Not sure if their curves match the Japanese geometry and the vdH isn't the easiest cartridge to align visually this way, good luck!A Dr Feickert analogue protractor
david
I don't know enough about the Ikeda to know which curve to use also in one of his posts Shakti mentioned that Ikeda's geometry has changed since the early models that I owned. I can suggest something if you figure that out or if you have a protractor that came with the tonearm then I can have it plotted on an easier to use protractor.I'm glad you said it...that makes me feel a little better.
Can you recommend a more suitable protractor?
Feickert definitiv does not! work.
please adjust it with the overhang, according to the manual.
http://www.aaudioimports.com/UploadImages/Ikeda IT-407 Mounting Template-English-2012_1.pdf
Overhang is 12mm .
This is just the mounting template what we need is the recommended null points for this arm.
david
I'll try it and see.If you do 12mm overhang, the 0 points are just a function of the overhang.
should be like 66mm and 121mm
Eureka!Feickert definitiv does not! work.
Overhang is 12mm .
Thank you so much David. You called itI'll try it and see.
David
After a long wait for delivery, the Ikeda - specific alignment protractor arrived last week.
I needed to make a tiny adjustment to get the offset angle correct, but for the life of me, i can't get the stylus to centre on both null points. I feel I'm being really dense.
If the stylus sits perfectly on the inner null point, then i move the arm so the stylus is over the outer null point, now the stylus is slightly too far back in the headshell. So i move the cartridge forward in the headshell so that the stylus is perfectly on the outer null, then track to the inner null and the stylus is now too far forwards.
Basically the arc the stylus describes doesn't align with the arc on the protractor. It is close, but impossible to set perfectly. The requirements are contradictory. To get one null point aligned means unaligning the other
I'm really scratching my head. I've removed and reset the armboard, no change, on my AF 301 there is only one place it will go. I've loosened and retightened the two screws at the arm base that permit vta adjustment in order to get the arm stem sitting perpendicular to the armboard, no improvement . I've removed and reset the headshell, no change.
Listening i can clearly hear distortion, vocalists are lisping still.
Any suggestions?
I'm properly flummoxed
... My own previous experience with alignment of Ikeda tonearms was negative, I couldn't get perfect alignment across the record and had to setup for least compromise at either end but not perfect.
Any suggestions?
That would explain it Peter. I definitely moved the cartridge back last fiddle.Baffled, this sounds like what I experienced using the MINT LP protractor. Instead of moving the cartridge forward, you should move it backwards slightly. The protractor rotates on the spindle. If you move the cartridge back, then move the protractor in the same direction following the cartridge, the inner null point will move back a little and the outer null point will move back more because of the overhang. Eventually, the stylus will hit both. Keep trying until you get it.
I did the same, only with the SME arm base sliding forward or backward. This should do the trick. Good luck. You need patience. And it is counterintuitive.
In that case, i will revisit tomorrow, and perfect it
Thank you very much
Thanks to your advice i managed to get it dialled in perfectly some time around 4 this morning...I'll check it again in a minute since at that time of day my eyes were starting to goRemember, this works in reverse too, and you may have to go back and forth a bit. If you are on the inner null point, but ahead of the outer one, move the cartridge/arm forward a small amount, rotate the protractor forward (clockwise as viewed from above) and check again. The inner null moves forward a small amount to meet the cartridge which was moved forward a small amount, but the outer null moves more forward to meet the stylus. This will take some patience. Good luck and let us know if that works.
My gratitude is profound!
