I'm sure it's around here somewhere. To be honest I didn't need instructions. The dealer walked me through the process just once and I did it all by myself from that point on. Here's the process.
1. Take the arm wand and screw on the cart firmly but with just enough pressure so you can move it about.
2. Insert the cart bolts in the slots on the alignment jig
3. Flip the clear panel over the stylus
4. Move the cart until the stylus tip is on the marker and the cantilever is aligned with the vertical lines
5. Tighten
That's it
Oh, but before putting on the cart, you need to get the right spindle/pivot distance when mounting the arm on the board. To do this there's a plastic piece that goes on the spindle. Move the armboard , I'm assuming you'll be putting this on your new CA
, until the designated hole on the wand accepts the nub sticking out of the plastic thing that looks like a thimble. Tighten everything up and that's done too. Also extremely simple.
