses long range-wise.
Hi Bob...now looking into this as the prices have come down quite a bit...also looking at a 17-55 f2.8 second hand which is less than 1/3rd the retail price, (and possibly TC14E or TC17E 2nd hand...reviews from bythom.com and rockwell with 70-200mm f2.8 suggest extremely good results.) Thanks for your advice...have long kept the 7200 in the back of my mind.
Lloyd, have you ever tried the 50mm f1.4 or f1.8? vs the 17-55 f2.8? You don't get the wide angle perspective, but the 50mm is super sharp, great at any light, small and relatively cheap...
I've been quite happy with a 70-200mm and my 50mm. That's all the glass I have for now. I may get something wider down the road but after my experience with the 50mm will stick with a prime vs zoom...
Just a note, Thom Hogan(bythom) is a real authority on Nikon/equipment in general, Rockwell is not worth paying any attention to IMO. Make sure the TCs are compatible w/the 17-55 btw, it isn't a given that they are. They're generally designed for longer lenses.
FYI, bythom.com is still the umbrella for his sites including dslrbodies and sansmirror.
Hi Bob,
Here is a quote from Thom's review of the 70-200m f2.8 VR 1 we own incl the use of the TC14:
"...Performance with the TC-14e teleconverter is nothing short of astonishing. How good is it? Well, I can't see any differences between the 70-200mm at 200mm with a TC-14e and the highly regarded 300mm f/4 AF-S! That's both unexpected and unprecedented. In other words, if you need a 300mm f/4 AF-S, just get the 70-200mm and a TC-14e. You'll get a more versatile lens and lose no sharpness...
http://bythom.com/70200VRlens.htm"
Using a DX camera, the 70-200 + TC14 gives us an equivalent 147-420mm lens (since DX on a 70-200mm is already 105-300mm). with the 17-55m f/2.8 being effectively 25-83mm, then we are pretty much able to cover in 2 lenses a wide range from 25-420mm with quite high quality...more than great enough for amateurs like us. Its really about the photographer now!
