Congratulations with a beautiful TT ! How stable is your Roadrunner speed reading compared to the modded VPI setup ? Where you using the BLDC motor with a version of Bill Carlin’s DIY 3 phase controller ?
Looks close to perfect ! But the most important aspect is the sound anyway, the momentum of the flywheel is probably part of that great sound.hi, the BB is using a four phase motor with 500 grams flywheel. considering that there is no Speed feedback and auto speed correction the speed is very stable (see video Below )
I wanted very much to use the BLDC Rim drive but it’s incompatible with the height of BB. I have searched the option to have a BLDC pod fabricated to match the Balance’s belt groove and again it’s very difficult.
Check the Balance’s speed stability here:
the Balance’s speed stability is reflected through the AM wow/flutter measurements i made, which are really low for a belt tt:
Dear BrianThe bearing is superb as well, and I wonder about the contribution of the heater. I suspect it does make a difference.
I'm also a bit interested in the function of the flywheel at a few hundred grams when used in conjunction with this massive platter of, what, 20 kg or so. Did Helmut explain it?
Would love to see another AC TT being measured using the exact same software.
My sense is that the less vibrations/resonance the better...
http://www.vpiforum.com/viewtopic.php?f=7&t=14369
Pretty darn good. I would imagine you could get it even better with a feedback loop if you can get the Eagle/Condor/RR to work with the Brinkman. Should be able to get it to approach the Technics 1200's wow & flutter of +/- 0.035% peak, although that is measured under IEC 98A weighted, while AnalogMagik measures under AES 6-2008.
That's great speed stability. I have a TW Acustic Raven Anniversary (belt drive) with the 3 DC motor (single unit) hooked up to a Roadrunner speed tachometer. It's a somewhat higher mass design than the BB. I do notice more speed variability until the turntable runs for a half hour or so. The heated bearing design of the Brinkmann is certainly a worthwhile design characteristic.
Once warmed up, sometimes it's stable, but I generally see more variation, + or - .002 over a 20 second period than your showing. Don't have AM (yet) so have no other numbers. It's possible I might get more stability with the battery powered version of the motor controller, but I don't really know. Maybe someone else can chime in.
I am speaking with Marc Gomez for some days now for a SAT tonearm, among others he wrote me ....The CF1-09 on a Balance will be one of the best sounding combinations available today....
