Pacific dac: Lampizator's new top of the line dac
Golum
1,813
2,577
405
Lausanne, CH
Curious about one thing. I love not having to switch inputs for DSD/PCM and I have to watch for expectation bias. But there seemed to be way less difference between DSD and PCM. Not sure if PCM is way better or DSD lost something or was it the fact I wasn’t manually switching inputs to play one or the other. But I really used to notice the difference between the two. I guess I can put a playlist of same songs in both DSD and PCM and see what I hear later.
Congrats on your new Pacific!
Regarding DSD vs PCM reading others impressions as well my personal case is that Lampi made a massive step up in terms of PCM playback and hence you hear what you hear.
Which tubes are you running in it?
Have fun and enjoy it anyhow.
Cheers;
G
howiebrou
2,794
3,649
1,470
So just got my new Pacific today which was nice surprise. It was a bit sad to start to pack up the GG and some sudden buyer’s remorse. Maybe I should have stay with the copper top and not go gold. Maybe I should have gone balanced like my GG was instead of SE like the Pacific is. Etc etc. This is my 3 Lampi. It’s amazing to me how much progress Lampi has made with producing a polished product and nothing to do with the sound.
No serious listening yet. Just some easy to listen to music. Reality is my system has undergone a ton of changes and more changes to come. Right now it is more of headphone listening setup than anything. In any case, I noticed right away that Pacific seemed to convey much more energy. Tamacun by Rodrigo Y Gabriela came on. WOW, that got my attention. It was pretty amazing.
In any case, hopefully more time this weekend to do some more critical listening. But more likely going to let burn in happen and try to reserve observations before then.
Congrats! What rectifier and power tubes are you using in your Pac?
Crashem
92
38
148
I actually have a boat load of tubes to try For both output and rectifiers. For now I am using the rk px25 and rk54ug.
questions:
1) which setting should we275a be at?
2) which setting for 2a3? I have a ton of different ones. Worth trying?
3) the 6n6p tube: do we know which is included? I see it is a military tube with okt label. I have buddy who is little dot amp crazy and he recommended a few to try. They are so cheap, I went crazy on eBay earlier. foton, nevz, red tips, 60,70,80. Hell I almost bought a 100 pack.
Reactions: christoph
Zero000
2,987
1,141
478
I think Lampi dropped 2A3 support some time ago. So the Pac doesn't do it.
My ultra massively modded Lampi Big 7 does it, though. But TBH my 2A3 collection could do with some work. I only have cheap Psvane and Electro H options. Though the gold grid Electro Harmonix does sound surprisingly good for its cost. Definitely not top league, though.
Pst... it's OTK.
Reactions: Alrainbow
Golum
1,813
2,577
405
Lausanne, CH
1) never heard anybody using we275a so maybe best to check with Lampi directly
2) 2a3 not usable in Pac so better avoid plugging it in
3)6n6p as used in Pac I’m not really sure it influences the sound at all as used as active anode load but if you have many just swap and write your impressions. I have few at hand as using them in my ARC gear instead of 6n30 - have some 6n6p with silver screen and apparently those are very good/best
Cheers,
G
Crashem
92
38
148
3)6n6p as used in Pac I’m not really sure it influences the sound at all as used as anode follower but if you have many just swap and write your impressions. I have few at hand as using them in my ARC gear instead of 6n30 - have some 6n6p with silver screen and apparently those are very good/best
Cheers,
G
thanks for the info.
i used the we275a with the GG. I forget but someone was pushing them for GG at some point.
Crashem
92
38
148
Hmmm. Sounds like I need to bring a pair of 242’s in house. I see there is both a KR and RK version. Any reason one vs. the other?
christoph
4,688
4,074
825
Principality of Liechtenstein
I first had the regular 242 in my (ex-)GG1.9 and they were the perfect match :cool:
Later (with my Pacific) I got the RK 242 and gave away the regular ones, so not a direct comparison, then :oops:
But from memory, I would say the regular 242 is a little more "brutally" transparent with a little more gain and the RK 242 is a bit more refined and has a tad less gain. This is with a pinch of salt, obviously.
Reactions: Alrainbow and Golum
Zero000
2,987
1,141
478
For the rectifier I use the Special Edition
RK-KR 5U4G
i also have a pair of the Special Edition RK-KR PX25 and have yet to use them as the standard KR242 is killer in my system
FFS just plug them in man! How hard is that?
Get with the Lampi spirit. It's ALL about adventure!;)
You don't know what you've got. Really.
Reactions: howiebrou
sbnx
1,207
1,361
290
What do you guys use to polish the top of the pacific? I have used a dry cotton rag and microfiber rag but I can't seem to get rid of the "marks" left by the shrink wrap that it came wrapped in during shipping.
howiebrou
2,794
3,649
1,470
I asked Lukasz and he suggested ethanol or lens cleaner solution. I am.having a similar problem getting rid of fingerprints and a bit of tarnishing.
Tuckia
474
732
180
Sorry, I’ve been out of the loop for awhile. You decided to order a Pacific. Congratulations.
Curious what your thoughts are.
I ordered mine with a copper top, a last second change. No residue, no clean-up, and no tarnish.
howiebrou
2,794
3,649
1,470
Doesn't copper tarnish more quickly than gold?
Golum
1,813
2,577
405
Lausanne, CH
Nope in this case as it’s lacquered and hance protected - isn’t this the case also with gold top?
bonzo75
22,647
13,676
2,710
London
