Clear Audio Double Matrix questions
labjr1
33
10
8
60
I currently clean my albums using the Clear Audio Smart Matrix Pro (very similar to the VPI HW1). I buy a lot of used albums as well as new and I clean everything before putting it on my turntable. I use the AIVS 3 step process and have had great success. I am considering moving to the Clear Audio Double Matrix Sonic RCM to speed up the process and to add sonic cleaning capabilities. The ability to clean both sides at the same time appeals greatly to me. However I question if the process is as effective as the 3 step process I use. I don't want to trade speed for lower quality. What are others thoughts on this? Is there a better solution instead?
amadeus
312
380
255
I use a Clearaudio Double Matrix Sonic Record cleaner since 6 months know i have cleaned in the mean time more than 1000 LP i also clean the new Lps and i am very very happy whit it its build as a tank very easy too use it makes acceptable noise and is very fast the ability to clean manual or 3 automatic programs is also a bonus i cant think being whit out this machine!
Reactions: labjr1
labjr1
33
10
8
60
Thank you!! That is what I wanted to hear. I will place an order tomorrow. If it saves time it is worth the investment. Time is the one thing you cannot make.
amadeus
312
380
255
Get it and enjoy it!
JackD201
1,427
1,820
Manila, Philippines
Yes, I use a double matrix as well. My only piece of advice going forward is to add cleaning fluid in quantities that you will immediately use. The reservoir does not keep the fluid from evaporating. Fluids are best kept in their bottles and following storage instructions anyway. Enjoy!
mulveling
234
335
168
Double Matrix Pro Sonic here. Love it, but yes its main value is for speedy cleans during listening sessions without interrupting the flow of things. In theory I'd like the option of multiple fluid tanks so I could do 3-step cleans, but in reality I'm not sure how much I'd use that since I hate doing dedicated cleaning sessions that involve much manual intervention. I find it does a superb job, but I only had a VPI 16.5 before (which I absolutely HATED using, and found myself skipping cleans sometimes which is a big NO NO for stylus wear). It's a dream to use - a single button press then something like 90 seconds for a normal cycle, which thoroughly cleans all but the grimiest records (plus a few optional spins under the carbon fiber brush for static). Then there's a quick clean mode which is great for touch-ups after the original clean (uses only a minimal amount of cleaning liquid). And I only occasionally use the double cycle for the really nasty stuff. I've always used AIVS No. 6 one-step solution here. Yep, keep a lot of it on hand because you can end up cleaning a LOT of records quickly!
The best feature is it takes a formerly dreaded task (for me) and makes it a nice relaxing (and cool to watch) part of the vinyl ritual.
wbass
175
94
93
44
Curious if anyone's still using a Double Matrix (Sonic or non-Sonic)? How is it holding up? Any usage tips or tweaks or issues? Wondering if the underside stays wet or drips too much for the double-sided cleaning to be useful. Thanks!
Hydrology
104
147
98
50
Ive probably done at least 8,000 records in mine ( I offer cleaning as a service in addition to my KLAudio ULtrasonic machine).
Works as good as new. The "only" issue is occasionally the LEDs that register how full the cleaning tank is, are slightly incorrect, and sometimes the underside of the record doesn't quite get the same level of cleaning fluid as the top, however for me this is a non-issue as I generally manually flip anyway tro check status.
Reactions: wbass
JackD201
1,427
1,820
Manila, Philippines
I still use mine which must be undergoing puberty by now.
All the records I've bought were already very well cleaned by the sellers or were sealed. This cleaner therefor never really had to do any heavy cleaning.
My only bit of advice is to fill the tank partially to save on cleaning solution. I was so excited when I got it I topped it up. Since my records are all pretty clean anyway, over time it just dried up.
Reactions: wbass
wbass
175
94
93
44
Good to hear. I've got a Pro-Ject VCS, a Loricraft PRC3, and an Humminguru ultra-sonic. But I've got several hundred used records to clean, and, realistically, at the end of the day, when I just want to play some tunes, I want to just pluck something from the shelf and have it clean and dry and ready to go in a couple minutes.
I'm thinking a used Double Matrix Professional (non-Sonic) would to the trick. Yes, no auto clean, but it just seems to be a matter of a couple more button presses? And maybe the lack of the "sonic" cleaning isn't a huge loss?
How quiet is the Double Matrix?
The VCS and the Loricraft are fine, but the VCS is loud, the Loricraft slow. I might end up selling them. And keeping the Humminguru when a deeper clean is needed.
Just thinking aloud. Many thanks.
