Lampizator Valve / Tube Rolling Review Thread
Tim F
125
43
113
Hey Golum,
Thanks for the reply. I've got these, just to have a play around....
Haltron 5R4GY which is my fav so far. Lacks some stereo imaging but is ok all round
Philips 5R4GYS, a forward sounding valve that to me lacks lower bass, so immediately impressive but not brilliant.
274B Shuguang cheap as chips :) but average
I have NOS Sylvania 45 with etched bases.
I can't run 300b as my GG2 does not have a setting for it.
Cheers, Tim
Alrainbow
3,256
1,430
450
Before you go down the set road buy one new recti. It’s the one tube that should be new or near new. The set outputs can be older as they are used at 10/20%
See attached for a few cheap recti to buy
Reactions: christoph
Alrainbow
3,256
1,430
450
Hey Golum,
Cheers, Tim
Show us the back of your gg dAc please
300 b tubes tend to be slower than a px25 is. The px 25 to me is a halfway mark between a 45 and a 300b.
The 242 while to be the fav does not work well in all LAMPI dacs.
But the recti is tube to set the pace so to speak. No matter how good a output tube is of the recti is old or just not a good choice a less then good sound is heard.
Alrainbow
3,256
1,430
450
Until you get one good recti and confirm it’s virtues don’t spend the money on exp recti or output
Shanghai sorry for spelling makes a good 300b mesh to try as is there 274b recti.
The large metal base one I linked is where we all should start if I’m asked. It works in all LAMPI dacs very well.
Reactions: Tim F
Tim F
125
43
113
Hey Golum,
Obscure q! I see the 242 has high gain, any idea if this'll cause problems going into an ARC Ref 3 pre-amp?
Not ignoring rectifiers but some of these are potentially available.
Cheers, Tim
Golum
1,814
2,577
405
Lausanne, CH
Tim i drive with this Ref6 and have no issues overdriving the preamp. Now this also depends on the output voltage of the DAC so you need to check this as well as i could not use this tube in gg1 for example...
Alrainbow
3,256
1,430
450
No I love the 242 it’s my fav tube
It just does not work well in all dacs / systems.
Tim F
125
43
113
Such a drastically different view to my amigo Golum. Can you elaborate? Cheers, Tim
Alrainbow
3,256
1,430
450
Not sure but here goes
The 242 tube is a fast or is a balanced sound. It’s only draw back is it’s high output and this is not always obvious. In fact unless you hear it done well you may write it off.
It can over load the preamp
But more importantly it can effect the sound making it brittle or tense long before or clips the pre amp. for this reason I’m warning others.
Now of your dac has a vol control it’s most easy to make it work
I hope this is what you needed to know
Reactions: iain and bonzo75
adamaley
588
546
228
Minnetonka, MN
I can attest to the virtues of the 242 rectifier. Alas, it overdrove and distorted at peaks in my system. If it works in your system, definitely prioritize giving it a shot.
Alrainbow
3,256
1,430
450
It is double the norm output voltage and due to its gain it peaks much more.
On another note the trp is much more tolerant and I’m loving it. It’s only down side is recti it’s all new and critical
christoph
4,689
4,075
825
Principality of Liechtenstein
Does any of you know if the Ayon AA62B output tubes can be used in a Lampi DAC?
christoph
4,689
4,075
825
Hey Golum,
Cheers, Tim
If the 242 works in a system despite its high gain, it really is a killer tube :cool:
Reactions: iain
christoph
4,689
4,075
825
