Personally I’d do nothing until TAS is available and I’d follow that pathI'm not going near that upgrade until Emile tells us he has a fix for any SQ loss.
Could you plese be do kind to share a little more details about this card , softwere and pictures if possible and only if you find a spare time that I am sure will not be easy.
(...) On to the USB card project: (...)
Can I ask what is the purpose of this card?
Now, all that would make things 100% perfect instead of 99.9% would be that Extreme Mini...
and an Extreme Turntable...
I have faith in you Emile.Even extremer then what's out there already?
I'll disclose it has over 200 parts and is big for a PCIe card at about 3x10", I'd say worthy of the Extreme moniker
Next project a Taiko DAC to fully control digital including it’s conversion to analog?Nearly total control.
Can we call that a Taiko Audio Network Music Habitat?
Big congratulations!
i’ve been suggesting that to Emile for some years now
I just updated to “Build 667” and music is still sounding enchanting, engaging, (add other superlatives here). Has anyone else done this and what was your result?
It looks like fantastic solution for extreme owners .
Cant wait to install it in my system, but it sounds like it will take few more weeks to be ready.
I understand you tested it against the Jcat XE ?
Also 1 or 2 usb exits from the card ?
External power from reserved Extreme rails are planned or separate power supply will do better job ?
I did not do a direct A/B comparison. However I can say the Jcat XE card is very good, though does not work optimally with the Extreme in stock form. It did provide a noticeable improvement in transparency after a modification to work from the Extreme's internal power supply. We did discuss with Marcin to have a modified version for our use but the economics did not work out what made us decide to embark on this project. In hindsight I'm happy we did as it was again a very valuable learning experience and there's absolutely merit to being "in control" ourselves.
1 USB port.
Internally powered does a better job, but of course it's designed to work best that way (not a fan of external power supplies with separated ground planes btw). It needs both 5V and 12V.
It will be available for non Taiko customers too ? any idea how much will be ? Thanks.
