My personal journey to MY SONIC LAB
shakti
1,437
2,383
480
Cologne, Germany
Just looking at a couple of your tts, AF3P & MS DDX1500 isn’t a question of differences in sound there’s a big delta in performance, abilities and quality between the two, how does this come into play when you’re tuning the cartridges?
My work horse to compare Carts is the TechDAS AF3P , the most of my other turntables are for collector purposes, like DQX 1000.
Please expand on this strategy. I realize tonearms, headshells and cables have a direct effect on final sound and very few are neutral. Are you saying that you play around until you a find a pleasing combination for a cartridge which may or may or may not be neutral? These decisions are system dependent as well and with an eclectic collection of gear such as yours where do you start?
I start with Cartridge and try to understand the DNA and the Designers goal of the concept.
For example, Matsudaira is voicing his carts with the material of the base plate and the house.
looking into the physics, any vibration frequency and energy, any resonance is changing, if they do a transfer from one material to another material. This is the main cause, that a Cart can be voiced with the usage of different materials.
( I know, that this is not new to you at all, but may be interesting for some readers)
For resonance control, the headshell has to fulfill 3 main objectives.
- The Designer of the Cartridge likes to have a energy transfer into a headshell material,
that supports his Cart voicing and the energy / damping needs of his Cartridge.
Y Matsudaira produces a MSL own headshell and he gives to his customer the code of the aluminium he is recommending.
P Ledermann likes wood headshells and tonearms with wood armwand,
so he is offering one under the Soundsmith brand a boxwood headshell
- The Designer of the Tonearm likes to see a headshell, which does not transfer too much energy into his tonearm,
also he likes to see a headshell, which is able to compensate the energy, which is coming back from the bearing to the headshell.On cheaper arms you will find between headshell und Tonearm a rubber ring to have an easy damping between Headshell and Tonearm
- every cartridge prefers a dedicated effective mass of a tonearm. The Headshell is the most easiest way to customize the effective mass
For this purpose I do have some different headshells available und choose the "best" compromise.
If you cannot choose from different headshell material to get the best match between Cart and Tonearm, may be , because you have a fix headshell, you can influence the energy transfer with different distance plates and mats (material and size).
Or you can choose a vdh Colibri, which you can order with baseplates made from:
- Plastic
- Titan
- steel
- different kinds of wood
- or even Amber
or you can choose a Koetsu with all kind of different bodies to meet your tonearm needs.
The combination of Cartridge, Headshell and Tonearm is a challenge and I like to try out different alternatives to create my personal best pairing or I like to follow others best practices, like the WBF
standard you have given to us:
- SME 3012R
- original headshell
- original wiring
- vdh Colibri Master Signature XGW (wood base)
The best match of Tonearm and Turntable continues the story.
You mentioned cable choices play a part for you too, MIT & NBS each have their own very strong characters and color, I can see throwing the latter in to boost the lackluster bass performance of the MS but on the AF3P and which one of your arm and phono combinations the boost becomes an exaggeration so you have to compensate yet with other pieces of gear.
Before I start comparing Carts, my set up must be tuned to play "neutral". For this purpose I prefer digital with less variables as a striating point. The set up must sound in balance, even when playing music from Tidal. I have often visitors and I do visit other people to listen to their gear. I tend to have, as a matter of personal taste , a little leaner bass and a more neutral (not warm) higher frequency voicing.
My speakers are like 2.5 to 3 meter from every wall, listening distance is nearly 6 meter.Listening position is nearly 2 meter from the rear wall.
Moving over to analoge, I do use the AMG Viella turntable, AMG 12J turntable and the AMG Teatro cartridge on the AMG/HRS M3X platform.
This analog "out of one manufacturer hand" set up should sound similar in tonal balance to my digital set up.
The AF3P has in overall a better performance as the AMG,
so the TechDAS turntable should show this with all compared combinations in competition to the AMG,
which is my "reference point"
I bring this up because of your last comment about making a Koetsu and Colibri sound similar so people understand that it’s not just a simple case of setup but you’re actually changing and coloring the sound to your taste otherwise the cartridges are nothing alike in nature or tonal balance. I’m not judging what you’re doing but pointing out that there’s a difference between assessing cartridges based on their qualities in a neutral setting and painting a sound.
It is difficult to answer, as it is indeed a short step between a neutral setting,
showing the character of a cartridge and to blend or to paint a sound.
One of the most controversy discussed cartridges are the Koetsu stone bodies. Some like them, some do not like, some feel just bored, some hear only coloration. But there are also some, who have heard them on a very high level, showing a performance, which is reflecting their high RRP.
Decoding their DNA as a nearly 4 decades old construction, designed in the time of heavy Japanese Tonearms, the birth of "High End" silver wiring and exotic heavy headshells
(like the contemporary ceramic Designs from SAEC, the heavy and robust Clearaudio Stability headshell and so on)
would lead us to combine a Koetsu stone body with such classic gear. But nowadays we are very much interested to measure compliance and effective mass and combine accordingly. So many Koetsu stone bodies ended up in light or medium heavy tonearms, like SME V, which is (at least for me) not the best combination.
Fitting a Koetsu stone body in an old Fidelity Research FR64 s or 66s plus heavy headshell (like Yamamoto Titan), maybe choosing the silver wire version of this tonearm plus "good" silver leads for the headshell will show a performance of the Koetsu Stonebody, which is far away from the peoples expectation. Showing dynamic, resolution, punch plus beautiful voices.
Is such a combination a "neutral setting" or is this "painting a sound" .
For me it is difficult to finally judge.
Many vdh Colibri users do have a problem with the tonal balance of the Colibri, being very prominent on the top end, casing a lot of sibilant problems on critical records if not properly set up.
Voicing such a set up into the darker side to get a more relaxing sound will please many Colibri users, but this is for me definitely "painting a sound" . The Colibri Carts are voiced with SME tonearms, so we can see this as the reference point. you can get them play warmer and darker, but than you are not listening any longer to a real Colibri :)
Unfortunately for many carts this reference point is not well known. So I love to visit fairs and to speak to Cartridge Designers about their Tonearm preference and reference.
Matsudaira is clearly saying in the MSL manual, that he likes stiff, rigid "simple" tonearms without exotic material usage to avoid any kind of voicing. But such a clear statement is not often heard from a cartridge manufacturer, as this might limit their sales potential.
shakti
1,437
2,383
480
Cologne, Germany
There are two different resistance/impedance values in play. One is the DC resistance (DCR) of the SUT's windings. This should be relatively well-matched to the cartridge's internal DC resistance in order to not affect measured performance. The other is the load impedance reflected through the SUT to the cart. Values of 430 ohms must be the load impedance. 31.5 Ohms could be either/or, but I assume to also be the latter. It's more sensitive because it has a higher windings ratio, which in turn reduces the reflected load impedance. Tuning a cart via loading is common practice, but selecting a SUT whose DCR is a mismatch for the cart is not the right approach. So, IMO, take the SUT-cart matching out of the equation entirely, and then tune loading to taste (exception being the Hyperion; see below). This is why simply selecting a SUT from the same manufacturer can solve problems.
The MSL Platinum has a very low internal resistance at only 1.4 ohms, and should be mated to a similarly low resistive SUT. Below 5 ohms would be best. However it also specifics load >100 ohms. This is a good place to experiment and find the best result to one's ears. When I heard the MSL Platinum, we were using a suitably low impedance SUT, and 470 ohm load.
The Hyperion has internal resistance around 10-12 ohms, and is ideally suited to a different SUT. You'll also not want to go higher than a 1:10, with 1:7 likely being the best bet with Hyperion. The MI inductance is very high, and measured response will be poor when connected to a standard 47k phono through a SUT greater than 1:10. Even at 1:10, we should expect some high frequency rolloff, thus the recommendation for ~1:7. At that point, no loading should be used with this particular cart -- the Hyperion. Since load resistors are typically applied as parallel to the primaries, they can only reduce the reflected load to the cart. You don't want this with Hyperion.
Thank you for your explanation, which exactly shows the problems of a proper step up combination.
Matsudaira recommends in his manual any transformer between 10x and 20x step up ratio. Murasakino and My Sonic Lab are offering 26db, 20x step ups under their brand. Both with slightly different technical data, but it looks like, that both do use additional parallel resistors.
I agree on Hyperion. 7x might be perfect. 10x with a parallel resistor does not work at all.
10x in direct connection works fine, but could be bettered, I am sure.
ddk
6,261
4,040
995
Utah
- Plastic
- Titan
- steel
- or even Amber
- SME 3012R
- original wiring
Decoding their DNA as a nearly 4 decades old construction, designed in a the time of heavy Japanese Tonearms, the birth of "High End" silver wiring and exotic heavy headshells
would lead us to combine a Koetsu stone body with such classic gear. But nowadays we a very much interested to measure compliance and effective mass and combine accordingly. So many Koetsu stone bodies ended up in light or medium heavy tonearms, like SME V, which is (at least for me) not the best combination.
Thank you for the thorough explanation Shakti, I can understand your process and your goals now.
david
maxson
4
David, I'd be interested to hear how you voice a cartridge or system in the same detail as Shakti has given. I know your goal is a "natural" presentation. How might this relate to what Shakti calls "neutral"? Do you take similar steps as he does to arrive at a "natural" sound?
Aj123
6
2
83
57
david
Is that a J Sikora reference turntable that you are using? How does it compare with the AMG Viella?
shakti
1,437
2,383
480
Cologne, Germany
J Sikora Reference and AMG Viella are different in sonic signature,
AMG is very vital, fast, dynamic (like Brinkmann Balance). Sikora is more rock solid, deep base, wide stage type
Reactions: Audire
bonzo75
22,447
13,474
2,710
London
BB is also rock solid, deep bass, wide stage. I have never heard AMG outside a hifi show. I have heard the Sikora reference a few times though never compared
Reactions: Aj123
shakti
1,437
2,383
480
Cologne, Germany
Today is a rainy Thursday in Cologne, the ideal weather to deal with the sound differences between the
- My Sonic Lab Signature Platinum
And the
- Murasakino Sumile
To deal with.
The choice for comparison much on the following tonearm:
- Glanz MH-124 S
The two pickups are in separate
- Acoustical Systems Arche L Headshell
assembled.
Turntable is the
- TechDAS AF3 Premium
The Tonearm is with a Glanz tonearm cable on the classic
- Jeff Rowland Synergy Phono Preamp
Connected.
Both pickups are very similar due to their design because they come from the same production line. If the base plate of the Signature Platinum is made of titanium, the base plate of the Sumile is made of solid steel, which makes the Sumile approx. 4g heavier. The sumile is still a bit quieter, but this reads on paper as a bigger difference than how it is felt when listening.
Mr. Daisuke Asai, the very young developer of the Sumile, worked and learned with Mr Matsudaira in the My Sonic Lab production for some time.
The idea has matured into its own pickup, which sees itself as a personal phrasing of the My Sonic Lab Signature Platinum approach.
If you want to compare these two pickups, the first thing you notice is how similar they are. If you do not mount the pickups precisely with regard to the critical parameters, you actually only compare the inaccuracies in the installation.
Luckily, the VTA and Azimuth can be precisely adjusted with the Arche Headshell so that the tonearm can remain unchanged with regard to these parameters.
After a few records in turn, the following characteristics emerge in the comparison of the systems:
My Sonic Lab Signature Platinum:
sonorous emotional voice reproduction, somewhat fuller basic tone, very musically involved, deep space, the details are transmitted a bit more reserved, rhythm & timing invite you to dance (I just got some new Tone Poet LPs from Blue Note, these "swing" wonderfully),
Murasakino Sumile:
sounds very similar at first, tonality is a little bit more on the neutral side, a little more precise, a little more details, a little more precise contours, a little less "swinging", with voices the articulation from the throat is emphasized more than the full tone from the chest.
The differences are really very small and have no relation to the differences that exist, for example, to a vdh Colibri or Lyra Atlas.
If you like to put the differences in a relationship, it is like sweetening your cafe / tea with white crystal sugar or brown cane sugar.
The difference between the two types of sugar will not change the original taste of the cafe / tea, but will give it a slightly different flavor.
So Asai gave the sumile the freshness of the clear crystal sugar on the way, Matsudaira the MSL Signature Platinum the somewhat more mature and full taste of the brown cane sugar.
Both are very close to each other and yet distinguishable in direct comparison.
However, I am not sure whether I would hear a difference between, for example, Hyperion and MSL or Hyperion and Sumile, which of the two pickups above described is currently playing in comparison to the Hyperion cartridge.
Tango
4,938
6,268
950
Bangkok
And the
- Murasakino Sumile
To deal with.
- Glanz MH-124 S
assembled.
Turntable is the
Connected.
Murasakino Sumile:
Although we have different gears, your description of the MSL Plat is pretty much the same way I hear it. It is like a very good idler tt.
Yakamozan
43
50
105
Jumping in with a question regarding the differences between the Eminent GL and the Eminent Ex ( not Ultra )
Would be nice to get some insights as i could not really figure out what is what and where the Eminent Ex places itself. Anybody who compared these two cartridges ?
shakti
1,437
2,383
480
Cologne, Germany
I had not the chance to compare the carts, but I did realize them during my research.
What I found out is, that GL and EX are basically the same!
Depending on importers wish, you can order the original Japanese portfolio (means the GL) or the Ex Export portfolio, which includes Eminent EX, Ultra Eminent EX and Hyper Eminent EX.
All specifications (Cantilever, diamond, coils, magnets, house, base plate) are the same
For the Eminent EX a different color scheme is chosen. The EX Version still have the colors of the former original Eminent.
I believe, that the EX versions are chosen from importers to safe their marketing price position and to avoid (or to identify) direct imports from Japan
In Europe both line ups are in the market, depending on the individual EU country.
The US for example is offering the EX Export line .
Reactions: CKKeung
Yakamozan
43
50
105
Many thanks for the feedback Shakti !
Aj123
6
2
83
57
Thanks Shanti, looks like like I made the right choice.
thx v much for the feedback, Shanti. I was considering the AMG v12, but chose the J Sikora max version with their Kevlar arm.. and the sound is just like how you describe it. :)
Reactions: Audire and shakti
montesquieu
269
417
148
Fascinating thread here and awesome info on the My Sonic Lab approach.
I have been really intrigued about the MSL cartridges ever since I picked up a MSL Eminent Solo Mono. This joined a largish stable of mono cartridges including 1.0 and 0.7mil Miyajima Zeros. While the Zeros have a solidity and coherence that I think is a particular characteristic of single coil mono cartridges, the MSL mono is an asbsolutely stunning performer, a much more a 'modern' sound than the Miyajimas, throwing a massive deep (and wide) picture and digging out more detail. I'm currently gathering info to do a write-up.
This experience has led me to ponder purchase of a stereo MSL ... my budget really only stretches to the Eminent Ex or Hyper Eminent - which from my experience with the Eminent Solo Mono should provide an interesting contrast to my current two main stereo cartridges, a Miyajima Madake and a fairly recently acquired Allnic Rose. The latter is currently getting most play time.
From the specification, it seems that the Ex has all the main characteristics of the more expensive models, without boron cantilever or, as seems particularly pertinent, the special materials used in body construction. Very little written up on these 'entry level' models though (if you can call £3k-£4k GBP entry level ... though I suppose it is in these parts!).
Reactions: hairyderriere
goldeneraguy
73
11
313
Shakti, Thank you for sharing your experience.
Your incredible knowledge and the ability to explain what you hear is amazing.
As music lover and happy owner I find the Sumile to be everything I would want or expect from a cartridge.
I look forward to your future posts
Reactions: shakti
Audire
1,479
1,830
330
FL Panhandle
Shakti thanks for this thread. It's a wealth of information for what I can expect in the near future. I have a J Sikora Standard Max w/ 2 KV12s arms, and MSL SP and Opus1 in bound. VAC pre as well. Come on December!
Reactions: shakti and hogen
shakti
1,437
2,383
480
Cologne, Germany
prior the High End Fair in Munich I like to stimulate myself with some analog toys,
I like to try the new Glanz MH-1200S tonearm :)
But some days before this arm arrives, a new cartridge was delivered, which I like to use together with this Glanz tonearm.
This Cart was missing in the time, where I discovered the different MSL ways to compose a cartridge. The
TechDAS TDC01:
- DC resistance: 1.4ohm
- Output voltage: 0.45mv
- Housing base: A 7075 alloy with DLC coating
- Housing: A 7075 alloy with DLC coating and damping
- Cantilever: A 2017 alloy
- Weight: 12g
As the Cart is much lighter than the TI sibling, I decided to go for a heavy Titan Headshell, the Yamamoto HS-5. Plus Yamamoto Titan screws plus the Yamamoto Titan finger. From my memory the TechDAS derivatives of the MSL theme were a little bit brighter than the most others MSL carts, so it became clear, that I have to change the pure silver headshell wires to some nice copper versions. I like the SAEC triple C headshell cables and gave them the first try together with the TDC01. You will see on the pictures the Dereneville headshell mat as well.
While I wait for the Glanz tonearm, I fitted the assembly to a Sorane TA-1 tonearm, which workes fine on my Basis Debut turntable.
Now this combination is getting some hours on :)
First impression is good, the focus is more on speed and information than I was expecting from an alloy cantilever.
Even with a similar cantilever more close to MSL Platinum than to MSL Gold.
Johan K
1,112
1,489
165
53
Sweden
Over the last decades I used a lot of different cartridges and it took me some time to understand, that many of my favorite carts,
even beeing from different brands (Supex, Air Tight, Koetsu, Miyajima) were from the same man (co) developed and produced:
Master Yoshiaki Matsudaira
It seemed, that he is mostly working behind the scenes, but with a lot of influence to the sonic Art of Japanese Cartridges.
I tried to understand his life for Cartridge Art a little bit better, and the following summary is what google is showing up in different sources.
(no chance for me to prove, so if someone knows better or more, please write a comment):
My Sonic Lab was founded by Yoshiaki Matsudaira in 2004. Matsudaira was no stranger to the Japanese Cartridge market. He started his career at SUPEX, whose Carts still enjoys a legendary reputation today. There he worked together with Yoshiaki Sugano, who later founded the Koetsu company. It is said that Yoshiaki Sugano especially loved the wooden case Koetsu and the first stone case Koetsu, the Koetsu Onyx, was significantly developed by his friend Yoshiaki Matsudaira.
During his time at Supex, Yoshiaki Matsudaira, probably together with Yoshiaki Sugano, fulfilled an OEM order for Luxman and developed a TA for Luxman. The project manager for this Luxman cartridge was Atsushi Miura, who was responsible for the tube devices and the Cartridges at Luxman. Atsushi Miura was also married to the daughter of the Luxman company founder ... but that's another story. Atsushi Miura was very satisfied with the development work done by Yoshiaki Matsudaira, and when Atsushi Miura left Luxman (which stopped producing tube devices in 1982) to found Air Tight, it was clear that he would take care of the tube devices but he also wanted pickups in the range that he ordered from Yoshiaki Matsudaira.
Yoshiaki Matsudaira was now full-time at Audio Craft and, incidentally, developed and built pickups for some Japanese companies in parallel. In 2004, Yoshiaki Matsudaira decided to found the company My Sonic Lab, which will continue to primarily fulfill OEM orders, but will also offer pickups under its own name My Sonic Lab. At the moment, many well-known pickup providers are among the "official" customers of My Sonic Lab, such as Transrotor (Tamino), Air Tight, TechDAs, Murasakino, etc. But some other manufacturers, at least in part, also seem to use MSL without publishing this manufacture, e.g. Koetsu, Miyajima etc.
Realizing, that I never had an original cartridge from the Masters own brand, I decided to buy a MSL cartridge.
As it should be at least in the league of the Sumile cart, it was obvious, that the decision should be done between the "Signature Gold" and the "Signature Platinum". As nearly no dealers in Germany do have both carts on demo , I spoke to fan boys and distributors. The out did recommend the "Signature Gold" as the warmer and more charming model of the two.
My current set up at home is well balanced (at least for me), so no need to shift the balance further into the warmer region, as even the more analytical MSL Siblings are are not as harsh or sibilant critical as others carts in this segment , so the decision was taken to buy the
Cartridge as the current MSL to product.
Matsudaira has sind decades the goal to reduce the moving mass of the coil in his cartridges. He is producing carts with a very small number of turns, resulting in low DC resistance numbers like 0,6ohm.
He is using a high permeability magnet, so still he can get out of the 0,6ohm cart around 0,25mv voltage.
The MSL signature Platinum has 1,5ohm DC resistance and 0,5mv output.
The classical MC Cart impedance set up, saying 10x up to 20x times of the DC resistance is the best value for the PhonoPre (direct connection, no step up)
would give a number of 15ohm to 30ohm impedance as best.
But the MSL manual is explaining in detail, that an impedance below 100ohm would kill the dynamic power of the Cart. And that even number up to 800ohm will work.
MSL recommends an impedance value of 200 to 300ohm.
For using a step up, the 10x or 20x types are recommended, which translates into a value of around 500 ohm or around 125ohm seen impedance for the Cartridge.
Since a couple of weeks I am using the similar Murasakino Sumile cart, so I tried a lot of different impedance combinations. So far no final recommendation,
as the value depends too much on the individual Phonostage in use.
With Boulder 2008 I prefer 200ohm, with Jeff Rowland Cadence I prefer the 250ohm value (which seem to be a 10x step up with parallel resistor)
It is said, that the very low MSL carts do like current amplification stages, like vdh Grail oder CHP P1.
Fitting of the MSL Signature Platinum was straight forward and simple, as the body is clean shaped and the diamond is well protected ( so no Colibri stress ...)
The MSL carts do follow fine adjustments with ease, so a first set up becomes very fast satisfying.
Fine tuning will be done after some hours of listening.
The TechDAS AF3P is now fitted with three carts in a similar price range, the
- Murasakino Sumile
- Soundsmith Hyperion OCL Signature
Listening to this 3 will become an interesting comparison, I will write about it in an separate thread :)
This thread about the MSL SP and the sonic performance will be continued after the "burn in " of the Cartridge.
View attachment 65548 View attachment 65547 View attachment 65546 View attachment 65549 View attachment 65545
Hi there Shakti,
Very nice indeed! Your turntable looks amazing?. I have the MSL P S here myself, for testing and reviewing how it would work in my system. It is mounted on my Kuzma 4point secondary headshell. Normally I have my Koetsu Blue Lace on the 4point, but as the 4point is very easy to adjust in every angle, then the 4point it was.
At the very first I did put the MSL P S on my SL-1200G, but I could not find the magic in that combination… so after a few spinn on the Technics if was off with a rocket-flight across the room an on to the 4point…
I thought it would be a ”no match” to get the MSL P S to rock like a groupie on the dancefloor… Ohh boy - ohh boy..!!
This cart really had me WORK for it.. It was not as strait forward as I was used to with other carts. I’ talking ofcourse of geting the magic out of the cartridge… To mount it on the arm - that was the easy part… real easy to be frank. The anti-smile came with the first record.. and I thought… ehh what the heck??!!
So tools - where are you, I thought…
So I started with very delicate setup process, checking all the angles, check the VTF, VTA/SRA.. checking the azimuth, checking the alignment as after 280mm Lofgren B, new collection on the WallyTools protractor.
Then I did all the magic stuff with my D’Agostino Momentum phonostage, in terms of gain-trix and loading-trix in respons to my preamp….
And what do you know….?… I cracked the riddle of MySonicLab Platinum Signature… and it started to sing for me…
Whhaaaooo - what a beautiful cartridge.. the compliance in the groove is amazing. It tracks the groove like a 1000% !! The background is scary quiet - black as the night.
It is not as bass powerful as the Blue Lace, but the midrange and the top end is just magic. I’ve found that it works absolutly best on acoustic music, voices and jazz in my system. Due to the very quiet background, classical music with very quiet parts in it, does not for some reason sounds that quiet anymore… it seems that the music sounds MORE… -even if it is a quiet part on the record.
Very cool feature indeed.
I highly recommand the MSL P S, but remember that it can be needing a little TLC before it let loose it’s magic ?.
Enjoy !
/ Jk 2ED49FC8-6EBD-468C-8A9B-4219572744C5.jpeg B50ADDD1-8193-4FB1-B6FC-E7C004078D6E.jpeg 519EABEB-4381-413D-B846-47C2F54089BE.jpeg 8F9E5D51-7C3B-4018-A321-5D95FAE25D05.jpeg
