How did this thread get from frivolous You Tube audio videos to a corpse littered Zu battlefield? Yeah, I'm bored, too.
I managed to borrow a pair of Odeon Midas.
Sounding very nice. Definitely not warm, soft, or romantic.I'll hook everything up tomorrow and have a listen.
I just realized that I've never ever heard Radiohead's "Street Spirit" without distortion. Until now.Sounding very nice. Definitely not warm, soft, or romantic.
Wow, you guys just don't stop.
I was wondering about the video. Is there something to be had, outside fun. My phone doesn't play them well.
Scale. I think I have scale at times. Then I sit in front of my friends theater 2x15 horn woofers and 12 cell wood horn. I am completely blown over. Oddly, it does some things great. Actually amazing. And others not. His room is also about 28 x 30 and he thinks it should be deeper by 20 feet to really fit the speaker. Then I harken back to scale in my room and really its all that fits in my house. It scales to my situation.
Been working over my amps. Flipping through tubes, footers, speaker placement. It hasn't clicked yet. I'm going to my tech's shop today to measure the cheap alps potentiometer at the swert spot and see about putting a Vishay foil resistor in its place. I also got some
V-Twist Cu24 using NO pigment for the conductors (completely no dye used), with UniCrystal OCC silver wire. I am replacing the old copper braid signal input wire too. Let that settle for a while and see how it sounds then.
Make a video...I just realized that I've never ever heard Radiohead's "Street Spirit" without distortion. Until now.
I get that. Showing they are pushing a ribbon. I'm sure anything can. Steve with Decware was saying his amp will run a dead short for hours on end. Says it will power anything. Then he modified his statement and said it would only reach a certain volume level, then peter out. In another set of comments he noted the amps will also clip and compress. So sure, I can see 2.5 watts push anything to some volume level. Whether its sonically the best that can come from the speaker is another question.
I have an itch to get a Decware amp and bi-amp my PAP Trio 15. The Black Shadow could do the 15s and the Decware do the horn. Rub for me is blending. I have been reading the recent TAS and the Eikon speakers. They have a dedicated room acoustic processor/active crossover. In the manufacturer comments the maker was noting the difficulty in active crossovers in the Martin Logan and how a passive crossover can blend better. Or so he said. It also rubs me wrong to take a vinyl or tape signal and turn it into digital. I have had people say they will build me a passive bi amping crossover, but its up to me to tell them the cutoff, slope etc. Yea, right. How the heck am I to do that. I bought a mini dsp but I was told I was stupid to think I could figure it out. Without say microphones and software to analyze what I was creating. Not really me.
I'd like the midrange to be more forward, warm, and dense. Perhaps the 300Bs need more break in. Or maybe it's the just the nature of the Midas speakers.Sounding very nice. Definitely not warm, soft, or romantic.
Sean fully acknowledges that. Happily, not the case.
So if I record my system and listen to it on my system, will it destroy space/time as we know it?
I've never tried recording my system, I have a LG V20, which has a high end DAC and decent camera... not sure about recording quality though...
No, I have done it and we are all still hereSo if I record my system and listen to it on my system, will it destroy space/time as we know it?
