A very fun report, Kedar! Thank you!
Kedar, Bill: A whole 'nother vinyl playback variable? Record clamps -- different brands; different sounding models by the same brand?
So, after carefully setting up the turntable stand, the turntable on the stand, the tonearm on the turntable, the cartridge in the tonearm TIMES one or two or three or four completely separate record-playing systems TIMES two or three or four tonearms per separate record-playing system, THEN, depending on musical genre preference, mood, and alcoholic versus non-alcoholic beverage of choice, selecting which cartridge on which tonearm on which record-player, THEN selecting which phono stage to use . . . THEN adjusting VTA for the thickness of the vinyl, and THEN selecting the brand of model of record clamp?
Are we sure that being able (or required) to make a dozen different decisions before dropping the needle is fun?![]()
My friend had his brinkmann on the wall shelf. Recently he put it on a normal hifi rack due to some room adjustment. The Dalby is more important.
But why does a number of variables in analog surprise you, that was always the case. What you use to align your tonearm, which head shell, which screws, which cleaner, destat, etc it never stops. Some stuff has more substitutes than others
