Pacific dac: Lampizator's new top of the line dac
the sound of Tao
3,620
4,838
940
Guys I really do like you both, but please go for a beer/fish&chips/curry and discuss things you have to discuss as this ping pong is kind of pointless and disturbing for many ;).
Thanks for understanding
I do love fish and chips and sashimi and a Goan curry would be awesome but I must admit I did hurt my neck following the ping pong on this one too closely.
Reactions: bonzo75 and Golum
marslo
953
673
605
64
Poland
To be honest I also prefer the real ping-pong game . It is also because I have beaten Ked 2:1 who was a demanding partner though;)
Finally Grandpa Mario won ;):)
the sound of Tao
3,620
4,838
940
Biting Ked is not a good idea... Goan curry is more spicy!
Reactions: bonzo75 and marslo
bonzo75
22,435
13,467
2,710
London
Did you not give me wine before game?
marslo
953
673
605
64
Poland
Tuckia
471
729
180
I finally got around to trying a pair of RK 242 in my Pac. Can't say that either of my preamps overloaded, but I just prefer the sound of the RK PX25 in my system.
So, I will let this pair go if someone wants them. About 70 hrs. on the clock. Send a PM if interested. Due to ongoing shipping challenges, US only please, unless you can endure the risk.
Greg
bonzo75
22,435
13,467
2,710
London
Greg
Check with Jazzhead. He was looking for one. Will tell him to contact you. But he is outside US. Btw, RK 242 is different from KR 242. In fact all RK and KR have their own characteristics
Tuckia
471
729
180
Thanks Ked. So maybe I'll need to score some KR242 as well.
The RK 242 and RK PX25 aren't too different in dynamics, but tonally I found a difference. The RK 242 have more of an upper mid-range presence and the RK PX25 being more grounded in the lower mids. This is with the Allnic L9000 OTL/OCL which is quite dynamic on its own. This pre really continues to impress and I might just have to keep it. I've had it 5 weeks now and has finally settled in. The first couple weeks were a bit bright.
bonzo75
22,435
13,467
2,710
London
I meant that RK vs KR for the same valve (242, PX25, 300b), will be different. So if you tried RK PX25, you will need to try KR PX25 as well
Tuckia
471
729
180
Well, I have (3) pair of KR PX25 coming in next week! Finally.
Reactions: bonzo75
christoph
4,659
4,058
825
Principality of Liechtenstein
Greg
Give them some more hours before you finally decide
sbnx
1,176
1,314
290
Funny that you ask. I went looking for that same thing last week. All I found was that it is low. I guess it should be pretty low as you can drive an amplifier directly form the DAC.
Maybe someone know the exact output impedance.
Crashem
92
38
148
haha I was assuming it was high since tube output. But knowing the impedence for both se and balanced would be great
Golum
1,805
2,552
405
Lausanne, CH
If there is no data in the supplied tech spec then LF only for that info...
sbnx
1,176
1,314
290
Here is what the manual says. So given that you want the outputimpedance about 20X lower than the input of the next device perhaps it is pretty high at maybe 1KOhm.
The DAC with volume control should sound audibly cleaner and more direct without any preamp between the DAC and the amp. The preamp, however good, will veil a lot of the DAC’s natural clarity, speed and directness. If you feel you need the preamp nevertheless, use DAC at the full volume or order your DAC without volume module. The load presented by the preamp or amp or simply the next analog component that the DAC sees, should be as high as possible. It is measured in kilo-Ohms and 100Kilo Ohms is a perfect ballpark value. More is VERY rarely seen. 47 K is next common value, and it is great too. 20 K is kind of on a low side, but we can handle that. Lower than 20k is bad news. We must configure the DAC with additional cathode follower buffer stage. The DAC will not be damaged in any way, but at around 10K of load the dynamics of the dac will start to fade away. Having said that - every properly designed amp or preamp keeps the load value above 40k. And if it doesn’t - we simply don’t choose such amp because it was not designed with audiophiles in mind.
Alrainbow
3,189
1,387
450
Lol such an old question you ask. It’s not low as less then 10 ohms it varies based on tubes you use. somewhere from 200 to 1500 ohms. it’s why I would not use a passive preamp. doing so just adds more to limit dynamics. not saying it’s like this for all but seems to be for me. how this helps. Why did you ask ?
Correction made
Alrainbow
3,189
1,387
450
Don’t use the dac at full volume always. It’s far better to use the vol into pre to balance tone. you may find a sweet spot that gives speed and dynamics but tone or weight you need. If left wide open it’s thinner but best dynamics
most use this at 8/16 Higher numbers adds more weight Right up loss of some Dynamics. a good active pre yields better dynamics then a passive or no preamp. But while this is factual adjusting it is system dependent
Reactions: adamaley and Golum
Alrainbow
3,189
1,387
450
I beg to disagree on the no preamp is better. If no premap is better there should be an under lying cause. Perhaps amp can’t produce enough power for a given speaker. adding a gain stage for me always seems to be a benefit not a loss. A vail is odd to me but again possible other causes here.
Reactions: adamaley
