Analog Magik
So this is same cartridge only different VTF, ? Cartridge? Arm ? TT?
Yes, same cart, arm, and TT over a few days. Adjusted everything else (VTF, Azimuth, and Zenith,...)
And I see a typo in my chart. The last VTF was 16.55 g not 16.15g
good review with data
I use V1 and one of the most useful things I find is adjusting Zenith using the VTA track. Adjusting visually to begin, I typically start with 8-10% distortion. By making teeny, tiny twists or the cartridge I can usually get this down to around 2%. I know this is not a revelation as I have seen it mentioned back in previous posts, but I didn't see where the author of this article mentioned zenith.
He did mention the lack of meaningful results with the VTA tests. However, he doesn't show any use of the VTA tests. Perhaps he did not get any meaningful measurements with the VTA adjustments because his zenith was too far off?
I’m using the RME ADI-2/4 Pro with AM software instead of the ART USB. It’s quieter and better in every respect compared to the ART USB. The biggest issue with the ART USB is its potentiometer—it doesn’t track channels equally. Additionally, the ART lacks the precision that the RME provides, which is clearly reflected in the results. Now, I can see very slight differences in measurements when I make small adjustments to a parameter—something I couldn’t detect with the ART.
Reactions: tony22
At ten times the cost I should hope so! :)
But seriously, I’ve wondered if something more pedestrian like a Creative Soundblaster Pro would be slightly better than the ART.
Reactions: mtemur
Great idea... makes sense but seems there should be a good candidate in between the $125 ART and the $2500 RME (I know street prices are less. There are a lot of high quality pro audio interfaces a lot less than the RME.. Impulse bought a used Apogee Duet 3 on Reverb for < $450 all in,. Apogee is a great company, a decent DAC too
I’m sure there are excellent alternatives to RME.
That said, I didn’t buy the RME solely for use with Analog Magik. I primarily use the RME ADI-2/4 Pro SE for vinyl ripping, and in my opinion, it’s an outstanding mastering-grade converter. I’ll admit it’s a costly choice for this kind of task, but it’s what I already have on hand. Some key advantages of the RME include:
- Exceptionally low noise and high accuracy
- Built-in spectrum analyzer, which helps me pinpoint the start of a test track—important because I always aim to measure the exact same section, typically the beginning
- Independent channel trimming, useful for compensating for cartridge or phono stage irregularities that could affect measurements
- 50K analog input impedance, which is close to ideal
- Built-in RIAA phono stage that works well with MM cartridges directly and with MC cartridges via a SUT, minimizing variables introduced by external phono stages
Agree, I use Parks Audio Puffin directly with a Toslink 24 bit/96k to usb converter to PC. Works better than ART which tends to freeze the PC at regular intervals. Puffin is my RIAA, but also a fantastic diagnostic and set op tool for vinyl, a Swiss Army knife.
Now you get Waxwing that cost 499 usd, the Hifi-ME Toslink-to- USB is cheap. Make sure you order that and not USB to Toslink.
If you do not want to skip your RIAA Waxwing works with line signals too so you can put it downstream your RIAA
It should be noted that for anyone in the U.S. purchasing from the linked site, while it ships from a NH location the payment (in US dollars) is still a foreign transaction. I did not see this mentioned anywhere on the site before purchase. It may matter to some depending on the form of payment used.
Yes, I’ve had one for a while.
Reactions: Balle Clorin
For music or Swiss army stuff?
The latter. It’s an interesting enough toy with the built in tools but in my estimation, sonically, it is no match for any of the better phono stages I’ve tried (Pass, DS Associates, MF Masterphono, others)
No - Dynamic Sound Associates. A very small company with next to no visibility in the modern world of rapid pace online audiophilia. The owner and designer, Dr. Douglas Hurlburt, produced a series of Phono stages that (for at least the two that I've heard) are rather remarkable in their ability to create wonderful music from a cartridge. There are online reviews available for both the Phono II and Phono III.
I put them on my test bench and compared the ART to the Apogee Duet 3 I just received. The ART showed .1 to .4 difference on the Analog Magik meters depending on where the pot was set. The Apogee always matched.
Hopefully AM won't lock up with the Apogee like when I'm using the ART, and was never sure the issue was the ART, but haven't played with it enough to declare that it doesn't.
Reactions: mtemur
I wonder why the AM antiskate tracks are so low in level. 4.8db lower than the lowest antiskate track on the Ortofon record ( 50um).
certainly no match to track AM33 V2 antiskate track... Maybe there is is an objective I do not know of
I recommend using antiskating track on AP test disk. It’s much louder
Remember the arm resonance at 82Hz revealed by AnalogMagik V2 pink noise in post 611?
Well I got rid of it, the cause was an un-tight screw!!! I notice by accident as I adjusted the VTF.. sometimes luck helps..
The resonance is not revealed in other pink noise and sweep tracks,except Denon XG-700x 5-500Hz slow sweep.
I was so unhappy with the 82Hz bug that I considered getting another turntable, now thanks to AnalogMagik I solved the problem. The Denon 51F stays.
BTW which software do you use for frequency response graphs?
Balle, I want to make sure I understand. You used the Denon 5-500Hz slow sweep, but which AM v2 measurement did you use with that sweep?
None, I record the AM V2 pink noise track to PC. , and import file into REW.
For some unknown reason this track is more revealing than others,
The Denon 5-200 hz Track may be used too but AMV2 is more revealing
Reactions: tony22
