Lampizator Valve / Tube Rolling Review Thread
marslo
953
673
605
64
Poland
The matrix is even more complex if you add different usb/ethernet/power cables, hard and sofware of your NAS/server/transport, even without talking amps and speakers.
IMHO there is not one best valve be it power or recti for every setup.
Reactions: christoph
christoph
4,660
4,058
825
Principality of Liechtenstein
No, you are right, I didn't. I spent a lot of time just comparing the whole set of Tak vs the set of RK for these days. Just to mention, my rect. for PX25 RK is KR 5U4G (not the RK version). But your point reminds me to have a try with PX25RK+TA-274B. It might work as a better combo.
I prefer the RK KR 5u4g by quite a margin over the non RK KR 5u4g
The Taka 274b and the PX25 make a wonderful Combo :cool:
Reactions: sujay
christoph
4,660
4,058
825
RK PX25 is different from KR PX25. Anyway that is not my favorite tube either
Did you directly compare the two versions?
If yes, can you elaborate on your findings?
bonzo75
22,443
13,473
2,710
London
In Greg's system the PX25 were better than the RK PX25 though the latter were very good.
All I can add is the first time I heard only the RK, I thought I would prefer it to KR PX25, only after comparing we preferred the KR more. However point is that it was close and can easily change in another system. The best I heard Lampi KR PX25 combo was with Martin Logans in UK Paul's system. With concert fidelity electronics.
4,698
It will be my first post in whatsbestforum.
I have been reading all the posts according to Lampi DAC since I got my GG2. You guys truly helped me a lot on picking dacs and tubes, but I often got very confused with what Bonzo said about GG/Pacific and TAK tubes because it is opposite to what people I know told me. (...)
Essencially rectifiers are a very simple device - an heated emitting cathode and an anode in vacuum. Electrons are emitted by the cathode and reach the anode - nothing magic here. They do not have the switching noise of solid state devices, a good point. However each rectifier has a characteristic curve of voltage versus current and noise. These characteristics are easily measurable and can influence sound quality only in a simple mode, these devices are not in the signal path. They will however measurably change the DC high voltage of the device, something that affects significantly the distortion spectra of tubes as it changes their operation point. But IMHO there is little place for miraculous properties in this device - if you tap the rectifier and listen to noise in the speakers it is not due to rectifier microphony, it is due to pick up in the amplifying tubes!
IMHO it is very hard to conclude anything definitive on brands or models. I have seen large variation between samples of the same brand and considering that modern tubes are made almost artisanally we can expect high variations in their properties between batches. We can't forget that people swap tubes in these amplifying stages and each user will operate the device at different currents.
Just to tell I am not astonished that different people have very different opinions on the sound qualities of rectifiers.
BTW1 Nothing new here, all this has been said many times elsewhere.
BTW2 If equipment manufacturers wanted us to play with "rectifier sound" easily they would just connect rectifiers in parallel, allowing us to switch the number in use or simply change the high voltage supply.
Reactions: TKK
christoph
4,660
4,058
825
Thanks Kedar :cool:
It was very close, then.
Maybe so close that also another pair of RKs could differ?
Or another pair of regular PX25?
From my experience and from what I read, especially the 242 seem to have quite a variation from one pair to another... :oops:
bonzo75
22,443
13,473
2,710
London
Thanks Kedar :cool:
Yes I have tried mine against 3 others. We preferred mine but it did not work in yours like my first pair (which didn't sound as good in others as the one that didn't sound good in yours).
I think the RK seems to be a bit calmer than the KR PX25. It sounded great in the Pac at heihei where we did not compare to KR PX25, but then the 242 was just a few levels up. In fact giving up SETs horns, going full Lampi with 242, audionet Heisenberg, audionet stern and a compatible speaker of preference (say YG) with subs (because when the 242 is right it does its magic in subs too) is a great option, though expensive
christoph
4,660
4,058
825
At least in the Lampi DACs, you can easily hot swap recties if you are reasonably fast (within about 10 seconds or so) doing it :p:D
christoph
4,660
4,058
825
What 242 did you use at heiei's place?
KR 242 or RK 242?
bonzo75
22,443
13,473
2,710
London
bonzo75
22,443
13,473
2,710
London
Btw a friend is selling his KR PX4 quads. If anyone wants to swap 242 quads, or buy this in pairs or as a quad, please contact Sujay on this forum.
He is using the Lampi 45s in his big 7 mk2 which is keeping up, and at times preferable, to his AMG with zyx omega ultimate and vdh master signature strad into the burmester phono (I haven't heard).
Reactions: sujay
4,698
Unfortunately the stabilization time of tubes in equipment is much longer than that. I have not measured noise in rectifiers, but in some triodes noise only reaches the minimum after a quarter an hour.
I found this is a real problem when selecting tubes for noise in an analyzer - if we are not patient enough we risk discarding the best of the lot!
sujay
516
219
955
Singapore
Thanks Ked! Happy to answer any questions anyone may have. And indeed sometimes I do prefer the drive of the lampi, at least where it is now after the upgrade to Mk2.
iain
38
16
115
How are you finding the MK2 after the MK1 and what chip or R2R did you have originally ?
Reactions: bonzo75
Golum
1,805
2,552
405
Lausanne, CH
Hey Adam i just got those :cool:...lets see how they play...
EF0DFF89-0778-4AD1-ABB9-44EBB2238540.jpeg 6F864BDA-FA8D-41AD-9A53-7CD697CEFF8D.jpeg FEBEB6CA-8214-44A3-BF52-E0F8FBE2CD07.jpeg
sujay
516
219
955
Singapore
the mk2 upgrade is worth more than I had originally thought. The DAC is quieter, the soundstage is better, the dynamics are better and more importantly, the drive is phenomenal. I have the R2R. Apparently, Lukasz thinks the R2R is really special and he didn’t want me to change that to the newer chip/engine.
