Impedance match will have nothing to do with it.Depending on the Phono stage used, some of the difference may be related to the different Impedance match.
He had specifically designed the later colibri strad to increase the previous one's output from 0.38 to 0.7. You mentioned that in the Pass you found the MS better, from the posts you made then, IIRC. You have now since getting Lamm reduced the output.
It is possible you have a very good XPP sample and a different MS sample. Given his inconsistency I would not make a call or new vs old. Mike owned about ten of them and always searched for the magic in one of his older colibris that he never found again.
I don't think output alone has to do with efficient system, given that western electric and living voice both used high output ones, and tang had a 0.5 that I heard. Audioquattr also used a 0.7 GC
His impedance varies a lot from 0.13 on GC to 0.39 for the higher output MS.
sorry,Impedance match will have nothing to do with it.
Yes. The industry standard for phono inputs is 47KOhms. That is thousands of times higher than the actual impedance of most cartridges. So the phono section insofar as its input impedance is concerned will have no effect.interesting statement, can you please explain, why a different impedance match will not change the sound ?
Why don't you try both in Ian's phono and see if preference is the same?
Sorry that my English seems to be not precise enough for my message, in many documents I found the term "load impedance" :This is a topic that has been covered elsewhere on this site- search on 'cartridge loading'. 'Loading' of the cartridge isn't the same as the input impedance of the phono section.
The Van Den Hul site has some problems, but I'm not able to find anything that suggests that the XPP has a source impedance as high as 40 Ohms. It would need to be more than that for the 400 Ohms input impedance of the Lamm to affect it at all! So the difference, IMO is something else.To my knowledge Peter is using a Lamm with fixed 400ohm "load impedance", which will fit a standard XGP or XGW type but is a little low for the XPP. XPP will play on 400ohm a little darker and softer, which some listener will like.
I'm not parting with my MSS either. I like it so much that I have no itch to upgrade it to the Gran Cru. Plus I am using all LammMike, Jeffrey_T raves about the Colibri you sold him a couple of years ago. And I have heard from others that it is a particularly special sounding version of these wonderful cartridges. When I visit Jeff, I will take one of my new ones for comparison. I don't think Jeff will ever part with it as it suits his system and tastes extremely well.
"MC cartridge load impedance is usually 5-10xthe output impedance of the cartridge as specified by the manufacturer, 1x-5x for cartridges used with transformers. For MM cartridges load impedance is usually a standard 47k ohms"
So I will use this term.
(But I assume, the most readers will understand, that I meant with "impedance" or "load" the value, which is shown / set up on the individual phono stage to connect the cartridge.)
vdh recommends for XPP 1kohm and higher "load impedance" , he liked, that my Phonostage that time offered 5kohm.
To my knowledge Peter is using a Lamm with fixed 400ohm "load impedance", which will fit a standard XGP or XGW type but is a little low for the XPP. XPP will play on 400ohm a little darker and softer, which some listener will like. Nothing wrong with it.
This is the most important matter! Just enjoyThe only thing that really matters to me is that it sounds good, which it does.
it was the .38 mv Colibri.......Was this a Colibri or Colibri Stradivarius?
Yes, it was a nice listening session yesterday at Peter's place. It was great to meet you, Andy!
A lot of the music sounded enjoyable, but the highlight of the session was for me a recording that Andy brought, a masterpiece by Stravinsky, "The Flood", a gem from his late, serial period (written in 1962):
Igor Stravinsky, Laurence Harvey, Columbia Symphony Orchestra, Robert Craft - The Flood - A Biblical Allegory Based On Noah And The Ark
View credits, reviews, tracks and shop for the 1962 Vinyl release of "The Flood - A Biblical Allegory Based On Noah And The Ark" on Discogs.www.discogs.com
(click on the small image in the link to see all five images enlarged)
It is a quirky piece, with some quirky humor, too. The brief, sudden instrumental flickerings were presented with great vividness and dynamics, as were the vocals. In fact, I would say that the presentation was extraordinarily dynamic overall, and incredibly engaging to me as listener -- a great way to hear this work for the first time. It was Peter's system at its best, for me. We listened with the Colibri XPP, and I was also pleased that I did not miss HF extension, unlike at other times listening to Peter's system. I also found HF extension fine on the other recordings that we listened to, all with the XPP cartridge.
On this particular recording we also did a brief comparison with the Master Signature, and the difference was not subtle, in favor of the XPP cartridge. The presentation had more clarity with the XPP, considerably better dynamics and, as Andy said, more color. It also sounded more open, and with the Master Signature I had again a feeling of somewhat lacking extension and air. There just seemed to be a better synergy of the XPP cartridge with Peter's system. This was a comparison on just one recording though; I joined later in the session, and Andy may have heard more comparisons between the two cartridges.
Peter, I'm vaguely recalling you telling me you bought a Solti/Mahler LP - maybe the 8th. I would love to watch a video of your Lamm/Vitavox system playing it.
@PeterA I am not above inviting myself, for the next time you might host a listening get-together. I work in the Seaport and live just west of 128/95.
Tim, I’m afraid you’re mistaken. I don’t believe I have Mahler’s 8th. I will look, but I doubt it.
Nice thread Tim. Just ordered the Mahler No. 8.
