There is a big DIY community in Canada on the DIY audio forum. If you visit a few of them, while you might end up listening to some bad stuff, you will soon find stuff far superior to the Odeon at much lower price, that can run on really low watts.
I'm not sure I want to go the DIY route for a number of reasons. I suspect that those would be some pretty big horns that wouldn't fit into my condo.There is a big DIY community in Canada on the DIY audio forum. If you visit a few of them, while you might end up listening to some bad stuff, you will soon find stuff far superior to the Odeon at much lower price, that can run on really low watts.
I also suspect that we have different preferences when it comes to sound. I, for instance, generally dislike Avantgarde loudspeakers. I've heard quite a few horns speakers and the Odeons were the only ones that have ever moved me emotionally. All the others have kept me from falling into the music because of some sonic colouration or aggressiveness.There is a big DIY community in Canada on the DIY audio forum. If you visit a few of them, while you might end up listening to some bad stuff, you will soon find stuff far superior to the Odeon at much lower price, that can run on really low watts.
A friend of mine ordered his Odeon 33 in double white:I'm deciding on colour now and I'm pretty sure I'm going to go with this colour scheme:View attachment 61528
I believe this is the larger model, the No. 38, but the No. 33 is very similar.
I never did consider the Viking -- the first I heard of it was when reading your thread just this week. Congrats on your selection as well.
I've demoed Trios twice but that was probably 15 years ago. Perhaps I'd like them now. I demoed the Duo Mezzo XD a couple years ago and did not like what I heard from that system.Sorry, I don't like duos at all. Trios are good for the bass horns, not their midrange and highs
I was thinking white matte enclosures with those almond-coloured horns. I find the glossy painted horns to look too "plasticy" for my taste; I like to know the horn is made of wood.A friend of mine ordered his Odeon 33 in double white:
White matte enclosures with high gloss white horns and they look fantastic
Fair point regarding the wood being visible but for my taste the high gloss horns give them a more modern look.I was thinking white matte enclosures with those almond-coloured horns. I find the glossy painted horns to look too "plasticy" for my taste; I like to know the horn is made of wood.
It's funny, I looked at Aries Cerat also. i had a problem with them because their on and off switch was on the back of the unit and would not be very accessible for me in my situation. Prior to me buying the Canary Audio Grand Reference 2's, I used to own the Raven Integrated Reflection MK2 tube amp. I thought it was super sounding and the owner ( Dave Thomson ) has some of the rarest and best tubes in the world. You may just want to give them a look or call Dave just for info.My current amplification is a Thomas Mayer 45/2A3 SET stereo amplifier. I tried it on the Odeon No. 26 but Odeons need more power -- 20 or 30 watts rather than 1.5 or 3.5 watts.
I used a Unison Research S6 (32 watts from EL34s in parallel, ultra-linear mode) and the sound with the Odeons was pretty fantastic.
One option would be to use that and modify it from an integrated to a stereo amp since I already own a preamp.
Another option would be to look for a different parallel single-ended EL34 amp -- preferably one that can be run in triode as opposed to ultra-linear or pentode. Mastersound makes a nice one but it only puts out 10 watts or so.
The Aries Cerat Genus amp, using 813s or 845s (I'm not sure which version sounds better) would be another option.
The Thoress 845 monoblocks is an option as is the Line Magnetic 503-PA.
Beyond that there is a whole world of other 845, 211, and other big-bottle SETs. Many of these, however, are beyond my budget.
I wouldn't say "itching' but I have been researching and listening for about 2 years. At some point one has to make a decision.So essentially you are saying we both don't like duos, you haven't heard trios for 15 years, you haven't heard Anima, universum, DIY horns, and we have different tastes? All those speakers are very different sounding, btw. If you just are itching to make a purchase, go ahead and spend a lot of like on the Odeon which is the least good sounding of all of them also less than many inefficient speakers, and doesn't work with your current amps. Or hold off from the purchase and investigate a bit more with the DIY community
The on/off switch at the back would be a real hassle to me as well. I'll check out those brands that you mention; thank you.It's funny, I looked at Aries Cerat also. i had a problem with them because their on and off switch was on the back of the unit and would not be very accessible for me in my situation. Prior to me buying the Canary Audio Grand Reference 2's, I used to own the Raven Integrated Reflection MK2 tube amp. I thought it was super sounding and the owner ( Dave Thomson ) has some of the rarest and best tubes in the world. You may just want to give them a look or call Dave just for info.
And I guess you want a nice to look at turn-key solution for your stylish condo and not some cobbled together monstrosity that maybe (or maybe not) might even sound a bit better but is not easy on the eyeI wouldn't say "itching' but I have been researching and listening for about 2 years. At some point one has to make a decision.
Yes, that would be one of the reasons I'm not excited to go the DIY route.And I guess you want a nice to look at turn-key solution for your stylish condo and not some cobbled together monstrosity that maybe (or maybe not) might even sound a bit better but is not easy on the eye
You need to post some of these DIY horn systems on your blog.
I'm adding the KR Kronzilla SX to my list of amplifiers under consideration.You should look at kronzilla
If I had the space for the Universum I would fly somewhere to hear them I think.
The other thing I wanted to mention here is that I primarily listen to rock and, from what others on this forum have said, the Odeons may be a better choice for that genre than either the Universum or Anima.
I've always wanted to love Acaplellas and have heard a number of models on a few occasions. For whatever reason, they just don't do it for me. I do love the plasma tweeter though.If you are near California, go see the Acapella/Audio note setup @ Audio Federation.
They have Apollon and Cellini horns in house right now.
